Old 11-25-2008, 09:38 AM   #20131
minimusprime's Avatar
Trader Rating: 19 (100%+)
Originally Posted by 94eg! View Post
Technically that makes my above post correct in ALL circumstances...
right. that would have been a lot easier to say. hehe.
"I personally do not believe in luck. I believe luck is just an excuse for people that have failed in their mission to accomplish something." Allen McNish
minimusprime is offline   Reply With Quote
Old 11-25-2008, 10:35 AM   #20132
I12PonU's Avatar
Trader Rating: 10 (92%+)
Thanks. I think I'll just grind off the hump on my stock bulkhead and get a spare piece for NIMH. Even the bulkhead is at least 50 bucks..
Here is the link to the two stick pack conversions. If you have an MSX, you nee the parts from the MSX conversion. If you have an MSX-MRE or later, you need the parts from the MSXX conversion (because of the ackerman steering). To find part numbers, just click on the "Parts Listings" button above the photo in the link...
BTW: The bulkhead parts and upper deck alone at $122 cost more than the entire conversion that can be had for $99. And TamiyaUSA is the only place that has them (according to google)...
I12PonU is offline   Reply With Quote
Old 11-27-2008, 04:54 AM   #20133
Hi, does anyone have the instructions for the stick pack conversion? Thanks in advance.
Ben.C is offline   Reply With Quote
Old 11-30-2008, 04:35 PM   #20134
Just dusted off my very old 415 as im returning to racing now brushless and lipo are getting so popular, was going to get a new Xray 009 but checked my old car for lipo fitment and seeing as they drop straight in and im a tamiya nut im planning on running the 415 instead.
Just got a short list of worn parts needing replacment such as ball cups, diff outdrives and wheel axles.
Any gains to be had in running the newer short arms on the 415 ( first version ) and if so what else needs to be changed ? part numbers or links would be a great help.
Any other parts that are worth using ?? i already run a spool, fixed centre pulley and white belts.
weekendracer_uk is offline   Reply With Quote
Old 11-30-2008, 05:45 PM   #20135
mild seven's Avatar
Trader Rating: 63 (100%+)
Send a message via MSN to mild seven
I just raced at the Masters on the weekend finishing 2nd in the 8.5 brushless class with the 415. Pretty happy with the result but i got beaten by a team aresoshit TC5
The car had no pace down the straight, i think i have cooked the motor. I reckon a 13.5 would of been faster.
I will be posting a set up later today
mild seven is offline   Reply With Quote
Old 12-15-2008, 05:38 AM   #20136
barts71m's Avatar
Trader Rating: 34 (100%+)
Anyone know where I can get a motor mount bulkhead #3455726 for an original 415...i dont really wanna do the upgrade to the later model stuff cause the price of the AUD atm i could almost afford another 416 lol....i ran the car in silver can and just love it...dont wanna retire it too a shelf queen just yet.
cheers
Smokem Racing, KBI Factory Team, Need some speed get some EAD, Contra Industries
barts71m is offline   Reply With Quote
Old 12-15-2008, 03:41 PM   #20137
Wink
cheers
Tamiya usa has the bulkheads. but it's probably cheaper ordering it from your LHS. Just letting you know they are not hard to find.
Don't retire the car, it is a great car. How fast it is depends on the hands that wheel it!
Obsidian is offline   Reply With Quote
Old 12-16-2008, 05:41 AM   #20138
barts71m's Avatar
Thanks for the info. Getting stuff out of Tamiya USA is hopeless without a US address and our LHS here is OZ dont usually do Tamiya TRF stuff. But have found an MSX upgrade kit. JUst need to find the LWT arms for it. 51104 is the part number I believe...is that all you need to change or do I need to start replacing C hubs and steering hubs etc etc.
Old 12-19-2008, 09:15 PM   #20139
Downunder... you should be able to order from RCmarket, rcchamp, basically anywhere from hong kong or japan. The shops over there have everything.
Old 12-22-2008, 02:41 PM   #20140
TryHard's Avatar
Haven't been in here for a while, but updated a useful little document today for the 415 MSX onwards.
It's the roll centre calculator that I created about a year ago, finally got round to gettting it as I completely wanted (slow work day).
Simply put your settings in, and ahve a look at your static roll centre. It's a useful little tool for seeing how the different settings affect the car, you'll be suprised at how much differnce only a small change can make.
Cheers
Ed
| THard.co.uk | Xray | MuchMore |
Old 12-28-2008, 10:11 PM   #20141
Default MSX still dominating
I love this car! Destroyed all the JRXR's, TC5's even the new 416's. The MSX is an awesome racing. I just slapped martin crisps vegas rubber setup and blew everyone out of the water by 2 laps.
MSX rule..
In addition, TRY Hards website rules, thanks for all the new tips and mods for the MSX!
Cheers.
Ed.
EdwardMSX08 is offline   Reply With Quote
Old 12-29-2008, 01:22 PM   #20142
Blueman Austria's Avatar
Default Lipo Tray
Hy there !
Does anyone tried out the bittydesign Lipo battery tray on the 415 M
SX/XX?
http://www.bittydesign.net
I think i will get one because i wont dremel out my bulkheads or swap over to the stick pack conversion.
With these trays i think there will be no limitation of fitting any lipo in the car.
Does anybody know if there are other manufractors of stuff like that?
Greetings Blueman
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 12-29-2008, 02:49 PM   #20143
chrisk's Avatar
Trader Rating: 32 (100%+)
SX/XX?
I use one and so do a couple of other guys at my track, they fit great, help with a little weight when running lipos and help move the battery away from the rear bulkhead
you can also get them from http://www.feralbatteries.com.au/category.aspx?id=%2053
depends on your location and the exchange rate, Feral batteries are based in Australia
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 12-29-2008, 11:24 PM   #20144
Thx for the info!
I will order mine from bittydesign direct, because they are from Italy, and there the tray costs 35 Euros and additinoal 8 Euros shipping costs (for 4 Trays) to Austria (not Australia).
Cant wait to get one and test my new Trackpower Lipo.
Greetz Blueman
Old 01-01-2009, 09:05 PM   #20145
TwoTone's Avatar
I hate to ask, been reading and can't find this in one place.
Can someone summarize the differences between all the 415 versions please.
TwoTone is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
