Old 07-03-2008, 08:44 PM   #19891
barts71m's Avatar
Trader Rating: 34 (100%+)
Originally Posted by -KilleR- View Post
This is how TAM49383 look like. It will fit both TA05 with rev. sus. arms and 415.
picking up a set of TA05 bars on sunday. Had 1 hanging around when I got the car. Fits in there with a little tweaking. Thanks for the tips.
cheers
scott
Smokem Racing, KBI Factory Team, Need some speed get some EAD, Contra Industries
barts71m is offline   Reply With Quote
Old 07-04-2008, 02:23 AM   #19892
-KilleR-'s Avatar
Trader Rating: 15 (94%+)
Thanks for sharing guys. Appreciate it.
Originally Posted by Grizzbob View Post
It really depends on the pack you want to use, I put up pics of the SMC 5000 hardcase pack in both my 415MSX(I believe it's either in this thread or in the SMC thread for their hardcased packs) & my 416. I don't remember just how far back you'll need to look, but I do remember that I had to cut away a LOT of the rear bulkhead to get it to fit the 415, including chopping that T-post(for lack of the proper term, it's where the top chassis plate mounts in the rear, & it's connected to the motor plate) in half. Just look back aways(maybe to sometime around early April) & you should find the pics....
Originally Posted by Kregger View Post
I know that with the SMC 4000 I can fit the battery in without any bulkhead grinding. If I remember the next time I go racing I'll take some pics. I believe I squeezed an orion 3200 pack in the car as well.
Originally Posted by Burlap View Post
TrackPower 3200 LiPos fit in the normal 415MS/MSX/MRE/MSXX chassis without modification as well.
-KilleR- is offline   Reply With Quote
Old 07-07-2008, 10:10 AM   #19893
Trader Rating: 32 (100%+)
Default NEW 415 MRE $250
selling a brand new unassemble 415 MRE in for sale thread, missing screw bag C. $250 + actual shipping.
http://www.rctech.net/forum/showthread.php?t=230325
joech is offline   Reply With Quote
Old 07-07-2008, 06:03 PM   #19894
Send a message via MSN to supra0707
Default advice me
hi, want to check with you guys about the arms of the car....is it suppose to move back & forth? notice that the front & rear right arm move bout 2mm if i deliberately moved it. the arms i am referring to is the lower / suspension arms. thanks.
supra0707 is offline   Reply With Quote
Old 07-07-2008, 11:22 PM   #19895
Burlap's Avatar
Send a message via MSN to Burlap
Sounds like either the toeblocks are loose or you have bent one of them. There shouldn't really be any forwards/backwards slop in them.
Burlap is offline   Reply With Quote
Old 07-08-2008, 07:54 AM   #19896
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
you do have all the required spacers on the suspension shaft? ive seen a few ask the same question before, and found that when they changed a suspension block, they forgot to put the small spacers back on.
axle182 is offline   Reply With Quote
Old 07-08-2008, 04:39 PM   #19897
barts71m's Avatar
Cause the search function is messed up on this post does anyone remember if the TA04 front spool goes into a 415?
cheers
scott
Old 07-08-2008, 06:19 PM   #19898
Burlap's Avatar
cheers
scott
The TA04 shouldn't be able to fit, if I am right in saying, due to the pulley being offset on the TA04, whereas on the 415 it is right in the centre
Old 07-09-2008, 06:25 AM   #19899
barts71m's Avatar
Bugga....um any ideas on what might fit.
Old 07-09-2008, 06:44 AM   #19900
-KilleR-'s Avatar
The original 415 spool.
Old 07-10-2008, 06:24 AM   #19901
Trader Rating: 22 (100%+)
Hey all what Spur Pinion combo is everyone running with 17.5? To get to a 3.6-3.8 it looks like a 80 spur 50 pionion for 3.6. Will that even fit or is there a better solution? Has anyone tested or played with spur combos that get better results as far as better acceleration with a larger or smaller pinion? I know with my stock motors we went largest spur, smallest pinion, but with the different torque curve on a brushless does it have the same effects or can it pull a larger pinion?
-j
Speed Passion U.S.A. - Turtlemaster Racing
www.speedpasion.net
Anemic_SluG is offline   Reply With Quote
Old 07-10-2008, 07:50 AM   #19902
barts71m's Avatar
that would be awesome but I cant find one anywhere and it didnt come with the car I bought. Did find a nice JAAD Racing unit has anyone used one of these?
Old 07-10-2008, 08:04 AM   #19903
TryHard's Avatar
the JAAD spool is good, it has steel outdrives so doesn't break easily. It uses a diff pulley instead of a spool one though. Overall, highly recomended.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 07-11-2008, 10:34 AM   #19904
Tpg racer's Avatar
Can anyone tell me the timeline of the TRF 415 from the original TRF 415 to the latest version of 415.......specify all the models of 415 that came out....
Also is it still worth getting the 415 considering the 416 is already out??? The fear of being phase out is there....
Thnx in advance guys...
Tpg racer is offline   Reply With Quote
Old 07-11-2008, 12:25 PM   #19905
TryHard's Avatar
http://www.thard.co.uk/415/415info.html
The 415 didn't stop being a good car since the 416 came out, it's just the 416 has moved the game on a bit. The 415 is still a very capable car, and easily good enough to win races
HiH
Ed
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
