Old 02-01-2009, 08:37 AM   #20176
Ricky/C's Avatar
Send a message via MSN to Ricky/C
Originally Posted by B4 View Post
I look forward to the next installment. I've tried a couple of online shops in HK without luck so I'm going to try Pro Shop Futaba in Japan. I know they have the pinions, just waiting to see about the spurs.
Try towerhobbies?! If you still cant find anything, pm me and I'll send you some!
TRF 416 WE | LRP SPX Stock Spec| 17.5 SP | Sanwa M11
TRF 416 WE | LRP TC Sphere | Novak 3.5 | Sanwa M11
www.oneten.co.za >>>>>>>>>>>>>>>> Home of RC in SA
Ricky/C is offline   Reply With Quote
Old 02-02-2009, 01:17 AM   #20177
B4
B4's Avatar
Thanks really appreciate your offer.
B4 is offline   Reply With Quote
Old 02-03-2009, 05:41 PM   #20178
TwoTone's Avatar
Quick question, may be getting a use 415 MSX and I current;y have TA05R
I know the LWR suspension is the same, but what about the stuff like Front one way and spool, will my TA05R ones fit the 415 MSX?
TwoTone is offline   Reply With Quote
Old 02-04-2009, 12:36 AM   #20179
Skitee's Avatar
Unfortunately not, the TA-05 one-way and spool is offset to the side in the bulkheads while the TRF415 one-way and spool runs just about in the middle of the bulkheads.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 02-05-2009, 08:33 AM   #20180
Chill_Will's Avatar
Trader Rating: 32 (100%+)
I have the 415msx - I'm looking for a good starting set for rubber tire racing on asphalt. I have seen all the setup on Tryhard website but I'm looking for one where I only have to change springs, shock oil or camber links if I go to a different track. I don't want to have to stock all the different suspension mounts.They confuse me.
A-Train racing (Woooooo Wooooo!!)
Chill_Will is offline   Reply With Quote
Old 02-05-2009, 04:49 PM   #20181
mild seven's Avatar
Trader Rating: 63 (100%+)
Send a message via MSN to mild seven
Hey.
Try my setup http://www.ttrc.com.au/index.php?opt...id=5&Itemid=28
with this setup all i needed to do is change shock position and different springs depending on track conditions.
mild seven is offline   Reply With Quote
Old 02-06-2009, 04:26 PM   #20182
Chill_Will's Avatar
Thanks, I will check out your set up. I know I will be running different springs and oil because I run on a medium traction track. I'm mainly concerned with what supension mounts that will work.
Old 02-09-2009, 12:15 PM   #20183
STLNLST's Avatar
Trader Rating: 21 (100%+)
Ran the car for the first time this weekend and it feels just like my cyclone. There are a couple of issue's I found but nothing to get all upset about just yet My car came with black belts but some of the guys running 415's have white belts. What's the difference between the two?
STLNLST is offline   Reply With Quote
Old 02-09-2009, 12:27 PM   #20184
linger's Avatar
The white belts was an attempt at lower drivetrain losses by using a softer belt. Personally, I hated the white belts. They were prone to flipping over and loosing teeth - especially in mod. It might be good for the slower motor classes.
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 02-09-2009, 12:28 PM   #20185
Skitee's Avatar
The white belts are low friction belts, which one you should run depends on the class you're gonna run the car in. The low friction belts would work fine and give you good life from 8.5 to 21.5, I've run the low friction belts in 6 cell mod(4.5) foam/asphalt and they just about make a race day (4 runs). Since going to the standard black belt I'm getting much better reliability from the belts.
Old 02-09-2009, 01:12 PM   #20186
RC MARKET's Avatar
Some TRF415 parts back in stock !
RC MARKET is offline   Reply With Quote
Old 02-09-2009, 02:43 PM   #20187
STLNLST's Avatar
Pedro had them on his car so that's why I was asking. I'll probably stick with the black belts for now but may try out the white one since all I run is 13.5 now. What's the difference between the milky white springs and regualr Tamiya springs? I have all the milky white one's if they are better.
Old 02-09-2009, 02:46 PM   #20188
Skitee's Avatar
No difference in the spring rates, I like to call them KGB springs since nobody knows your SECRET spring setup
Old 02-09-2009, 03:02 PM   #20189
STLNLST's Avatar
I'll just tell everyone that I'm running white springs all the time. On foam and rubber What's the deal with the bearing size? I've heard that the 415 goes through bearings like crazy. Why is that if it's true?
Old 02-09-2009, 03:52 PM   #20190
the milky whites springs are 17 lbs.
bigdog is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
