Old 11-13-2008, 08:43 AM   #20086
tc3team's Avatar
I have some of those blue circular spacers left over from the build of my trf415msxx, can anyone tell me what they are for please?
I suspect they are to be placed over the hex's but im only guessing
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 11-13-2008, 09:08 AM   #20087
I12PonU's Avatar
Trader Rating: 10 (92%+)
which blue circular spacer?Big ones are for spacing the wheels, axle sized ones go between the bearings, and the small ones are for wheel base shims.
I12PonU is offline   Reply With Quote
Old 11-13-2008, 10:57 AM   #20088
Trader Rating: 17 (100%+)
Send a message via Yahoo to Chico
I have a ad in the wanted section. If anybody has an extra TRF415 MSX or MSXX car for sale, PM me or post the car in my ad in the wanted section please.
I also have a buddy who is looking for one also.
Thanks.
Chico is offline   Reply With Quote
Old 11-13-2008, 11:39 AM   #20089
minimusprime's Avatar
Trader Rating: 19 (100%+)
Originally Posted by 94eg! View Post
Yes those are the arms. There is also kit 54083 (about $60-70 on eBay) featuring the 416 uprights, axles, larger wheel bearings and other parts. This is supposed to be a conversion for the TA05, but it should work on any car. I can't comment on what blocks you need. Yes they would have ot be wider ones. You may also have to worry about your axle length with this kit.
you'd def need rear uprights, different axles to get this to work on the 415. these are also the reversible arms. not the short ones. At least it appears that way from the pictures. if you wanted to use the short arms you'd still need the longer toe adjustment blocks to make it work. (read d-e, xd-xe)
"I personally do not believe in luck. I believe luck is just an excuse for people that have failed in their mission to accomplish something." Allen McNish
minimusprime is offline   Reply With Quote
Old 11-13-2008, 12:23 PM   #20090
I12PonU's Avatar
They are short arms. Long arms have 'Y' braces and short arms have 'X' brances. Long rear arms also have little nubs for sway bar mounts. strange how they included everything but the rear knuckles?
Old 11-13-2008, 12:48 PM   #20091
Rozzt_iwa's Avatar
Send a message via MSN to Rozzt_iwa
Default new
i am buying a second hand 415 can any 1 tell me any setup help it will be raced in 540 class on a ashfelt surfece outdoor have been racing with a tt01 i know its a big difference
B5M (17.5),cactus (17.5),sc10 short corse truck (10.5), sakura s zero VTA(21.5),mini-z
www.nbhc.com.au
supporting local hobby shops
http://www.iwawrestling.com.au
Rozzt_iwa is offline   Reply With Quote
Old 11-13-2008, 02:04 PM   #20092
94eg!'s Avatar
I race 27T rubber-tire on a small soda prepped parking lot track with a MSX MRE and have no issues with the standard MRE setup. I do use a front one-way, so that might take some getting used to. A lot of guys recommend the front spool but I've yet to try it. Keep in mind the MRE comes with a locked center shaft...
Of course I don't know how to mess with setup, so take it for what it's worth...
94eg! is offline   Reply With Quote
Old 11-13-2008, 02:16 PM   #20093
i'd start with either a box setup or:
yellow springs all the way around
yellow sway bars
35wt oil
2nd hole on shock support in fornt
3rd hole on shock support in rear.
4.5-5 droop in front, 5.5-6 droop in rear
5mm ride height
sorex 36r's or rp30's
that's where i would start.
Old 11-13-2008, 07:04 PM   #20094
chrisk's Avatar
Trader Rating: 32 (100%+)
Thanks guys will look a little further into it then
Rozzt_ina
your buying scottys car, get his setup sheet of him that he has used for tempe, he has it sorted as setup wise, very similar to what minimusprime has posted anyway
yellows all round, scotty has played with blues up front
he had ran the red sway at the rear, yellow at front
droop the same and ride height the same
one way front and centre
tyres, Tuesday nights 28's ,24's when it is in the middle of winter for 540, thats all we had been running, last Sunday i ran 36's thou as the track temp was pretty high
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 11-14-2008, 01:54 AM   #20095
Hey guys, just bought a 415msx-mre online im super excited!!! hey chrisk, you mention tempe, you mean tempe AZ???
whtltning00 is offline   Reply With Quote
Old 11-14-2008, 02:30 AM   #20096
jase's Avatar
gday all i was pondering to whether i should spend the bucks to get a 416 or get the 2007 Marc R edition 415 what are your views cheers
jase
ALL MY R/C GEAR IS FOR SALE
HB D4 WCE MAMBA MAX
PM ME I MAY HAVE WHAT YOU WANT
jase is offline   Reply With Quote
Old 11-14-2008, 03:14 AM   #20097
chrisk's Avatar
whtltning00
Tempe, Sydney Australia
sorry mate along way from AZ
smaracing.org
Old 11-14-2008, 03:32 AM   #20098
penmark67's Avatar
Trader Rating: 14 (100%+)
Default 416
jase
Hi Jase I have a MRE and a MSXX and are great cars but.........they are just not as good as a XRAY 008 but the 416 WE shits on it big time......
Get the 416 I am
penmark67 is offline   Reply With Quote
Old 11-14-2008, 06:33 AM   #20099
jase
i do pretty well locally with my 415. the only downfall of this car is the 950 wheel bearings. if you stay on top of the car and make sure the drive train is free and there is little to no slop in the suspension/steering. this car will keep up with any of the newer cars.
you might be tempted to get a 416 or new xray. but you're talking about at most .1 second per lap difference. so you're better off saving your money and focusing on your driving imo.
gl
Old 11-14-2008, 01:33 PM   #20100
jase's Avatar
many thanks for the replies i will continue to save
HB D4 WCE MAMBA MAX
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
