Old 12-18-2007, 04:08 PM   #19486
Originally Posted by buboy28 View Post
sir RNOLD: if you could buy just the bulkheads and the upper deck that would be fine i have the 415MSX MRE and bought the whole convertion set so that i could use my Li-po packs this is how my 415 looks like now
Hello there...
ur 415MR is such a beautiful car with alum. front steering knuckle and rear modulus suspension ... I'm getting one like yours 2nd handed...
I have a big question... is ur front alum steering from Square RC? and could you tell me where I can order it?
Thanks a lot!!!
dendog220 is offline   Reply With Quote
Old 12-18-2007, 05:53 PM   #19487
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Originally Posted by dendog220 View Post
Hello there...
Thanks a lot!!!
hi, i ordered it from www.rc-mushroom.com
buboy28 is offline   Reply With Quote
Old 12-18-2007, 06:20 PM   #19488
pole_position's Avatar
This is the right time to get a TRF415MSXX MRE at more than a hundred bucks cheaper than it should be with the new release of TRF416... as Tamiya has made a terrible marketing nightmare of launching a new product (416) to kill off a older but proven product (415MSXXMRE) at the same time.
There is no major major changes between the 416 vs 415. Personally I will still go for a TRF415MSXX MRE
pole_position is offline   Reply With Quote
Old 12-19-2007, 04:40 AM   #19489
Send a message via MSN to jontang001
HI
I just want to say that you are wrong...
I got my 416 last week and tested on carpet track.
416 let me feel the stable and more powerful...maybe the rear belt was too short.
I can see the most improved in detials.
Some said that 416 just alike the first 415 but I said after you tried you will not say that again!!!
TAMIYA TRF416, EVO5MS, TB03 FullOP
Schumacher Mi4LP, CAT SXII, Cougar
jontang001 is offline   Reply With Quote
Old 12-19-2007, 10:40 AM   #19490
Originally Posted by TryHard View Post
you can run the MRE belts, just loosen the tensioners off... at least thats what I do!
HiH
Ed
Cheers Ed didnt think there would be enough slack to go that far.
Have you found any difference between the 16t and 18t pully's if so what?
Cheers Paul
blue247carz is offline   Reply With Quote
Old 12-25-2007, 03:18 AM   #19491
DRAG_ON's Avatar
Do anyone have Maezumi Satoshi and Mark Reinhard, 5 cells set up from the past 2007 reedy race.........
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
Old 12-25-2007, 03:42 AM   #19492
TRF415boy's Avatar
Cheers Paul
I've been running that combo for 2 years now. Belts and pulleys lifetime is much longer, no more belts snapping and basicaly that's the main advantage really. Sure the drivetrain is a bit freer but it's already quite free on the MRE.
TRF415boy is offline   Reply With Quote
Old 12-25-2007, 03:56 AM   #19493
It΄s been posted before but the search button doesnt seem to work. Marc used Victors germany car and setup.
Mr_Orange is offline   Reply With Quote
Old 12-25-2007, 06:40 PM   #19494
Trader Rating: 37 (100%+)
Send a message via MSN to slyts6
i have the normal TRF 415...is there a way to fit the front and rear bulkheads from a MS or MSXect to the chassis plate?
will this fit the normal 415 chassis?
http://www.tamiyausa.com/product/ite...oduct-id=49378
pretty sure id need to upgrade to lightweight suspension too correct?
Axial Wraith -- Scratch Built -- Vanquish -- Motoworx -- Rc4wd
Axial XR10 -- Hitec 7955tg -- Vanquish -- Airtronics -- Tekin FXR's
If it's got wheels or tits, you'll have trouble with it.
slyts6 is offline   Reply With Quote
Old 12-25-2007, 09:25 PM   #19495
miccal's Avatar
Trader Rating: 23 (100%+)
It will fit provided you change to the reversible suspension set. I was using an original TRF415 chassis on my TRF415MS with no problems.
miccal is offline   Reply With Quote
Old 12-25-2007, 11:53 PM   #19496
Originally Posted by DOTMAN View Post
I used the Cyclone front belt and Xray rear belt and they worked perfectly
Depends on what Cyclone belt you get... the stock one or the longer 170T one made for the 39/18T pully set on the Cyclone.
duckman996 is offline   Reply With Quote
Old 12-26-2007, 12:47 AM   #19497
asw7576's Avatar
Originally Posted by andrew222 View Post
I need a little help.
I own a TRF415msxx MRE. Whenever I full lock the steering to the left or right and apply half throttle, I get this massive vibration to the whole front a-arm. When I apply full throttle the vibration disappears. Now when I turn the steering halfway and apply half throttle I don't get any vibration. I can't figure it out. It's driving me insane. A little help would be so helpful. Thanks
Check out your front CVD. Sometimes it does that. You need to clean and rebuild.
Old 12-26-2007, 01:18 AM   #19498
TRF415boy's Avatar
Nah you don't NEED to upgrade to the LW suspension, it'll fit without problem with the old style suspension.
Old 12-26-2007, 02:30 AM   #19499
DRAG_ON's Avatar
does anyone using JAAD racing Diff Outdrive on MSX........??? where can i buy online? anyone have a good website that sell this Jaad Products, thanks
Old 12-26-2007, 03:49 AM   #19500
are the bulkheads on the MS and onwards easier to take the spur gear and shaft out?
would i need a new shaft or one from the MS or later?
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
