Old 11-16-2007, 05:22 AM   #19441
Vicko's Avatar
Trader Rating: 14 (100%+)
thanks running it on Dec 1. sure hopes it goin to fun
Vicko is offline   Reply With Quote
Old 11-19-2007, 02:19 AM   #19442
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
hey guys,
the front one-way on my MSX isn't as free as it use to be. I have cleaned out the bearings that sit in the front knuckles and no luck, is there anyway to clean out the one-way internal bearings?
Cheers
Castle Hill Raceway
surrealmaterial is offline   Reply With Quote
Old 11-19-2007, 07:15 PM   #19443
G Mills's Avatar
I'm looking for a 415 msx upper deck and steering rack. Please contact me if you would be willing to sell them. thanks.
G Mills is offline   Reply With Quote
Old 11-20-2007, 08:20 PM   #19444
Spec-R's Avatar
Trader Rating: 5 (88%+)
Send a message via Skype™ to Spec-R
Default 415 msx mre mod
Hi Guys,
just join the treat recently,got a 415 msx mre and i want to change the centrel pulley to alum...anyone got any ideal how to do it, dont want one way, and what parts i need to get to do the mod? thanks
Spec-R is offline   Reply With Quote
Old 11-21-2007, 10:35 AM   #19445
Originally Posted by Spec-R View Post
Hi Guys,
Why would you want to change to aluminum? The big reason for the plastic gears is that the alum pulleys wear quickly...especially in mod. The teeth become sharp and wear out your belts prematurely. I'd stick with the plastic pulleys if I were you.
DOTMAN is offline   Reply With Quote
Old 11-21-2007, 08:41 PM   #19446
quick question:
are the blue lightweight aluminium drive shafts strong enough to run in mod (Novak 4.5)? or is it better to have the steel ones?
Cheers
Castle Hill Raceway
Old 11-22-2007, 12:22 AM   #19447
Spec-R's Avatar
Thanks for the advise, as i see a wide direct pulley on the net it looks good.Wide mean one piece 16 teeth.
Old 11-22-2007, 02:49 PM   #19448
Super Moderator
Grizzbob's Avatar
Originally Posted by surrealmaterial View Post
quick question:
Cheers
Honestly don't a good answer on that, as I haven't run a 4.5, but to be honest I think I'd go with steel on that one, always better to be safe than sorry, IMO....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 11-22-2007, 08:20 PM   #19449
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
quick question:
Cheers
you can run it placing it at the rear not on the front for it is not strong enough to take a serious crash but to be sure better use the steel ones both at the rear and the front
buboy28 is offline   Reply With Quote
Old 11-24-2007, 09:04 PM   #19450
Vicko's Avatar
so what spring are u ppl using one carpet, rubber tires?
what type of rubber tires also?
on med to high traction carpet..
thanks for any info
Old 11-24-2007, 09:06 PM   #19451
Send a message via AIM to ThunderRobo Send a message via MSN to ThunderRobo
I ran the JACO Blue rubbers on my 415. some others are running Sorex 28R and CS 27 at my track.
We use Jack the Gripper.
Derek.C
http://www.runryder.com/helicopter/gallery/43404/
ThunderRobo is offline   Reply With Quote
Old 11-24-2007, 09:09 PM   #19452
using Tamiya Yellow springs all around, with yellow sway bar up front, red in the rear.
Front one-way.
Derek.C
Old 11-27-2007, 01:57 AM   #19453
quick question guys,
anyone got an idea on how long the black swing shafts would last running a 4.5? And how long the derlin outdrives for the MRE spool would last..
Cheers
Castle Hill Raceway
Old 11-27-2007, 04:28 AM   #19454
TryHard's Avatar
thanks for any info
Tamiya Whites up front, blues in the rear, no sway bars. Shocks, 3 hole pistions, 45-50wt front, 40-45wt rear.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 11-27-2007, 10:27 AM   #19455
Send a message via MSN to jontang001
HiH
Ed
Hi Ed
May I ask you what the front and center axles were you use? one way or???
I have saw many different settings for carpet but there are in double side...hard or soft...which is the best for carpet? I mean the springs and shocks...like you, you use a harder setting. But, like the upper post, he use the yellow springs...I can not get it...
jontang001 is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
