Old 05-06-2008, 12:40 AM   #19741
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
Originally Posted by HUCKMAN View Post
I have a problem with my TRF415. When I turn hard to the left and mash the throttle my car wants to do doughnuts, but when I turn hard to the right and mash the throttle the car just sticks and doesn't want to do doughnuts. I've checked my steering endpoints and they're both equal. I even tryed dialing out my steering to an EPA of 60% for the left side and it still happens. My droop is set perfectly, my shocks are all the same length. I'm puzzled about what is causing this. Can anyone give me some advice as to what things I can look into to see what my problem is. I'm running a front spool and it even did the same thing when I had a diff up front. Thanks for the help.
Huck
look for a bent hidgepin or something, check your toeblocks are sitting right and make sure theres nothing binding....
Castle Hill Raceway
surrealmaterial is offline   Reply With Quote
Old 05-06-2008, 01:37 AM   #19742
A bent hingepin? That would be the pins that hold the a arms to the toeblocks right? Now that you mention it I did notice that I had a pin that was bent slightly but I thought nothing of it. I suppose this would cause my suspension to hang up at times and cause my a arms not to actuate correctly. Hm... This make sense. Thanks surrealmaterial for the help. You kick ass! I'll post my findings.
HUCKMAN is offline   Reply With Quote
Old 05-06-2008, 02:18 AM   #19743
Hey guys I seem to keep lossing my screw and flang in one of my c hubs in the front. is there a trick to this or what. Oh I'm running a Msx MRE.
Also I can't seem to bring my rear ride height lower than 6mm. trying to get 5.5. just not working. I will double check my shocks. later today.
thanks in advance.
cyrrus is offline   Reply With Quote
Old 05-06-2008, 03:01 AM   #19744
thanks in advance.
I had the same problem with losing my screw and bushing in the bottom of my c hub. This usually means that you c hubs have taken a beating and are on their last leg. At least that was my experience. To get the screw to stay in without coming out wrap the end of the screw with teflon tape about 1/8 inch wide. Install screw and do not overtighten. This worked for me while I was waiting for new c hubs to come in the mail. About the ride heighth...Check your shock lengths. The shock end cup shouldn't be showing any threads. Also, make sure you shocks are all the same length with some calipers.
Old 05-06-2008, 03:04 AM   #19745
TryHard's Avatar
Also, don't use a titanium screw. Just use a black steel screw. I always found that the Ti ones seemed to back out, and strip the threads easier. However, the black steel ones seem to grip the plastic betterm and don't back out.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 05-06-2008, 04:54 AM   #19746
tc3team's Avatar
Ive had first hand experience of a bent hingepin, in short it binds up the wishbone so it wont pivot freely. If you're lucky you can get a hammer to it to flatten it out if you're short of parts, if not get it replaced
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 05-06-2008, 11:30 AM   #19747
pug 205 gti's Avatar
Originally Posted by mac853 View Post
Could somebody tell me what kind of belt drive if i wonder put my 415 with 37/18T diff/center pulleys?
How about if try Cyclone long and Xray short belts, as i believe is too much tight, isn't it?
Best regards
Hi mac
Maybe you should try a TRF416 front belt they are longer than the TRF415 front belts.
Its quietish on rctech lately?
pug 205 gti is offline   Reply With Quote
Old 05-06-2008, 06:45 PM   #19748
mac853's Avatar
Originally Posted by pug 205 gti View Post
Hi mac
How about their lenghts of trf416 compare of Cyclone ones which is 510mm?
And i wish to try Xray foam spec rear belt, is 186mm, worth it?
Or maybe Cyclone rear belt with 189mm?
mac853 is offline   Reply With Quote
Old 05-07-2008, 12:01 AM   #19749
yep thats it.....and no problems, glad to help out
Castle Hill Raceway
Old 05-07-2008, 12:50 AM   #19750
I had a front left hinge pin that was bent and a front rear toe block that was bent about .050 on the left side. This explains why I was spinning out on left turns only.
Thanks for your help surrealmaterial!!!! I guess the carpet season on a short track took its toll on my car. I've learned alot! Thanks to all!
Huck
Old 05-07-2008, 12:40 PM   #19751
Blueman Austria's Avatar
Hy there!
Yust a quick question.
Does the TA05 Stabilizer Set fit the 415 MSXX MRE 07 front and rear?
Greetings Blueman
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 05-07-2008, 01:10 PM   #19752
Toughbeard's Avatar
For the loose ti screw I use Loctite 642. It works like a charm and never over tighten screws in plastic. Sometimes a small amount of silicone works perfectly as well.
Last weekend we went to the first race of the season. Unfortunately it got cancelled on teh second day due to heavy rain. So I tried to seal as best as I can in a short time and try to run the car so People can see that these things can actually run fast in rain as well. It is a short movie and the box I made leaked so I got cut out about in 2 mins...
Enjoy...
Rain Run
Toughbeard is offline   Reply With Quote
Old 05-07-2008, 02:28 PM   #19753
tc3team's Avatar
Originally Posted by Blueman Austria View Post
Hy there!
Greetings Blueman
ive been told the ta05 set fits the trf415msxx, so I dont see any reason why it wouldnt fit the mre too, its just the next model up with a few more alloy parts and a slightly different chassis
Old 05-07-2008, 02:29 PM   #19754
TryHard's Avatar
Hy there!
Greetings Blueman
Old 05-07-2008, 02:35 PM   #19755
Toughbeard's Avatar
Hy there!
Greetings Blueman
I use it on my 415 MSX MRE so you can use it on your 415 MSXX MRE 07....
Damn... now try to read that 3 times in a row real fast
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
