Old 04-06-2009, 02:27 AM   #20401
tc3team's Avatar
Originally Posted by penmark67 View Post
Hi mate , I ran a 415 on foams at an indoor venue and ran 37s on the front and 40's rear schumacher 32lb front springs and 28lb rears 50wt f and 40wt rear 3 hole pistons short camber links and middle hole on the bottom of the arms front and rear 1.5 deg camber f&r 1.5 deg toe out front and 2.5 rear toe in 4mm ride height 3mm droop
I ended up running 2 top decks to stiffen it all up ,
Ps all depends on the type of carpet ur running on
Cheers Mark M
What holes did you use on the shock towers? thanks
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 04-07-2009, 05:46 AM   #20402
penmark67's Avatar
Trader Rating: 14 (100%+)
Default holes
Second from the outside on the front and second from the inside on the rear and yes it was very aggressive.
Hey Phil , Ive put all the 416 parts on the car and it feels gooood .
The way i see it with the short arms,knuckles,uprights,suspension blocks and ackerman spacers all 416 with the 10x5 bearings in the right places (instead of the 9x5's) i should see a bit of a difference.
Have a great easter
Mark Miller
penmark67 is offline   Reply With Quote
Old 04-08-2009, 02:54 AM   #20403
tc3team's Avatar
Have a great easter
Mark Miller
Thanks,
I have used the same settings with 35 shore front, 32 rear foams and it's waaay too aggressive on the steering. (grip rolling) I am going to get some 40 or 37 and see how they fair...
Old 04-08-2009, 06:26 AM   #20404
Have a great easter
Mark Miller
I think that same at i`ll chance those knuckles for bigger bearings 10x5 for summer racers
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini M03 - Tamiya 415MSX MRE - Tamiya 416 WE
Cruisaaja is offline   Reply With Quote
Old 04-08-2009, 03:41 PM   #20405
tim fry's Avatar
What alternative turnbuckle ends can I use as my standard ones have too much slop? I have tried HPI and Schumacher and these are too tight on the balls.
tim fry is offline   Reply With Quote
Old 04-08-2009, 03:56 PM   #20406
TryHard's Avatar
Tim, just replace them with new tamiya ones.
To remove some of the slop currently, take some packaging plastic, remove the ball cup and then place the plastic over the ball joint. Now pop the cup back on, and it'll cut a perfect circle out of the plastic. If the joints are particularly sloppy, you may want to try that a few times.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 04-08-2009, 04:06 PM   #20407
tim fry's Avatar
HiH
Ed
Thanks for the advice Ed. I have tried to get some Tamiya replacements but cannot get any for the wekend
I have some on order but need some for Friday night as the centre steering ones keep popping off!
Old 04-09-2009, 01:05 PM   #20408
Hey
I need to see is it possible to fit SMC C-max/LRP5300 lipo for MRE without heavy dremeling.
Can anyone post a pic... thanks
Old 04-09-2009, 01:48 PM   #20409
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Cruisaaja View Post
Hey
The only way that is happening is if you get a bitty design tray.
STLNLST is offline   Reply With Quote
Old 04-09-2009, 01:53 PM   #20410
STLNLST's Avatar
HiH
Ed
You should think about adding a how to drive better section to your web pages. I have read every bit of info you have posted yet I don't have any wins yet. I think your info is flawed
........or maybe the nut behind the wheel is to blame
Keep up the good work and my win is coming We have the Reedy warm up race this weekend and I hope to do well but my main thing will be to have FUN!!!!!!
Old 04-09-2009, 02:03 PM   #20411
well my car is set !!!
good job really as i have just entered in to the Euro round at Apeldoorn NL
i hope i get to practice there before
sidecarphil1 is offline   Reply With Quote
Old 04-10-2009, 01:24 PM   #20412
right i'm trying an one way again in the front
do you think i'm mad ????
using a 10.5 BL motor on a tarmac high grip high speed track ???
Old 04-10-2009, 05:32 PM   #20413
Can anyone tell me how the service is from RC Market in Hong Kong to the U.S.?
Cheerz
Obsidian is offline   Reply With Quote
Old 04-11-2009, 12:45 AM   #20414
STLNLST's Avatar
Cheerz
Excellent
Old 04-11-2009, 05:29 AM   #20415
Cool thanks
Looks great. There is`t any HK onlinestore to buy, but only that bittydesing in Italy?
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
