Old 07-03-2009, 03:16 PM   #20596
Skitee's Avatar
Yes a wider hex is an option but even that may not create enough space.
The HPI/HB knuckles will work but then so will the TB-03/TRF416 knuckles
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 07-04-2009, 03:09 PM   #20597
STLNLST's Avatar
Trader Rating: 21 (100%+)
If anyone is looking for a used 415 with a few parts and special made tweak board and lipo tray I'll have mine up for sale in about a week or two.
STLNLST is offline   Reply With Quote
Old 07-04-2009, 07:43 PM   #20598
J Stark's Avatar
I want that special tweak board son. You're Tamiya career was short lived, it should have been mine in the first place
J Stark is offline   Reply With Quote
Old 07-05-2009, 01:49 AM   #20599
STLNLST's Avatar
I pulled the race card and received it first
Old 07-05-2009, 07:31 PM   #20600
Originally Posted by 94eg! View Post
Actually you've got it backwards. A lower FD means you get more top-speed. A higher final drive gets you more torque...
Longer gears = numerically lower
Shorter gears = numerically higher
Thanks alot
hoppie is offline   Reply With Quote
Old 07-05-2009, 09:18 PM   #20601
haywood's Avatar
Trader Rating: 49 (100%+)
Default 415 MS
Can someone confirm what parts are needed to run 28mm foams or even VTA tires to clear the knuckles?
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 07-05-2009, 10:03 PM   #20602
JimmyMac's Avatar
If you have 5mm hexes, you will need about 2mm worth of wheel shims to clear VTA tires. But that does not leave much room for the wheel nut to secure onto the axle. Best bet I think is to switch over to 416 caster blocks and knuckles. With a 5mm hex and 0.5mm wheel shim, I have good clearance on my 415 MRE. You can get the TA05 Short Arm set from Hk for about $63. Something like that. Awesome deal. Full set of suspension arms, hubs, blocks, knuckles, axles, bearings, hexes, and hardware. That's what I did for my 415MRE setup for VTA. Or, switch over to HPI knuckles and axles. I think that post is pages (years) back.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 07-05-2009, 10:19 PM   #20603
haywood's Avatar
Thanks,do you know the short arm kit number?
Old 07-05-2009, 10:27 PM   #20604
JimmyMac's Avatar
I did a quick search, here is one place that sells it for about $68. Part/kit number 54083.
http://www.rc-mushroom.com/product_i...ducts_id=16914
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 07-05-2009, 10:35 PM   #20605
haywood's Avatar
Thanks, Jimmy Mac,This might get spendy with 2 cars to convert!
Old 07-05-2009, 11:18 PM   #20606
JimmyMac's Avatar
You could just buy the caster blocks, spindles, bearings, axles, and kingpin hardware to save money. But I don't have part numbers for each of those items. It might be cheaper like that... maybe.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 07-06-2009, 08:54 AM   #20607
94eg!'s Avatar
Trader Rating: 17 (100%+)
Don't these parts require shorter driveshafts due to the wider axle bearings and longer axles?
94eg! is offline   Reply With Quote
Old 07-06-2009, 09:34 AM   #20608
tc3team's Avatar
If you can score some 26mm foams like these for example:
http://www.rc-direct.co.uk/enneti-to...re-p-3337.html
you will make your life (and pocket!) a lot easier.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 07-06-2009, 09:40 AM   #20609
JimmyMac's Avatar
No, the driveshaft length is determined by long arm vs short arm and/or wide or narrow suspension block. I'm running long arms on my MRE and use 46mm bones where as the 416 WE uses short arms and 44mm bones.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 07-06-2009, 10:38 AM   #20610
94eg!'s Avatar
Not really cause wider suspension blocks are used in conjunction with short arms to maintain the same overall width...
If you compare two cars that both came with long-arms and different hubs (MSXX vs original 416), the 416 uses 2mm shorter driveshafts. I was always told this is because of the longer axles...
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
