Old 03-06-2009, 01:11 AM   #20266
Originally Posted by bigkoitat View Post
I just wanted to share what set up I have on my 415MSXX-MRE
I used the Josh Newman Reedy set up but with front yellow springs
and red rear springs, also .5 spacer under the rear suspendion mount spacer.
The set makes the car feel planted on unprepped sealed asphalt. So when I go to the races on the weekends the car has tons of traction with Soda/Water prepped on sealed asphalt. The reason I'm sharing this cause now my 415 and 416WE feels excactly the same!!! I'm just excited and wanted to share
the 0.5mm spacer under both rear suspension mounts ?? or just the rear most one ??
sidecarphil1 is offline   Reply With Quote
Old 03-06-2009, 03:59 AM   #20267
chrisk's Avatar
Trader Rating: 32 (100%+)
bigkoitat
can you share the whole setup
always looking at others to try anything to gain more speed
Thanks if you can
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 03-06-2009, 10:52 PM   #20268
bigkoitat's Avatar
Trader Rating: 6 (88%+)
chrisk and sidecarphil1 I couldnt get the Newman setup to upload but I did get this one to work, this setup is ecxactly what I'm running. and the .5 spacer is on the rear most suspension block
hansB_msxx_01june[1].pdf
JAWS
TRF-416WE & 416-X / DHW / TEAMRCR.NET
bigkoitat is offline   Reply With Quote
Old 03-07-2009, 12:26 AM   #20269
asw7576's Avatar
Originally Posted by STLNLST View Post
The 415 isn't lipo friendly either. I had to mill mine just to get the Orion 3800's to fit. You can't even think of trying to get a 5000 to fit unless you get the bitty design tray. I plan on trying the tray out because I like the 415. This is also my first Tamiya so I don't have any 416 info to share with you. Many have said that the 416 is faster across the board but until someone here beats me with one I don't believe it
I recently modified aluminium rear bulkhead of my 415 msx. I just bought Speed Energy 4000 35C ( I think this battery is same as Intelect Power 3800 35C ).
It wasn't fun..... coz I have to dremel it carefully...... it took me 30 minutes. I don't want to do lousy job, u know .
One thing that disappointed me..... my yokomo BD can accept 5000 30C easy without modification, but my 415 msx cannot.
What do you guys think of 5000Mah 30C versus 4000Mah 35C ? Which one is better for racing ? My home track still adopt 5 minutes qualifying and final. I'm using Novak GTB 3.5R.
Old 03-07-2009, 12:36 AM   #20270
STLNLST's Avatar
Trader Rating: 21 (100%+)
I was always told the higher the mah the longer the discharge curve. So I'd stick with the 5000 pack.
STLNLST is offline   Reply With Quote
Old 03-07-2009, 01:09 AM   #20271
asw7576's Avatar
Originally Posted by -KilleR- View Post
You will need to modified your bulkhead to fit in the other higher mah batts. I'm currently using it with Orion 3800 hard case. See attached picture for the modification done on the red circled area.
I saw your modification...... I think your craftmanship is better than mine. ..... how did you cut so straight ?
Old 03-07-2009, 06:24 PM   #20272
TwoTone's Avatar
Does anyone know where you can buy just the one bulkhead that needs to be milled for lipo? I'd like to have an original spare before milling the one I have.
TwoTone is offline   Reply With Quote
Old 03-07-2009, 07:49 PM   #20273
chrisk's Avatar
cheers thanks for the setup ill have a look compared to mine and try a few things
smaracing.org
Old 03-08-2009, 11:23 AM   #20274
asw7576's Avatar
I think you need to buy MSX upgrade kit ...... the complete upgrade kit shown in my photo attachment above.
IMO, I think you don't have to buy extra bulkhead if you grind off some materials slowly and carefully . Plan ahead how much material you want to remove by marking what area to cut and what area must not be cut.
Old 03-08-2009, 03:23 PM   #20275
Skitee's Avatar
+1...It really is a very easy mod to do, just take your time and do it right
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 03-08-2009, 06:11 PM   #20276
Trader Rating: 59 (100%+)
Send a message via AIM to todb
I run a 415 msx in vta at my track and it is a blast. But i cant keep good corner speed without it traction rolling or i get lucky and manage to keep 2 wheels on the ground. Because the car is has not been run for some time i dont remember what set up is on it. I run on carpet open track with good flow but i run a diff in the front cuz its all i have. Can anyone give me a good setup to start with. thanks in advance
todb is offline   Reply With Quote
Old 03-08-2009, 09:19 PM   #20277
bigkoitat's Avatar
No worries mate, i ran that setup today and my car was hooked up!!! I just neede to get the correct gearing and when I did I was at the front till I got taken out by a wrong way driver.... thats racing though
JAWS
Old 03-09-2009, 12:36 AM   #20278
asw7576's Avatar
Sorry to ask a silly question......
Recently I just completed a race....... during heat 1 to 3, my car was fish tailing alot, especially in S chicane corner : I can enter the right turn but loose traction completely on the left turn and fish tailing on the exit. ..... So I asked my friends what setup to minimise the fish tailing problem on quick S corner, but their suggestions were not cure my problems at all. One friend mentioned to use brand new tires, but I was stinggy and I keep using paragon.
I finally gave up after driving in Final #1...... and I decided to change rear tires. Luckily I found slightly used tires in my RC bag. So I gave them paragon and use them for rear tires. HALLELUJAH !! Suddenly I can blast off leaving my rivals and finished 1st ?? ..... ( I'm in group B , not A ..... I'm not that good driver ).
So, is there great car setup for old tires, OR, definetely they are not exist in electric racing ?
Sorry friends, I'm nitro guys...... I'm lack of knowledge in rubber tires business. Thank you for sharing ideas .
Old 03-09-2009, 01:17 AM   #20279
piper48
Guest
Posts: n/a
Default rubber tires
No substitution for fresh rubber. You yourself experienced the difference between the tires. I'm pretty sure there is a set up out there for worn rubber but would you be willing to waste 1 or 2 qualifiers trying it and then chasing the set up if it doesn't work? I can understand the stinggy part cuz I race on a budget, but again no substitution. As they say in NASCAR "come in and get yourself 4 Mr. Feel Goods"
Old 03-09-2009, 12:05 PM   #20280
STLNLST's Avatar
Will taking right side only apply for us as well I couldn't help myself. I had to throw that out there
This Saturday will be my first asphalt rac with the 415. I can't wait. I'll be running at Speedworld (home of the 08 & 09 Reedy Race) I'm torn between running Marc's 07 Reedy set up and Corey's set up. If feel like a girl trying to decide who I'm going to the dance with
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
