Old 11-14-2007, 01:31 AM   #19426
TryHard's Avatar
Originally Posted by echo View Post
Thanks Tryhard, so i still can use my original bearing holder (black plastic)?
Yes you can, but you might have to remove some material from them to get them to fit the bearings properly.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 11-14-2007, 01:34 AM   #19427
RBLove's Avatar
Trader Rating: 72 (100%+)
Any of you Tamiya guys have an extra set of 3H pistons (53573)? Shoot me a pm if so.
RBLove is offline   Reply With Quote
Old 11-14-2007, 09:03 AM   #19428
habis's Avatar
Originally Posted by Jam-ehz View Post
1. It's exactly 2.0:1
2. HB Cyclone Front belt, XRay T1 Rear Belt
3. 2.055:1
4. Likely the same as above, but some report that it's too tight..
Unfortunately it was the first time I ran the MSX on carpet with rubber, but for me the times were phenomenally greater than what I've ever done on the TA05.. then again, 2 different chassis, different weights, but I knew that it was allowing the motor to run at full speed without hinderance. I'm sure foam would work just the same, but perhaps a bit tighter belts.. but still not as tight as you would with a 16T center..
I believe the MRE car's new steering also changed the upper deck's hole positioning.. you'll likely need to get an MSX top and bottom chassis with the standard steering rack.
for the 18/37 combo i tried the X-ray reat belt and it was too tight.
you need to use the Cyclone....but that is to loose.
i fitted the Cyclone belt ....but as it was very loose i didnt take the car for a spin. i gave up on the 37/18 project as the x-ray belts on a 35/18 combo is a better solution.
also i can fit the large diff plates(x501) on the old 35 pullies.
so i find the 35/18 combo better giving a IR on 2.05:1
habis is offline   Reply With Quote
Old 11-14-2007, 10:12 AM   #19429
Trader Rating: 27 (100%+)
Send a message via AIM to John Stranahan
Originally Posted by surrealmaterial View Post
thanks for the roll center chart TryHard! As i have no idea, what would be a good starting roll center to use on a low grip asphalt surface?
Cheers
I would strart the roll centers near zero on low grip asphalt front and back. Here are some indications that it is too low. Too much grip in the corner. The car slows down too much from cornering. This is not likely on low grip asphalt. During a bigger race as traction comes up you can raise the roll center or add sway bars to promote a little drift or sliding in the corners.
Ed- Really nice job on that spreadsheet that you posted above. It makes it really easy to calculate roll center and remove the mystery. Wish we had one as easy to use for the TC5.
John
John Stranahan is offline   Reply With Quote
Old 11-14-2007, 11:56 AM   #19430
RC MARKET's Avatar
TRF416 ?
Which one with photo can see TRF416 motor mount is 1pc
or motor mount with left side center shaft mount 1pc ?
RC MARKET is offline   Reply With Quote
Old 11-14-2007, 12:15 PM   #19431
POUNDITRACING's Avatar
is there a thread for the 416?
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 11-14-2007, 08:28 PM   #19432
Trader Rating: 62 (100%+)
Yes.
patrick is offline   Reply With Quote
Old 11-15-2007, 10:09 AM   #19433
Originally Posted by patrick View Post
Yes.
where you jerk. Help a buddy out. Hay how's your cell phone. Sorry, had to do it.
Old 11-15-2007, 11:38 AM   #19434
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Arrow TRF416 Thread!!!!!
Ask and you shall receive.
http://rctech.net/forum/showthread.php?t=181060&page=10
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 11-15-2007, 11:55 AM   #19435
Originally Posted by JRRobiso View Post
thanks. pat in a butt head.
Old 11-15-2007, 05:08 PM   #19436
Vicko's Avatar
Trader Rating: 14 (100%+)
goin to run rubber tire on carpet for the 1st time with my 415mr
anyone got any advice?
Vicko is offline   Reply With Quote
Old 11-15-2007, 09:18 PM   #19437
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default bearings
Can someone confirm the size of the bearings for the front and rear hubs? The instructions only list a part number and not a size.
J.Gonzalez is offline   Reply With Quote
Old 11-15-2007, 10:03 PM   #19438
Superkarter's Avatar
the hub bearings are 5x9x3mm
Superkarter is offline   Reply With Quote
Old 11-16-2007, 12:52 AM   #19439
peejay's Avatar
Which version of the 415? The original has 1150 bearings, and all others 950.
peejay is offline   Reply With Quote
Old 11-16-2007, 02:13 AM   #19440
TryHard's Avatar
Two things;
Outer hole on the rear hubs - I've always found it helps to settle the rear end of the car down, makes it less snatchy.
D-D on the front - almost a must if using a front one-way, helps to calm the front end down.
If the grip is up as well, raise your roll centres to help carry corner speed.
HiH
Ed
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
