Old 04-17-2008, 04:59 AM   #19666
Originally Posted by Cruisaaja View Post
Next i`ll try old Tamiya 415 belts and 16th middlepulleys, so IR is then 2.18
Front belt #51062 and rear #51063 if they fit better.
I`ll tell you later how it goes..
Steven here
mine has been installed in my 415msx no changing of belts already run an 18 centre ,just had to change the front pully (maybe a mm shim but i think it will be fine) running this sunday. Internal ratio is 1.94
Casino Kid is offline   Reply With Quote
Old 04-17-2008, 05:05 AM   #19667
skier444's Avatar
Send a message via ICQ to skier444
Thank you Steven; I believe the same .. but ... Is there anyone who can check it or know it for sure?
The REAR DAMPER STAY for "TRF 415 MS" is #51191
The REAR DAMPER STAY for "TRF 415 MSXX" is #4305555
Not all the parts are interchangeble -> have a few at home already
TRF 415 MSXX, Moped, Orion, 3PK
skier444 is offline   Reply With Quote
Old 04-17-2008, 05:37 AM   #19668
DRAG_ON's Avatar
Default 415 MSX EXTERNAL diff adjustment
Yes you can adjust your 415 MSX rear differential externally..............here are some step of a little modification you need:
step: 1
First you need to disable your rear differential
step: 2
You need to dremel the bolts so that 1.5mm hex can fit into the bolts
step:3
make sure you dremel enough so that 1.5mm hex can fit in
step:4
You need to reassemble the diff i already attached the picture, this is different from the manual instruction
step:5
step:6
Inset hex key 1.5mm hold it and grab the rear right wheel clockwise to tighten the rear diff and counter clock wise to loosen the diff
step:7
Enjoy your external diff adjustmet 416 style
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
Old 04-17-2008, 05:41 AM   #19669
zenithrr's Avatar
Originally Posted by Tremor24 View Post
Hey dialed 415 guys, I'm running an MSX, I have a question about how to get more mid corner off power steering, I'm running a spool and I either have to hit the brakes or give it more throttle, which is not ideal enough for the sharper turns, to get it to steer enough, I'm running on asphault, also this is with a Stratus 3.0 body, would a Mazda 6 give me more mid speed steering, thx.
Originally Posted by Racing4Evo View Post
Yes, change bodies. Try the Mazdaspeed 6 with the wing cut down and mounted as far back as possible. Also lowering the inner rear camber link will help too.
also you can try:
1. add a bit postive toe in on the rear. such as -3 to -2 degree
2. use the 2 degree castor c-hub instead of the 4 degree.
3. the last thing you want to do is, to change to harder spring on the rear, or change to softer spring on the front.
TA05MS, F201, F103GT, RS4 Mini, TopForce (original), Mini Inferno, **Tamiya BMT 931 K4** "I am a new soul, welcome to the new world, so proud to joint the TEAM MORON. lalalala" We love Onions products, so touching. COL - cry out loud
zenithrr is offline   Reply With Quote
Old 04-17-2008, 11:09 AM   #19670
Drag-on. Good to see at this can make externally now for 415
Now it`s much easier to do it
Thanks to share that
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini M03 - Tamiya 415MSX MRE - Tamiya 416 WE
Cruisaaja is offline   Reply With Quote
Old 04-17-2008, 11:21 AM   #19671
Originally Posted by Casino Kid View Post
Steven here
Steven. You drive MRE wright?
I chance those Tamiya belts like i mentioned earlier and they are much better fit than those other belts.
Also i put 16t middlepulleys back and IR is now 2.18 and that`s the way i`ll use it next time when i go outdoor racing
Old 04-17-2008, 03:22 PM   #19672
Tremor24's Avatar
hey with that mazdaspeed 6 body what line should I cut it down to and should I cut out the holes on the wing?
Tremor24 is offline   Reply With Quote
Old 04-17-2008, 04:16 PM   #19673
I tried cutting the holes in the wing and it made the car unstable. I covered the holes with tape and my handling problems went away. I wouldn't do that again
DOTMAN is offline   Reply With Quote
Old 04-17-2008, 04:28 PM   #19674
Burlap's Avatar
Send a message via MSN to Burlap
Nice work Drag_On, I've got a spare 415 diff plus spare diff screws, might give that a try.
Burlap is offline   Reply With Quote
Old 04-17-2008, 06:46 PM   #19675
DRAG_ON's Avatar
your welcome mates--externally adjusted rear diff make easier to set up without having to open the ball cups all the time the slot hole for hex wrench is already there all the time i never notice it
Old 04-18-2008, 03:15 AM   #19676
Gday
Finaly here are some pics of my 415MSX with S400 rear gear diff and SMC 4000 Lipo. (sorry about the quality 1/2 blind and shakes )
Will have a run on sunday weather permitting and post results.
have a good weekend
Steven
Tamiya TRF415-2008_0418jugs_goin_away_pics0012.jpg   Tamiya TRF415-2008_0418jugs_goin_away_pics0008.jpg
Old 04-18-2008, 10:51 AM   #19677
Hedaria's Avatar
Default Lipo batteries
Casino,
Did you have to grind off any of the rear aluminum bulkhead to fit the Lipo battery? Do you know which Lipos fit without any modification?
Hedaria is offline   Reply With Quote
Old 04-18-2008, 11:34 AM   #19678
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Originally Posted by Hedaria View Post
Casino,
The battery that requires the least modification is the Orion 3200. You can get away with not grinding anything but it will rub just slightly and you do have to coax it into the place.
Casino Kid- I'm glad to see someone fit the SMC pack because I plan to get one. Please can you take a side view picture of how much you grinded the bulkhead?
Racing4Evo is offline   Reply With Quote
Old 04-18-2008, 01:33 PM   #19679
Hedaria's Avatar
Default Lipo Fitment
Racing4Evo,
Old 04-18-2008, 04:50 PM   #19680
Casino,
Gday guys
as far as the batteries are concerned NO you don't have to grid any part off the bulk head PERFECT fit.
SMC 4000 are the ideal lipo combined with a G.T.Power A6 Charger wich gives you all of the settings for lilo/lipo/life,nicad/nimhand lead acid.
As well as a program for your pc (simple program) you can save all of your datta from each battery.
Steven
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
