Old 06-04-2009, 12:22 AM   #20551
asw7576's Avatar
hello,
I have original 415 msx. My upper deck is broken. My LHS only has msxx upper deck left in the store. Can I use msxx upper deck as direct replacement ?
Old 06-04-2009, 01:31 AM   #20552
Originally Posted by Blueman Austria View Post
The size of the bearing is 9mm outer and 5mm inner diameter.
If you have a 1050, then it is 10mm and 5mm, and so on.
The thickness (i think) is caused by the outer and inner dimension.
There should be no different types of bearings available.
Greetz Blueman
I was on avidrc.com and did not see any 9x5 bearings but they did have 5x9x3. Is that the correct size then? Sorry just wanted to make sure since I already purchased 8 bearings that I can not use.
home13oy75 is offline   Reply With Quote
Old 06-04-2009, 01:59 AM   #20553
Skitee's Avatar
Originally Posted by asw7576 View Post
hello,
I don't think that will work, the steering system is different between the MSX and the MSXX so the steering posts are not in the same place and the holes won't match in the top deck.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 06-04-2009, 03:00 AM   #20554
r_s
unless the steering post is left unscrewed to the upperdeck. = more flex.
r_s is offline   Reply With Quote
Old 06-04-2009, 03:58 AM   #20555
asw7576's Avatar
I know more flex = more stable or more grip. Isn't that dangerous if you don't screw the top portion of steering post ?
Old 06-04-2009, 04:55 AM   #20556
r_s
i thought the steering post might be bent or the upperdeck broken if you hit something hard.
but i always run my msx without those screws and nothing bad happens.
maybe somebody else here can share their experience doing this trick??
Old 06-04-2009, 06:02 AM   #20557
tc3team's Avatar
ASW- The older top decks are probably pretty hard to get hold of these days
If you know of someone who uses CAD and has access to a cutting mill, that might be an option.
Haywood- I would keep a few steering arms, wishbones and uprights to hand just in case, the usual things if you tap a board too bad. In general though, i've found Tamiya's to be pretty durable
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 06-04-2009, 10:17 AM   #20558
asw7576's Avatar
Okay thanks people.
I already test msxx upperdeck. Yes, it can fit into msx except the holes for steering post, ie. top portion of steering post are naked.
Old 06-04-2009, 10:50 AM   #20559
Blueman Austria's Avatar
That are the right ones 3mm is the thicknes of the bearings!
Greetz Blueman
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 06-04-2009, 11:43 AM   #20560
94eg!'s Avatar
Trader Rating: 17 (100%+)
Greetz Blueman
On the MSX, the only thing holding the bell cranks down is the upper deck. I imagine you may generate more play in the steering with those upper screws missing. Still it [i]is[/] an option if you've broken your upper deck...
94eg! is offline   Reply With Quote
Old 06-04-2009, 11:48 AM   #20561
94eg!'s Avatar
Does anyone know what size is the 950 bearing? I bought some from avid and I believe I must have the wrong dimensions because they don't fit. I thought they were 5x11x4 ... probably more like 5x11x3??
950 actually refers to the size of the bearing in millimeters. 950 means 9x5mm. 9mm being the outer diameter, and 5mm being the inner diameter.
Just like 1510 bearings are 15x10mm & 840 bearings are 8x4mm. The other guy was correct about the width. Very few bearings have options for width, don't worry about it until you run into multiple choices...
Old 06-04-2009, 07:14 PM   #20562
haywood's Avatar
Trader Rating: 49 (100%+)
Default 415MS
Can someone tell me which lipo packs will fit in the stock 415MS chassis without having to go to a lipo tray?Thanks
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 06-05-2009, 06:13 AM   #20563
DRAG_ON's Avatar
i should have stock that upper deck long before, i know it getting harder to get MSX 415 upper deck. ASW can you share the pic of MSXX upper deck bolt into MSX chassis.
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
Old 06-05-2009, 07:41 AM   #20564
r_s
yeah it's too late now.
and the last (maybe) msxx upperdeck in our LHS here has been taken by ASW
hopefully we can order it.
Old 06-05-2009, 08:36 AM   #20565
DRAG_ON's Avatar
well i just have to use some PCB board with rotary tool and with carbon fiber sticker to make my own MSX upper deck, let me know if you need 1
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
