Old 07-01-2008, 07:44 AM   #19876
barts71m's Avatar
Trader Rating: 34 (100%+)
Originally Posted by DRAG_ON View Post
you bought it 2nd hand or brand new, i never striped front hub before -- just never over tighten the screw mate..............here i included site from tamiya
http://www.tamiyausa.com/pdf/manuals/49381ml.pdf you can search the parts number there i can remember which number for the hub either
Thanks...found them coming loose after each run. So only tightened them hard enuff that it didnt bind the front hub up. Wouldnt call it over tightened.
Bought it 2nd hand....bit of a toe in the water to c if I liked the racing thing.
Smokem Racing, KBI Factory Team, Need some speed get some EAD, Contra Industries
barts71m is offline   Reply With Quote
Old 07-03-2008, 01:53 AM   #19877
TryHard's Avatar
Originally Posted by barts71m View Post
I know its probably on here somewhere but the search function is having a spaz at me.
Just bought a 2nd hand 415 to start racing with, ran my first praccy 2nite and I seemed to have stripped a front hub. Is this the replacement part number #53579???
Also what sway bar kit works on the front of the car???? can find the rear bar kit but cant see the front 1...base model TRF 415.
TIA
Scott
TAM53842 (standard colours)
OR TAM49383 (Black coloured)
OR TAM49414 (Milky Blue)
One of thoose three should be fine for the roll bars. Each set includes 6 bars (3 front, 3 rear), in soft, med and hard rating.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 07-03-2008, 02:04 AM   #19878
barts71m's Avatar
HiH
Ed
Thanks Ed...i have the TA05 set already TAM #53842) the rear set works fine but the front is a different shape. It squares off in the corners picture attached. Only bar I can c that does similar is the TA04 bars. I think ive found the fronts and rear on ebay for a decent price.
Old 07-03-2008, 04:20 AM   #19879
TryHard's Avatar
I think you can get the non-bent bars to work with the original suspension (as I assume thats what you have on the car), as the end of the bars meet in the same place (as there is a greater angle on the 05 bars, than the 2 bend 414 ones). But in all honesty, it's been so long since I had an original 415, I can't remember! I do remember them being a pain to mount though, with the screw through the arm
IIRC, the MS (which was the first 415 to use the LWT reversable arms) came with the TA05 version bars.
HiH
Ed
Old 07-03-2008, 05:35 AM   #19880
barts71m's Avatar
HiH
Ed
yep std arms std 415...ill c how I go with that.
cheers
scott
Old 07-03-2008, 01:31 PM   #19881
-KilleR-'s Avatar
Trader Rating: 15 (94%+)
This is how TAM49383 look like. It will fit both TA05 with rev. sus. arms and 415.
-KilleR- is offline   Reply With Quote
Old 07-03-2008, 01:33 PM   #19882
-KilleR-'s Avatar
Do anyone have a picture of 415msx or msxx fitted with lipo?
ie. TrakPower, SMC, Team Orion & etc.
How much you need to grind off the bulkhead?
Saw those with Peak 3200 or RCM3300 few pages back.
Please share them. Thanks.
Old 07-03-2008, 02:00 PM   #19883
TryHard's Avatar
Bugger that, grind the battery!
Tamiya TRF415-dscf0047.jpg   Tamiya TRF415-dscf0049.jpg   Tamiya TRF415-dscf0048.jpg
Old 07-03-2008, 02:24 PM   #19884
-KilleR-'s Avatar
Kewl
Keep em coming.
Old 07-03-2008, 02:49 PM   #19885
94eg!'s Avatar
Trader Rating: 17 (100%+)
Hey Tryhard, I have a quick question about setup...
Can you possibly point me in the right direction of where to start off droop settings? I measure with a standard gauge that looks just like the Tamiya one shown here (from the bottom of the chassis up to the bottom of the upright):
I race the MSX-MRE and it's completely kit spec right now. We run on a tiny asphalt track with one-ways, -1.5* camber, and ride height is about 5.5mm. The car has some toe-out in the front but I have no way of measuring it.
94eg! is offline   Reply With Quote
Old 07-03-2008, 03:18 PM   #19886
TryHard's Avatar
On that gauge, go 5 under the front outer hinge pins, 4 under the rear. Think I only ever changed from thoose settings twice whilst running the car!
HiH
Ed
Old 07-03-2008, 05:08 PM   #19887
94eg!'s Avatar
Thanks man. I'll set it up as such. Actually my Kyosho tool measures in half millimeter steps if it makes any difference...
BTW: It makes much more sense to measure to the bottom of the hinge pins as that would be a much more consistent reading with various camber settings...
Old 07-03-2008, 06:01 PM   #19888
Super Moderator
Grizzbob's Avatar
It really depends on the pack you want to use, I put up pics of the SMC 5000 hardcase pack in both my 415MSX(I believe it's either in this thread or in the SMC thread for their hardcased packs) & my 416. I don't remember just how far back you'll need to look, but I do remember that I had to cut away a LOT of the rear bulkhead to get it to fit the 415, including chopping that T-post(for lack of the proper term, it's where the top chassis plate mounts in the rear, & it's connected to the motor plate) in half. Just look back aways(maybe to sometime around early April) & you should find the pics....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 07-03-2008, 06:16 PM   #19889
Kregger's Avatar
I know that with the SMC 4000 I can fit the battery in without any bulkhead grinding. If I remember the next time I go racing I'll take some pics. I believe I squeezed an orion 3200 pack in the car as well.
Kregger is offline   Reply With Quote
Old 07-03-2008, 06:24 PM   #19890
Burlap's Avatar
Send a message via MSN to Burlap
TrackPower 3200 LiPos fit in the normal 415MS/MSX/MRE/MSXX chassis without modification as well.
Burlap is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
