Old 05-03-2004, 10:56 PM   #2041
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
well, i had a few inquire about the diff swap, so here is a list of stuff:
Yokomo MR4TC belt car:
ZS-501 - diff joints (use the rear ones)
ZS-506 - diff rings (can use 414M/TA04 rings, i had some!)
ZS-507 - thrust set
ZS-508 - diff screw
ZS-010RT - rear liteweight shaft set- can use reg steel set part #
ZS-010RS
anyones 5x8mm bearings for the center of diff, and 3mm diff balls of your choice...
TRF415 parts
51055 - ball diff pulley
hardest part was the 6x11 adapting bearing that the larger Yoke drives required. found a Tamiya part # of 9805802, comes from the TXT-1 somewhere...
for the center, im sure there are a number of ways, but i just used another locked pulley, part #51060, and filed it and the spur holder down. whole setup worked great last weekend, and ill put up a few pix...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 05-03-2004, 10:58 PM   #2042
Turbonium's Avatar
Default and another...
of the center spacing...
i might also add that other than the filing of the center components, all the front diff pieces fit together like butter... no funny stuff, machining, spacers, shims, etc.
Wes
Team Novak
Old 05-03-2004, 11:04 PM   #2043
AdrianM's Avatar
I have a question for you guys. I was talking to Surikarn at the pre worlds and he said that Tamiya will be running a new car at the Worlds. The Evolution 4 Pro. How long has the 415 actually been available?
Adrian Martinez
Old 05-03-2004, 11:18 PM   #2044
over gear's Avatar
Trader Rating: 15 (100%+)
Default Re: and another...
what battery plate is that??
over gear is online now   Reply With Quote
Old 05-03-2004, 11:20 PM   #2045
Turbonium's Avatar
that is the Xray holder, for the 6-inline setup... works pretty well, other than not being TCS legal!
Wes
Team Novak
Old 05-04-2004, 12:57 AM   #2046
over gear's Avatar
Cool! that's good news for lazy people
how do u mount that on the chassis? that little battery tape slot is not counter sunk for flat head screw....
Old 05-04-2004, 01:47 AM   #2047
Registered User
Suradaj's Avatar
I made a diff for the front today by using YOKOMO MR4TC parts and the TAMIYA F201 universal dogbone. Perfect fit. No shimming, no changing of any bearings, and no troubles. I will try it out at a local race this weekend to see how it is.
I like the oneways. Just want to see how the diff works on the 415.
Suradaj is offline   Reply With Quote
Old 05-04-2004, 07:28 AM   #2048
Martin Crisp's Avatar
Default Adrian : 415 & EVO 4
Hey Adrian,
The 415 has not been out long. Tamiya has two top cars they constantly evolve. One is shaft (EVO) and one is Belt (41X). So for those that want a shaft drive, the evo is the place to be.....and the 41X (e.g 414, 415) is the car if you prefer belt. Both approaches have their pros and cons. Both cars are great.
From my testing, at the moment the 415 seems a little quicker than the evo III,... I think mainly due to the stiffness of the chassis of the 415. But the shaft drive is certainly more efficient. I would bet the EVO IV will have a stiffer chassis setup than the EVO III.
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 05-04-2004, 08:15 AM   #2049
Turbonium's Avatar
for the strap, i just use a small file to let the screws fit flush... kinda envision this: <0>. i got some of that Xenon tape which is the best tape i have used, but the strap is still easier...
Wes
Team Novak
Old 05-04-2004, 08:16 AM   #2050
Turbonium's Avatar
i was gonna try the F201 bones, just didnt have any handy... that would be much easier! i did have the MR4 set laying around, so i thought id try....
Wes
Team Novak
Old 05-04-2004, 10:23 AM   #2051
Registered User
Suradaj's Avatar
The F201 bones are long but it will work. You still have about 1.5mm clearance of play at the end so the suspension don't bind up.
Old 05-04-2004, 10:37 AM   #2052
ZS-507 - thrust set
ZS-508 - diff screw
ZS-010RS
TRF415 parts
Cheers Tamiyadriver
This gives me something to do while my kit is being shipped out , time to go parts hunting around my local hobbie shops.
Setup sheets
Has anyone got blank setup sheets that can be downloaded and team drivers setup sheets for outdoors on tarmac so i can see what people have been running ?
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 05-04-2004, 12:24 PM   #2053
Registered User
Suradaj's Avatar
This is what I used to make a diff for the front. I didn't have to go looking for bearings or many parts to do it. I used the same bearings that is in the front of the 415 bulkheads.
TAMIYA 51055 415 Diff Pully
TAMIYA 53522 F201 Unversal shaft
YOKOMO ZS-501 Diff Joints
YOKOMO ZS-506 Diff Rings
YOKOMO ZS-507 Diff Thrust Bearing Set
YOKOMO ZS-508 Diff Adjusting Kit
I am just going to pin the mid gears.
Old 05-04-2004, 12:28 PM   #2054
over gear's Avatar
What kind of diff ball does 415 comes with? steel? carbide? ceramic?
my diff feels rough after 2 race day... is it normal?
Old 05-04-2004, 12:37 PM   #2055
Hi everybody,
I've just receive my brand new 415, I got a question:
I've received:
OP-440 springs but it is the hard spring set, what is the reference for the regular kit?
Tamiya
Purple 22.72
Gray 20.91
White Short 17.24
Blue Short 15.27
White 14.82
Blue 14.08
Yellow 13.33
Red Short 13.24
Yellow Short 12.90
Red 11.86
Hugo is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
