Old 11-21-2008, 07:57 PM   #20116
mild seven's Avatar
Trader Rating: 63 (100%+)
Send a message via MSN to mild seven
ok thanks. I think it was a hot bodies and a xray belt. hmm gonna have to find the thread where this was discussed.
mild seven is offline   Reply With Quote
Old 11-22-2008, 10:02 AM   #20117
94eg!'s Avatar
Trader Rating: 17 (100%+)
It's THIS thread. Just go up the upper left corner and press the "search this thread" button. Then you can try looking up x-ray or 2.0 or whatever...
94eg! is offline   Reply With Quote
Old 11-23-2008, 08:53 AM   #20118
mac853's Avatar
Excuse me, anybody which assembled front diff before could confirm if the it's really looser than the rear 1, in the case i broke the screw in the 1st time when i try to put it at least as tight as the rear, as it convince me the front diff could not be as tight as the rear 1, isn't it?
Best regards
mac853 is offline   Reply With Quote
Old 11-23-2008, 12:23 PM   #20119
rctouringracer's Avatar
Send a message via Yahoo to rctouringracer
you should be able to get the same tension on the front & the rear diffs....
rctouringracer is offline   Reply With Quote
Old 11-23-2008, 05:45 PM   #20120
TryHard's Avatar
Originally Posted by Chico View Post
I have seen this site and it is very informative, but the setups will not show up for me. I go to the rubber car setup section and then click on some of the setups and they just take me to a search type website. The Corey Lewis setups will not open for me, they just take me to a page that has no setups on them.
I also can not see any setups on that site for the MSXX. Is there any whre to see Rheinards setups for mod rubber from Vegas the last 2 years?
My bad. When I switched the site over to the forum software, I thought I'd moved all the setups across properly... looks like I missed some. I'll try and get the links fixed tomorrow. Cheers for the heads up
At Mild Seven;
Belt details are on here
http://www.thard.co.uk/415/tips/18tpulleys.html
Regards
Ed
| THard.co.uk | Xray | MuchMore |
Old 11-24-2008, 12:27 AM   #20121
Rozzt_iwa's Avatar
Send a message via MSN to Rozzt_iwa
dose any one know where i can get stiffiner posts bk1 and bk2 i got a second hand trf 415 and didn't come with them
B5M (17.5),cactus (17.5),sc10 short corse truck (10.5), sakura s zero VTA(21.5),mini-z
www.nbhc.com.au
supporting local hobby shops
http://www.iwawrestling.com.au
Rozzt_iwa is offline   Reply With Quote
Old 11-24-2008, 05:31 AM   #20122
barts71m's Avatar
Trader Rating: 34 (100%+)
Ross...dont worry bout em too much....didnt get them with the car either and they are only good for carpet use I believe.
Smokem Racing, KBI Factory Team, Need some speed get some EAD, Contra Industries
barts71m is offline   Reply With Quote
Old 11-24-2008, 01:03 PM   #20123
Default Lipo battery that Fixes 415 msx
Does anyone know what lipo battery model fixes the 415 msx without modifing the car?
GoletaBill is offline   Reply With Quote
Old 11-24-2008, 02:03 PM   #20124
94eg!'s Avatar
As far as I've heard NONE of them fit without modifying spot where the blukhead curves around the cells. Your best bet would be to research the stick-pack conversion or buy a 416...
I tried a friends Yeah Racing 3200 in my MSX MRE and it wouldn't go...
Old 11-24-2008, 02:08 PM   #20125
minimusprime's Avatar
Trader Rating: 19 (100%+)
i was able to fit an smc 28c 4000 after grinding off about 2-3mm off the little hump thing that hangs down on the bulk head. if you're not willing to remove that then the above answer is correct. none.
"I personally do not believe in luck. I believe luck is just an excuse for people that have failed in their mission to accomplish something." Allen McNish
minimusprime is offline   Reply With Quote
Old 11-24-2008, 07:34 PM   #20126
94eg!'s Avatar
Technically that makes my above post correct in ALL circumstances...
Old 11-24-2008, 07:56 PM   #20127
maxepower's Avatar
Default Conversion stick pack parts!
You can buy the parts from the stick pack conversion kit seperately, so you don't have
to spend all the money to buy the whole kit.
The only thing you have to modify is to countersink the holes for the center
post. After that you can fit 5000 lipo pack in the car.
Just my 2$
maxepower is offline   Reply With Quote
Old 11-25-2008, 02:21 AM   #20128
chrisk's Avatar
Trader Rating: 32 (100%+)
I run yeah lipos 3200 and 4000 and they slide under the bump, i have a few little scratches on top of the battery case but really on the sticker on top that was scratched. I just bought one of the lipo trays as well and they helped me with weight and they require not mods at all, they slide the battery out a little away from the bulkgead
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 11-25-2008, 07:46 AM   #20129
I12PonU's Avatar
Trader Rating: 10 (92%+)
part numbers?
I12PonU is offline   Reply With Quote
Old 11-25-2008, 08:44 AM   #20130
94eg!'s Avatar
Here is the link to the two stick pack conversions. If you have an MSX, you nee the parts from the MSX conversion. If you have an MSX-MRE or later, you need the parts from the MSXX conversion (because of the ackerman steering). To find part numbers, just click on the "Parts Listings" button above the photo in the link...
MSX: http://www.tamiyausa.com/product/ite...oduct-id=49385
MSXX: http://www.tamiyausa.com/product/ite...oduct-id=49436
BTW: The bulkhead parts and upper deck alone at $122 cost more than the entire conversion that can be had for $99. And TamiyaUSA is the only place that has them (according to google)...
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
