Old 04-20-2009, 10:36 AM   #20461
Originally Posted by Blueman Austria View Post
Hy there!
I own an MSXXMRE07, with the kit puleys and the internal ration of 2,25
Now i have al the part i need to change it form 2,25 to 2,0:
TRF501X/416 Puleys 18T
HB front belt 169T
Xray rear belt
Now my question, because i have not much tracktime to test:
Is it always a benefit to lower the internial ratio? or depends it on wich class you run (mod or stock)
I run the car in 9,5BL 5cell/13,5BL LIPO classes.
Thanks in advance for some answers.
Greetings Blueman
dont worrie about that i race with 10.5 BL with a TRF415MSXX and i use stock internal ratios and use 98/48 which gives about 4.17(ish)/1 and i can keep up with the 13.5BL lipo boys with Xrays
sidecarphil1 is offline   Reply With Quote
Old 04-20-2009, 12:18 PM   #20462
Blueman Austria's Avatar
I think also that the difference will not be much, but i read (i think in this thread) that a lower internal helps the car to get faster on topspeed when you accelerate out from corners. compared to the higher internal, when the alover ratio is the same.
Has anybody further expirience in this stuff?
Greetings Blueman
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 04-20-2009, 01:40 PM   #20463
we have noticed with brushless motors this year that the cars reach there top speed in about 70 to 90 meters of accelaration on our back straight
the brushless motors used to wind up more slowely usually reaching top speed half way down our back straight
The brushless motor has not as much torque i find as the brushed motor but find it revs well so keeping speed throught the corner is REALLY important
my TRF can keep up with the Xray009 and the Hotbodys through the corners and down the straight , just my driving skill lets the car down !!!
Old 04-20-2009, 01:46 PM   #20464
mutley001's Avatar
Hi guys
Just got hold of a second hand 415 msx mre and want to get a base setup for rubber carpet racing. Tried searching the tread but can't find any setups with that links still work!
Any help you can give would be greatly appreciated
Cheers
Paul
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 04-20-2009, 02:02 PM   #20465
TryHard's Avatar
Paul....
www.thard.co.uk/415
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 04-20-2009, 02:02 PM   #20466
TwoTone's Avatar
Originally Posted by mutley001 View Post
Hi guys
Cheers
Paul
http://www.thard.co.uk/415/415info.html
TwoTone is offline   Reply With Quote
Old 04-20-2009, 02:24 PM   #20467
mutley001's Avatar
Thanks guys,
Didn't know Ed had a site for the 415 as well, nice one matey!
Cheers
Paul
ARC R11 2017
ARC R10 2013
Team EAM
Old 04-20-2009, 04:07 PM   #20468
94eg!'s Avatar
Trader Rating: 17 (100%+)
Does anybody have anything for extremely small parking-lot outdoor asphalt, specifically on the MRE & MSXX cars? I checked the list of setups in the link provided, but we absolutely cannot run spools on our track. I've always run with a front one-way cause the corners are so tight and low-speed.
The MSX-MRE kit setup works decent with the front one-way, but I'm sure it could be better...
94eg! is offline   Reply With Quote
Old 04-20-2009, 05:57 PM   #20469
JayL's Avatar
usually tight is where a spool works better, high speed flowing corners is one-way
JayL is offline   Reply With Quote
Old 04-20-2009, 06:49 PM   #20470
Default IFS for the TRF??
Why don't the TRF cars have the IFS suspension??? I thought the IFS was a new a better design. Have the racers found that it isn't better, difficult to tune???
I am looking to get a TA05-IFS, but is it a waste of money? will the normal TA-05 be a better performer?
RepaF1 is offline   Reply With Quote
Old 04-20-2009, 07:03 PM   #20471
TwoTone's Avatar
Only difference is the body you can run, IFS allows the bodies with lower front ends on them.
If you get a TA-05, either reg or IFS, do yourself a favor and get the 'R' version shocks alone worth the price difference.
If you buy used look at it carfully, I see a few on here that aren't true 'R' version even though the person lists as such
Old 04-20-2009, 07:23 PM   #20472
maxepower's Avatar
Unhappy Unfair advantage?
I think a lot of race events don't allow IFS bodies because their not ROAR approved and in club racing they say it's an unfair advantage because the bodies only works on Tamiya IFS suspension and not any other car MFG.
Just a guess!
maxepower is offline   Reply With Quote
Old 04-21-2009, 02:26 AM   #20473
penmark67's Avatar
Trader Rating: 14 (100%+)
Default .
Put in a front diff and run a similar setup to a T Hard carpet rubber setup , the diff will make it easy and predictable to drive which will give you consistant lap times.
Mark Miller
penmark67 is offline   Reply With Quote
Old 04-21-2009, 09:30 AM   #20474
94eg!'s Avatar
Just a guess!
IFS bodies are for looks only. They are meant to mimic real life touring cars with hood lines so low that they actually dip down between the front fenders. Unfortunately the aerodyamics of a 1:1 car do not scale down, and your typcial touring car body is going to provide far superior downforce for both front & rear. This is why your typcial touring car body is illegal at Tamiya TCS events. If they weren't, everyone could only run the Tamiya Legacy B4 to be competitive...
In addition, the pushrod suspension actually adds to the complexity creating room for more slop. Instead of two ball-joints per shock, you now have 4, plus a ball-bearing and rocker arm. This does adds considerably to the unsprung mass of the car (even though it may not seem like it).
Old 04-21-2009, 09:41 AM   #20475
asw7576's Avatar
Sometimes slop is good.... it gives nimbleness to suspension.
( btw, I still prefer normal shock though ...... simplicity is better for me )
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
