Old 01-07-2008, 03:38 PM   #19531
TryHard's Avatar
Quick Plug....
Anyone looking for a brand new, never used MSXX bottom plate (2mm thick) shoot me a PM. As the 415 is going... no need for it anymore. It's even had the edges glued!
Regards
Ed
| THard.co.uk | Xray | MuchMore |
Old 01-10-2008, 11:45 PM   #19532
asw7576's Avatar
Are these batteries can fit into MSX415 battery area ? I'm worry the battery is too thick and I have to cut some material from rear alluminium bulkhead.
45mm X 138mm X 18mm
or
34mm X 98mm X 32mm
Old 01-11-2008, 01:53 AM   #19533
TryHard's Avatar
45mm X 138mm X 18mm
or
34mm X 98mm X 32mm
I don't know... but I'm highly suspecious of the MaxAmps packs though, simply as the don't come in a hard case, something I consider essential for touring cars.
Regards
Ed
Old 01-11-2008, 09:54 AM   #19534
asw7576's Avatar
okey, thanks.
I measured my MSX battery area, and it can accept 45mm X 138mm X 18mm ( lipo 5000Mah ) very nicely.
I 'm gonna add 3mm rubber strip on the outside to protect the battery from side impact.
Old 01-11-2008, 10:36 AM   #19535
mkdut's Avatar
Trader Rating: 19 (100%+)
I am currently running the Maxamps 5000 in my MSXX with no problems at all. You can dremel the bulkhead if you need a little more room. 6 months of racing and hardly a scratch on the battery.
mkdut is offline   Reply With Quote
Old 02-01-2008, 07:12 PM   #19536
DRAG_ON's Avatar
down in page:9, i'm sure some people still driving this car ---
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
Old 02-04-2008, 03:58 PM   #19537
TryHard's Avatar
I'm sure there are plenty who are too... however I'm no longer one of them... so have made some alterations to my site to reflect that. It's now going to be a 416 resource....
However, don't fret, I've kept all of the 415 info on there (it's even given me the opportunity to finally sort out some little niggles), it's just not on the main page.
www.thard.co.uk/415 is the address you now need.
Last update includes the 16 ball rear diff, and the flex characteristics, plus adding in some of the last setups I had to add. And I doubt very much I'll add any more to it now... Thank you 415, you were very good to me (shedding a small tear )
Regards
Ed
Old 02-11-2008, 12:34 AM   #19538
G'day
Can any body tell me if anyone has run the S400 rear gear diff in a 415msx.
if so will it fit without any shimming and what oil is used for mod/asphalt high grip.
Thanks Steven.
and where do you purchase them from.
Casino Kid is offline   Reply With Quote
Old 02-12-2008, 10:10 AM   #19539
Travis S's Avatar
Trader Rating: 46 (100%+)
Originally Posted by buboy28 View Post
sir RNOLD: if you could buy just the bulkheads and the upper deck that would be fine i have the 415MSX MRE and bought the whole convertion set so that i could use my Li-po packs this is how my 415 looks like now
Just looking for clarification on what kit I need to get for my MSX MRE so I can fit lipos like in the above picture.
Can I used the stick pack MSXX kit with just the MRX or will I need to order some different parts to get it to work? (link below)
http://www.tamiyausa.com/product/ite...oduct-id=49436
or do I need to get the MSX? (link below)
http://www.tamiyausa.com/product/ite...oduct-id=49385
Travis S is offline   Reply With Quote
Old 02-18-2008, 02:23 PM   #19540
Meatball1974's Avatar
Hello, new owner of a ~new 415msx and am in the midst of getting some front braking. I've just finished completing the front diff assembly using JAAD and Tamiya parts but have been rudely reminded that the MSX has a center front one-way on it was well.
Can someone point me to a good, reliable online site that sells to Canada the would carry the direct drive center pulley? Also hoping to find the HPI parts needed to convert the front of my car to be compatible with 28mm foams too.
Thanks.
Meatball1974 is offline   Reply With Quote
Old 02-21-2008, 05:22 PM   #19541
yokemad's Avatar
Hi Dudes
I need Your Help
I've just bought some tamiya shocks for my Mi3 and build them by following the manual with 40W and 30W shock oils but they now have 100% rebound with 2 of them has foam on top and 2 of them has O rings...
I don't know tamiya products so I have no Idea If it's normal or not...
I need your help to archive 50% rebound...
Many thanx in advanced for your help
yokemad is offline   Reply With Quote
Old 02-24-2008, 09:34 AM   #19542
Did you buy 49436 ? Looks the better of the two
Andyg01 is offline   Reply With Quote
Old 02-26-2008, 06:25 AM   #19543
tc3team's Avatar
Could someone tell me if the 415MSXX is the last one that came out before the 416 please, I am a bit lost with how many versions of the 415 there are, I did look at the thard.co.uk website as I think it used to be on there but now its all 416 related
Anyone got a list of in which order they were made?
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 02-26-2008, 06:48 AM   #19544
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
415
415 MS
415 MSX
415 MSX MRE
415 MSXX
415 MSXX MRE
THE END
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 02-26-2008, 07:00 AM   #19545
tc3team's Avatar
Thanks, thats really useful What are the differences between the msxx and the msxx mre? Am I really going to notice the difference between the two?
is the msxx quite fragile, or a solid car? I have a ta05 with the 3racing graphite chassis and its a tank, solid as a rock! I heard the bearings can be fragile as they are ceramic, any experiences? (I could be wrong)
thanks.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
