Old 08-10-2008, 02:38 AM   #19966
barts71m's Avatar
Trader Rating: 34 (100%+)
thanks for the tips ppl, rebuilt my car as per box instructions and did some mods as per thard's site, lowered steering rack etc etc and the car ran flawlessly and drove better than ever. Seemed to be a little too stuck though didnt have to lift anywhere. Also the first time ive ran brand new tires on the tourer. Did some little mods for the final but we got rained out before I got a chance to run em.
Smokem Racing, KBI Factory Team, Need some speed get some EAD, Contra Industries
barts71m is offline   Reply With Quote
Old 08-10-2008, 02:41 AM   #19967
chrisk's Avatar
Trader Rating: 32 (100%+)
i also have the MRE steering in the car and will try the suggestions. i definately need to rebuild the shocks and try that
cheers for the help
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 08-12-2008, 03:18 AM   #19968
black4G93's Avatar
Send a message via MSN to black4G93 Send a message via Yahoo to black4G93 Send a message via Skype™ to black4G93
Hi guys, may I know what is the best combination spur gear and pinion gear for Yokomo SPN 19t and Yokomo Tmax 23t motors sit on TRF415 MRE to run in medium track? As I know the internal gear ratio is 2.25. Thanks in advance.
Greetings Jonathan
RCmania Hobby Shop - Queensbay Mall Penang (2F-11)
012-4532160 (Jonathan)
black4G93 is offline   Reply With Quote
Old 08-12-2008, 05:04 PM   #19969
ckoetsch's Avatar
Trader Rating: 18 (100%+)
is the trf415 better than the t2 008?
Sick Graphics - KYOSHO RB6.6 - "If you ain't first you're last" R. Bobby
NW Hobbies of Albany and Dave's RC Tracks of Hubbard.
ckoetsch is offline   Reply With Quote
Old 08-12-2008, 06:51 PM   #19970
vr6cj's Avatar
Trader Rating: 124 (100%+)
The word on the street around our neighborhood is that alot poeple a going back to the 415 cause they can get it to work better then the 416 at this point in time. Any thoughts on that?
vr6cj is offline   Reply With Quote
Old 08-12-2008, 08:43 PM   #19971
HELP! I can't seem to find the screws to mount my motor with..anyone know which screws or even the part# that corresponds to them? did they have washers as well??? thanks!!
one*eighteen is offline   Reply With Quote
Old 08-12-2008, 09:41 PM   #19972
vr6cj's Avatar
Instructions say 3x8mm button heads. 3x.05mm washer. Screw bag b #9464089 or 10 3x8mm screws #9805765. It's a 2mm allen and I dont use the washers.
Edited. Stated 2mm at first but realized that was the wrench size. lol
Old 08-12-2008, 10:10 PM   #19973
mild seven's Avatar
Trader Rating: 63 (100%+)
Send a message via MSN to mild seven
I just finished building my 415 MRE and i have to say it was a good kit to build. very happy with the quality. I cant wait to give it a run next week. I wrote up a building review, it will be up on my website on www.ttrc.com.au shortly.
mild seven is offline   Reply With Quote
Old 08-13-2008, 02:44 AM   #19974
habis's Avatar
....Let it remain on the street.
the 416 is a killer car - the fastest around at the moment. just look at the results.
habis is offline   Reply With Quote
Old 08-13-2008, 11:17 AM   #19975
thanks!! but no washers?
Old 08-14-2008, 06:07 PM   #19976
Burlap's Avatar
Send a message via MSN to Burlap
Get this for all your spacer needs!
http://www.tamiyausa.com/product/ite...oduct-id=53539
Infact I need to get another packet of those, all my thin spacers keep getting nicked by friends.
Burlap is offline   Reply With Quote
Old 08-16-2008, 02:20 PM   #19977
skier444's Avatar
Send a message via ICQ to skier444
Post front spool
I'm looking for a front spool (solid axle) for my TRF 415 MSXX and found just #53877. Does it fit 415 MSXX ? If not, can anyone recommend any other ordering number for MSXX ?
TRF 415 MSXX, Moped, Orion, 3PK
skier444 is offline   Reply With Quote
Old 08-17-2008, 02:51 AM   #19978
Blueman Austria's Avatar
No! The TA05 spool set will not fit your MSXX.
You have to get the following items:
3454401 TRF415 front spool
9804268 TRF415 Delrin spool outdrives
9804267 TRF415 Aluminium spool sleeves
You can also use the steel outdrives from the ta05 spool instead of the delrin ones.
From Jaad Racing is a complete spool set available.
www.jaadracing.com
This is a complete set, and you can also use the delrin 415 outdrives with it.
Greetz Blueman
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 08-17-2008, 03:10 AM   #19979
barts71m's Avatar
Originally Posted by Blueman Austria View Post
Yes t the 415 blocks from XA-XD are flipable with no issue.
I have attached a pic of the "manual" wich is included in the suspension mounts XA-XD. There you can see wich spacer should be mounted.
Greetings Blueman
I tried this with an XA over the weekend but it bound my chassis up so much my arms wouldnt drop down....any suggestions???
Old 08-17-2008, 03:58 AM   #19980
ShadowAu's Avatar
I've had my 415 for some times now... its started life as an MS but has been updated to an MSX with some MRE parts thrown in for good measure...
I am having serious problems with lack of rear grip... My setup is not that far removed from most I have seen online with the exception of no sway bars or a front sway bar only... I run a spool with fixed center... I mainly run 10.5/19T and 5 cell modified... I run on a fairly changeable car park track with low-ish to medium grip
Nothing I seem to do can make the car grip in the rear... its almost like the rear end "floats" on top of the track surface instead of biting in
Does anyone have any setups etc that feature very high rear grip?
I am quite content with doing what I do
Don't mistake not being happy for unhappiness - its not the same thing
ShadowAu is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
