Old 04-24-2008, 04:57 PM   #19711
badboy's Avatar
Trader Rating: 14 (100%+)
Default Internal Gear Ratio
Hi! What are the internal gear ratio of the following:
TRF 415
TRF 415 MS
TRF 415 MSX
TRF 415 MSX MRE
TRF 415 MSXX
TRF 415 MSXX MRE
TRF 416
badboy is offline   Reply With Quote
Old 04-24-2008, 05:28 PM   #19712
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
Originally Posted by pug 205 gti View Post
what vw have you got?
I had about 10 VW's in my lifetime, so far. The last one was a VR6 Jetta that was very fast with some mild mods to wake up the output.
........Now I have a family and I drive a ford with plenty of trunk space for my RC Gear........ Oh well!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 04-24-2008, 05:40 PM   #19713
TryHard's Avatar
TRF 415
TRF 415 MS
TRF 415 MSX
TRF 415 MSX MRE
TRF 415 MSXX
TRF 415 MSXX MRE
TRF 416
TRF415, MS, MSX - 2.188 (35/16)
MSX MRE, MSXX, MSXX MRE - 2.250 (36/16)
Although if modded to use the 18t pulleys, it gives 2.000 (36/18)
TRF416 - 2.056 (37/18)
HiH
Ed
| THard.co.uk | Xray | MuchMore |
TryHard is online now   Reply With Quote
Old 04-24-2008, 05:43 PM   #19714
TryHard's Avatar
Originally Posted by Kwikvdub View Post
Hello, Is there a difference between a D block and a 1D block??...... Just wondering?
Thanks!
Nothing in width, but 1mm in height (D stands 1mm taller than 1D).
HiH
Ed
Old 04-24-2008, 06:27 PM   #19715
TRF 415
TRF 415 MS
TRF 415 MSX
TRF 415 MSX MRE
TRF 415 MSXX
TRF 415 MSXX MRE
TRF 416
badboy
at the moment my 415msx is running 35/18 roll out 1.94 using a S400 rear gear diff and is awsume
steven
Casino Kid is offline   Reply With Quote
Old 04-25-2008, 03:12 AM   #19716
zenithrr's Avatar
Originally Posted by TRF415boy View Post
If you had asked we would have told you right from the start to put your pack at the front...
fun to try out new thing.
I just wonder why the porsche 911(rear engine car) has mostly a 40/60 to even a 32/68 weight distribution, yet they still perform so blancened at the track ???
maybe if I can get some 32mm or even 34mm tire. then I can put more weight to the rear to try out somemore thingz.
TA05MS, F201, F103GT, RS4 Mini, TopForce (original), Mini Inferno, **Tamiya BMT 931 K4** "I am a new soul, welcome to the new world, so proud to joint the TEAM MORON. lalalala" We love Onions products, so touching. COL - cry out loud
zenithrr is offline   Reply With Quote
Old 04-25-2008, 03:21 AM   #19717
TRF415boy's Avatar
Porsche aren't quite easy to drive, they tend to lose the back end and you need to be a good driver to be able to push them.
As I said, just leave it at the front or you'll suffer from the pendulum effect.
TRF415boy is offline   Reply With Quote
Old 04-25-2008, 05:06 AM   #19718
tc3team's Avatar
As we all know, car setup is all very much an individual thing, what works for one doesnt work for you. Hence why I dont look at team driver setups for all my inspiration when looking to get the most from the car.
A couple of large sweeping corners in a lower grip situation may be good for a pendulum style setup on weight transfer to the back end, but!
a) it might not suit your own driving style
b) it might not suit the other corners you need to get round on that same said track.
That said, the 415 with its motor position layout does already put some of your overall electronics weight to the rear of the car, with the motor in the place it is.
All I would say is, try it but dont expect it to help you in all the corners, it is quite an art to race a car well with a lot of rear weight and to get right consistantly. It would probably work better with higher powered motors where you have more power to throw the car about.
If anything, a 4 wheel drift setup might feel a little more settled and allow better cornering if you are into the art of getting a car around with some degree of wanting the car to do the work more than choosing the right line with a more traditional setup where the back end sticks more
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 04-25-2008, 05:51 AM   #19719
Originally Posted by Casino Kid View Post
badboy
steven
Hey Steven
Did you try that geardiff outdoor?
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini M03 - Tamiya 415MSX MRE - Tamiya 416 WE
Cruisaaja is offline   Reply With Quote
Old 04-25-2008, 11:05 AM   #19720
JayL's Avatar
911 is rear Wheel Drive, weight=traction
JayL is offline   Reply With Quote
Old 04-25-2008, 01:31 PM   #19721
Originally Posted by Cruisaaja View Post
Hey Steven
yes (run on a tennis court asphalt)and i find it to be an excellent addition to the 415msx , only had an old 540 motor in as the track was rather small and just setting up after the rebuild.
Also run my SMC 4000 lipos to see how long i would get out of the pack (30min) no worries then the rain came down.
will be running ata track up the coast next weekend with a orion 10.5 so will see how every thing goes.
Run it without any shim , the rear belt seems to be ok no chafing.
Looking forward to putting the MM 4600 and 7700 in for a squirt.
Steven
Old 04-25-2008, 04:20 PM   #19722
TryHard's Avatar
Hey all,
Well, I've made some changes to my website, mainly turning it over too the TRF416. If you want to find the TRF415 pages, they are still there, just need to head over here now and follow the link... http://www.thard.co.uk/viewforum.php?f=7
I've kept the Setups, tips and tricks and info pages, everything else can be found elsewhere in the forum.
Cheers
Ed
Old 04-26-2008, 06:53 AM   #19723
i have been told that from msx to msxx mre all the front and read diff/spool/oneway width are the same, just that the pullies are different. is it true?
Molala3 is offline   Reply With Quote
Old 04-26-2008, 08:47 AM   #19724
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
No entirely, the spool and one ways are the same width but the screw locations are different from the MSX to the MRE but the same from the MRE to the MSXX. I had problems trying to fit the 36 front pulley on an MSX spool.
Racing4Evo is offline   Reply With Quote
Old 04-29-2008, 01:53 PM   #19725
pug 205 gti's Avatar
hi
Does anybody know if a body of a trf415 will fit straight on to a trf415 msx mre chassis. thanks
Its quietish on rctech lately?
pug 205 gti is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
