Old 06-17-2008, 01:25 PM   #19861
94eg!'s Avatar
Trader Rating: 17 (100%+)
Figured I would put up this pic while it's still on the same page as my others. Might help someone who needs to install a VFS-1 ESC...
94eg! is offline   Reply With Quote
Old 06-17-2008, 05:37 PM   #19862
Burlap's Avatar
Send a message via MSN to Burlap
Nice and tidy, I kept the motor wires on my KO relatively long, to give it some slack and easier for me to solder
Burlap is offline   Reply With Quote
Old 06-23-2008, 07:05 AM   #19863
Send a message via MSN to supra0707
Smile new to trf415
[QUOTE=habis;4538457]the spool is available EVERYWHERE........you just have to buy it in parts and put it together...
hi, just got a TRF415 MSX MRE. it has a front one way spool. both front left & right wheels spinned at the same direction when i turned it. it seems that its locked for 1 direction only. is it alright to have that? use to drive TT01D. found that the TRF415 is a lot better to drive now.
what's the different between Ball Diff & Front One Way? hope you guys who's more expert than myself to give me some advice. thanks.
supra0707 is offline   Reply With Quote
Old 06-23-2008, 09:01 AM   #19864
94eg!'s Avatar
What you have is a front one-way. A spool is locked in both directions. A front diff would be exactly the same as the rear diff. Each has very different effects on the car while driving, and should be used under different racing circumstances.
I suggest you stick with what you've got, and see if it works for you. But if nobody else is running a front one-way at your track, chances are you shouldn't either...
Old 06-23-2008, 09:37 AM   #19865
sounds like he may have center one way and front spool?
slomo is offline   Reply With Quote
Old 06-23-2008, 09:47 AM   #19866
hi guys,
i decided to buy trf 415 msx mre, my problem is a little about where to buy it.
i searched, posted in the for sale threads, no luck for 2 weeks.
trf 416 is kind of expensive (as i will be needed many spare parts for it), in the online stores i couldn't find 415 , (in one place i found it the price was only 30 usd below the 416)
where do you think i could get the best price for 415?
any second hand with the spares will be lovely.
thanks for the replies
khaledome is offline   Reply With Quote
Old 06-24-2008, 06:44 AM   #19867
Default thanks
thank you for the info. anyway, my trf415 comes with rear ball diff. need to really test it on the track. do you think a front ball diff is better?
Old 06-24-2008, 09:05 AM   #19868
94eg!'s Avatar
...do you think a front ball diff is better?
It simply depends on where your racing. Our tiny parking lot track pretty much necessitates a front one-way to get through all the low-speed turns quickly.
If you can't keep up with the others that are using a ball-diff, THEN you should think about ordering one. Otherwise, save your money for tires...
Old 06-24-2008, 10:54 AM   #19869
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Parts Needed -
Hi gents, after selling my MSX and my MRE, i found my old original 415 chassis parts. Im puting it back together with the leftover parts i had. Im missing one diff bearing and adjuster (the diff bearing holder which you use to adjust the belt tension) i also need a full set of the suspension arm shaft ball ends (what a mouthfull) the part that goes into the suspension mounts. If anyone has these small parts, please let me know, paypal waiting etc. I *think* i have all the other parts required. Im looking forward to seeing what the old girl has left in her!
Cheers!
axle182 is offline   Reply With Quote
Old 06-24-2008, 06:07 PM   #19870
Burlap's Avatar
With the 415, unless it is carpet, you usually use the one way for higher turn motors, and use the spool for mod motors.
Old 06-24-2008, 06:10 PM   #19871
94eg!'s Avatar
Originally Posted by Burlap View Post
With the 415, unless it is carpet, you usually use the one way for lower turn motors, and use the spool for mod motors.
You may want to re-type that. It doesn't make sense. Low turn motors are Mod motors..
Old 06-25-2008, 12:00 AM   #19872
Burlap's Avatar
Ah, me brain gud
Old 06-25-2008, 02:43 PM   #19873
Toughbeard's Avatar
thats the way to do it only the switch is at a dangerous place...
Toughbeard is offline   Reply With Quote
Old 07-01-2008, 07:18 AM   #19874
barts71m's Avatar
Trader Rating: 34 (100%+)
I know its probably on here somewhere but the search function is having a spaz at me.
Just bought a 2nd hand 415 to start racing with, ran my first praccy 2nite and I seemed to have stripped a front hub. Is this the replacement part number #53579???
Also what sway bar kit works on the front of the car???? can find the rear bar kit but cant see the front 1...base model TRF 415.
TIA
Scott
Smokem Racing, KBI Factory Team, Need some speed get some EAD, Contra Industries
barts71m is offline   Reply With Quote
Old 07-01-2008, 07:28 AM   #19875
DRAG_ON's Avatar
TIA
Scott
you bought it 2nd hand or brand new, i never striped front hub before -- just never over tighten the screw mate..............here i included site from tamiya
http://www.tamiyausa.com/pdf/manuals/49381ml.pdf you can search the parts number there i can't remember which number for the hub either
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
