Old 02-28-2008, 07:38 AM   #19561
tc3team's Avatar
Originally Posted by tc3team View Post
ive got a brand new, unbuilt trf415msxx in the mail to me Anyone got any build tips?
I know its a good idea to superglue the chassis to stop it from delaminating, take my time on each step etc, but is there anything else I should know?
thanks!
I guess you are all busy building your 416s? lol If the ta05 manual is anything to go by, it should be a very well documented build manual
Any differential build tips for me to make a butter smooth diff?
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 02-29-2008, 12:42 AM   #19562
Drifting101's Avatar
i need the product code for the screw and flanged spacer/bushing that is at the bottom of the TRF 415 front suspention arms (that goes through the c hub to the turning hub). Over the weekend i crashed and lost that screw and bushing when when it smashed the c hub
Thanks, Matt
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 02-29-2008, 02:51 AM   #19563
TryHard's Avatar
Thanks, Matt
Hi Matt,
The screw is a normal 3x10mm countersunk. These are the flanges
http://www.speedtechrc.com/store/ebp...id=426&id=1813
I find keeping a few in the pitbox always useful
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 03-03-2008, 07:21 AM   #19564
tc3team's Avatar
anyone got the tamiya part #s for a spool for a 415msxx (not mre), I believe I will be needing a fixed layshaft too but im still in the process of building it up (kit comes with a 1 way).
Is there any slim chance the tamiya ta05 centre shaft and spool will fit? Doubt it, but you never know lol.
tia
Old 03-03-2008, 07:27 AM   #19565
Have a review of the Tamiya USA site, that will have the manual(PDF) and then you will be able to find the part
Andyg01 is offline   Reply With Quote
Old 03-03-2008, 10:00 AM   #19566
tc3team's Avatar
I have the manual that comes with the car, but as it comes as standard with the one way I dont think it lists the option parts, but thanks I will have a look and see what I can find
Old 03-03-2008, 02:36 PM   #19567
TryHard's Avatar
Hey Chris,
The best thing to do is get the parts from the MRE kit. So the spool and central unit. Parts required are;
TAM3454395 Direct Centre Shaft
TAM51213 16t Pulley
TAM50589 5mm E-Ring
(this kinda shows it 18t pulley tip)
TAM3454401 Direct Holder (Front spool)
TAM9804268 Direct cup (delrin drive cup for spool)
TAM9804267 Direct couplnig (Aluminium sleave)
Otherwise, have a look for the JAAD spool. Has steel outdrives as standard, and works very well. Jaad 415 products
HiH
Ed
Old 03-04-2008, 12:38 AM   #19568
does anyone know if this will fit in a standard 415
http://www.speedtechrc.com/store/ebp...id=521&id=6323
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 03-04-2008, 02:06 AM   #19569
TryHard's Avatar
Yes that will fit, as the bulkheads are the same distant apart. Just need to use the delrin drive cups as my post above
HiH
Ed
Old 03-04-2008, 02:59 AM   #19570
tc3team's Avatar
Originally Posted by TryHard View Post
Hey Chris,
TAM51213 16t Pulley
TAM50589 5mm E-Ring
HiH
Ed
Top man just what I was looking for.
Old 03-04-2008, 03:25 AM   #19571
HiH
Ed
Yeah we found the JAAD spool after you mentioned it. Looks really good but Have to find somewhere to get it from! Found it on PrecisionRC but you can't order it! Something wrong with the site so we can't fill in the boxes... Anyone know another site that sells these spools?
Powered by Falco
Old 03-04-2008, 03:29 AM   #19572
TryHard's Avatar
It helps having hard copies of all the manuals on my home PC.. always easy to pick off the part #'s quickly.
http://www.tamiya.com/japan/download/rc_index.htm and click on the second link down on the left hand side
Old 03-04-2008, 03:43 AM   #19573
tc3team's Avatar
Nice one, I will download that at home
Old 03-04-2008, 11:29 AM   #19574
TRF415boy's Avatar
HiH
Ed
Ed this isn't the spool but the centre shaft... And it will fit the car, BUT you'll have to take the whole rear assembly to remove or put it, so I wouldn't recommend it at all.
TRF415boy is offline   Reply With Quote
Old 03-04-2008, 02:08 PM   #19575
TryHard's Avatar
haha, so it is.... thought Spool center ment the centre part of the spool... my bad
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
