Old 10-06-2008, 04:39 PM   #20041
rcfiend's Avatar
Trader Rating: 30 (100%+)
Thanks for the info on the 416 guys. I have one other question. Will parts from the TA05 fit on the 415. I have a bunch of parts left over from my 415, just checking.
rcfiend is offline   Reply With Quote
Old 10-06-2008, 04:57 PM   #20042
94eg!'s Avatar
Trader Rating: 17 (100%+)
I guess some of the parts are interchangeable. It really depends on which TA05 you have. The R model uses the same light-weight reversible suspension as the MSX's (with longer CV shafts), but the standard models do not. I guess some of the bearings, pullies, diff internals, spurs & pinions might change over, but that's really about all...
Of course nice shocks change over, but the 415's always have the nicest shocks available at the time of their release...
You may have to be more specific about the parts in question...
94eg! is offline   Reply With Quote
Old 10-06-2008, 09:21 PM   #20043
chrisk's Avatar
Trader Rating: 32 (100%+)
I think you might be running the wrong suspension blocks on that chassis run the A in the front and 'c' or 'd' in the rear and you should not have that problem
I think you're going to have to change the wheelbase so that the arm clears the bulkhead.
Rear your manual you're supposed to remove material from the arms.
Thanks for the comments guys
Arms as per manual, wheelbase as per manual
May have to find were it says remove material from the arms in the manual.
Thats what i though i would have to do if it was the right setup mod i needed to make the car turn a little more.
Thanks again for the tips
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 10-08-2008, 08:36 PM   #20044
Steveagle's Avatar
Trader Rating: 18 (100%+)
Since my last post a few days ago, the car is running much better. Had to get a Futaba s9551 servo and GTX speedy and the car is running much smoother and faster.
Im looking to get a front one way and a centre one way pulley but im not sure what parts i need to get. If someone can list the parts that i need to buy or point me to the right page in this massive thread, that would be awesome.
I believe some of the parts needed are:
Front one way pulley - 51054
Centre one way pulley - 51061
Anything else?
Tamiya | Spektrum | Tekin | Intellect | ACE
Sydney Model Autosports | www.smaracing.org
Team Awesome: Are you awesome? I am.
Steveagle is offline   Reply With Quote
Old 10-09-2008, 09:04 AM   #20045
94eg!'s Avatar
Anything else?
Here is a link to many manuals:
http://www.tamiya.com/english/rc/manuals.htm
If your car is the MSX MRE (spool & locked center), you'll need the parts found in the MSXX manual. There quite a few different parts to get to build yourself a center one-way, so I just skipped it. My MRE runs great with the front one-way and locked center. You can try that & see if it helps...
BTW: for the front one-way you will need the one-way bearing holder, light-weight one-way drive cups & one-way pulley (with same number of teeth). You should be able to use the screws, bearings & shims from your spool...
Old 10-17-2008, 08:02 AM   #20046
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
Hello Fellow Racers, Is the one-way assembly the same on the 415 MSX and the 415 MRE??
Thanks!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 10-17-2008, 09:21 AM   #20047
94eg!'s Avatar
The MRE's don't include one-ways. So if you want to run one, you have collect the parts from the MSXX (not the MSX). Here's a link to the manuals if you need part numbers:
Old 10-17-2008, 11:25 PM   #20048
berserk's Avatar
Default lipo batteries
I have a question regarding lipo batteries. i am currently using a orion 3200 lipo battery and i am planning to upgrade it with a much more higher maH rating. anyone knows which particular lipo battery with higher mAH rating that will fit the msx? thanks in advance.
berserk is offline   Reply With Quote
Old 10-18-2008, 08:05 AM   #20049
-KilleR-'s Avatar
Trader Rating: 15 (94%+)
You will need to modified your bulkhead to fit in the other higher mah batts. I'm currently using it with Orion 3800 hard case. See attached picture for the modification done on the red circled area.
-KilleR- is offline   Reply With Quote
Old 10-18-2008, 10:29 AM   #20050
edwintklee's Avatar
Trader Rating: 23 (96%+)
bro can have measurement for the red line? so i can machine to lathe to a smooth and flat finish.
thanks for this cool mod....
I am a Red Star, Blue Star, Fans......
edwintklee is offline   Reply With Quote
Old 10-18-2008, 10:42 AM   #20051
kilokhan's Avatar
Can Somebody Kind Enuf to Post 415 Chasis PIC with their LIPO tray??
Will the Tray fit those Height More than 23MM Lipo Batts(RACE PACKS)?
Its kinda hard to find batteries more than 3600MAH above to fit the sexy 415 chassis.
kilokhan is offline   Reply With Quote
Old 10-18-2008, 04:32 PM   #20052
rcfiend's Avatar
Hey guys I have a few more questions. I picked up a used 415 MSX and it came with the following arms and rear carriers. Can anyone tell me what they are and what there intended purpose is (ex. when would you use this combination or does anyone still use them)
Old 10-18-2008, 04:38 PM   #20053
rcfiend's Avatar
Also can anyone tell me if the following TA05 parts will fit the 415 MSX.
- 46mm Universal Shafts
- Front Shoct Tower
- Rear Shock Tower
- FR & RR Swaybars
- TA04 Suspension Arms
- High Precision Diff halves
- Front One-Way
- 414 4 Degrees C-Hub Carrier
Thx in advance guys. I'm just getting back into the hobby and thought I would give th 415 a spin at the Tamiya track in Cali.
Old 10-18-2008, 04:59 PM   #20054
- 46mm Universal Shafts-no
- Front Shoct Tower-no
- Rear Shock Tower-no
- FR & RR Swaybars-yes
- TA04 Suspension Arms-yes, but with the rest of ta04 suspension
- High Precision Diff halves-no
- Front One-Way-no
- 414 4 Degrees C-Hub Carrier-with ta04 arms only.
slomo is offline   Reply With Quote
Old 10-18-2008, 06:53 PM   #20055
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
That's the David Jun Rear suspension kit. I don't think anyone uses that anymore cause no one could figure out how it works.
Racing4Evo is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
