Old 07-13-2009, 04:53 AM   #20626
TJ
TJ's Avatar
Default help
Hi Guys I don't know if you can help me but .... i run a 415msx i am running a comp this weekend and I've been told that the surface is carpet but track temp is about 7 degree C. I am runing rubber hpi vinage tyres which is the class, so I need to take steering away and add traction to the rear. I know I am asking alot but has any one a setup I can start with. I was going to put a diff in the front and I was thinking of putting a JUNN rear end to add traction, am I going in the right direction. HELPPPPP
Castle Hill Raceway: www.castlehillraceway.com
Facebook: https://www.facebook.com/groups/121817254587521/
"Anything I say can or will be used against me at a later date":
TJ is offline   Reply With Quote
Old 07-13-2009, 07:00 AM   #20627
tc3team's Avatar
TJ- Although I have no experience of the Tyre, if the track and tyre are both low grip, I would possibly be looking at softer oils and springs to help the car with the steering.
Low grip and harder springs = drifting, or spinning out
A diff will make the car easier to drive, which if you're not used to lower grip levels, should help you out
Unless the track is very high speed and flowing, where a one way could be beneficial, but you'll have less brakes. Never used a spool on low grip tracks to say anything about that.
3 degrees rear toe should get the back end feeling pretty stable too.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 07-14-2009, 06:03 PM   #20628
haywood's Avatar
Trader Rating: 49 (100%+)
Default 415MS
Guys, I am going to run my 415 on ozite with rubber tires and when I got the car It had these susp. blocks in it.
Front
1b
1a
1xb
1d
Rear
Is this the correct set-up?Sorry these b,d,x,etc has me confused.
How should the car handle with this setup?
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 07-14-2009, 08:05 PM   #20629
chrisk's Avatar
Trader Rating: 32 (100%+)
I ran my 415 msx for the first time last night with the short arm suspension, alll i can say is wow
we ran a new layout with some tight hairpins and i was dreading it as i always suffered with understeer, but a few changes and the new short arms, it has never felt that good.
I run 540, so i am not up there with the top class, but the car was the best i have ever had.
CARPET SET UP QUESTION:
We race on ashpalt all the time but there is a series round here in Australia that is on carpet, never ran on that before.
What are some tips to run the 415 msx on carpet.
This is 540 class and will be on foams:
Any tip and any setup would be great
chris
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 07-15-2009, 08:05 AM   #20630
tc3team's Avatar
Chris, if the track is rather flowing, you may want to try a one way, to carry as much corner speed as possible.
However, using a one way you will have brakes (I doubt you will need them much with the speed of a 540 though )
Make the car as light as possible too (or as close as you can to the weight limit if there is one).
If the track is more technical, you might want to look at increasing rear toe to 3degrees to help the back of the car feel more stable on cornering.
Ride height 4.5 or 5mm and full rebound on the shocks would be a good starting point. Depending on the shore compound of the tyres and the grip levels, you will probably be using stiffer springs than the kit ones too...
Old 07-15-2009, 12:53 PM   #20631
Since I'm having a hard time finding the alloy knuckles for the 415 in stock anywhere, will it be difficult for me to run the 416 knuckles? I'm already running the short rev suspension.
home13oy75 is offline   Reply With Quote
Old 07-15-2009, 01:14 PM   #20632
Skitee's Avatar
The 415 knuckle uses 950(9x5) bearings and the 416 knuckle uses 1050(10x5) bearings and the 416 knuckle uses a slightly longer wheel axle(TB-03).
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 07-15-2009, 01:24 PM   #20633
Skitee's Avatar
DOUBLE POST.
Old 07-15-2009, 01:50 PM   #20634
94eg!'s Avatar
Trader Rating: 17 (100%+)
Originally Posted by Skitee View Post
...and the 416 knuckle uses a slightly longer wheel axle(TB-03).
Which also means you may need a slightly shorter driveshaft. But this depends on the blocks your using...
94eg! is offline   Reply With Quote
Old 07-15-2009, 02:12 PM   #20635
Skitee's Avatar
I did the complete short arm suspension conversion when I still had my MSX, the 415 kit drive shafts(46mm) work perfectly.
Old 07-15-2009, 03:29 PM   #20636
haywood's Avatar
Front
1b
1a
1xb
1d
Rear
Any help here guys?
Old 07-15-2009, 05:33 PM   #20637
chrisk's Avatar
Thanks,
I already run a one-way and we have a 1500g weight limit, so it will be right on that, ill look into some of your suggestions
cheers
smaracing.org
Old 07-16-2009, 01:00 AM   #20638
Skitee's Avatar
Any help here guys?
That should be fine to start with, you've got 0.5 degree toe out at the front and 3 degrees toe in at the rear.
Here's a link that will help with the suspension blocks
http://www.thard.co.uk/viewtopic.php?f=24&t=30
Old 07-16-2009, 11:49 AM   #20639
94eg!'s Avatar
In the front it's called "sweep" since toe is actually controlled by the steering tie-rods...
Old 07-16-2009, 11:58 AM   #20640
what does front sweep do to the car ??
sidecarphil1 is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
