Old 11-08-2007, 07:39 PM   #19411
hyena boy's Avatar
Originally Posted by nexxus View Post
It's a nice conversion which I did when I had mine but as far as advantage? Nothing major, changes the FDR and gives you the option of wide pitch pulleys and gets rid of that silly external shaft stopper. I'd change to the MSXX / MRE steering before doing the drivetrain.
do you have part numbers for the pulleys, and build diagrams for them?
can you put the mre steering on a msx on the stock chassis?
does anyone run the 415msx on carpet with foam tires, and if so what hop ups do you suggest or need?
jeff
hyena boy is offline   Reply With Quote
Old 11-12-2007, 02:57 PM   #19412
TryHard's Avatar
Hi All,
Thought I'd just share this little, well, calculator with you fellow 415ers. First up, you need Excel for it....
Basically it's a complete roll centre calculator for the MSX onwards. Select your setup options from the first page, and up pops your roll centre. I've done it for both the front and rear, and tried to include as many of the options as drop down boxes. Only ride height, and camber link shims need to be entered as numbers.
I've also set the calculations up to take into account the change in track width (even though it's miniscule), that occurs when you add or take away toe from the suspension blocks (as the angles change, so does the inner pin width). Also added in the options for use with kick-up, anti-dive, and anti squat.
Anyway, let me all know what you think... hopefully it'll prove useful to some of you.
Regards
Ed
P.S. When I get my 416... I'll be doing the same
EDIT - added an updated sheet version, added some notes, and kit setups to the calculator for reference
| THard.co.uk | Xray | MuchMore |
Old 11-12-2007, 04:37 PM   #19413
Originally Posted by TRF415boy View Post
No I have bought longer belts from bando, but you need to buy them from a distributor and they might not want to sell them to you. best wait to see what tamiya's doing tbh.
TRF415boy, Hi I have been looking at changing to a larger layshaft pully for a while now and have been looking at the 18t plastic pully's from the TRF501X which have the same locators as the standard MRE layshaft also wouldn't the 501X front belt fit if you convert to 37t front and rear diff pully's obviously with maybe an XRAY rear belt???
Have you any experience with interchanging these parts?
Cheers
blue247carz is offline   Reply With Quote
Old 11-12-2007, 05:07 PM   #19414
RC MARKET's Avatar
Cheers
F use MRE belt & R use XRAY rear belt can use 37T pulley ,
but center is 16T pulley.
RC MARKET is offline   Reply With Quote
Old 11-13-2007, 01:37 AM   #19415
echo's Avatar
What the different between TRF415 MSX low friction (white) and MRE belt?
I am a Human Network
echo is offline   Reply With Quote
Old 11-13-2007, 01:39 AM   #19416
echo's Avatar
I want to convert my center shaft 415msx to direct center shaft 415mre. What should i buy?
Old 11-13-2007, 01:58 AM   #19417
TryHard's Avatar
MRE belts are slightly longer to be a better fit for the 36t pulleys. The white belts do fit, though you have to run the belt tensioners a bit looser.
For the direct centre shaft... see here
http://www.rctech.net/forum/showpost...ostcount=19401
Old 11-13-2007, 02:07 AM   #19418
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
thanks for the roll center chart TryHard! As i have no idea, what would be a good starting roll center to use on a low grip asphalt surface?
Cheers
Castle Hill Raceway
surrealmaterial is offline   Reply With Quote
Old 11-13-2007, 05:21 AM   #19419
TryHard's Avatar
Cheers
TBH, I'm not too sure myself. Was really doing it to see how my setup relates front to rear (I think the rear RC is too low atm).
I would have thought something similar to kit settings wouldn't be far wrong, so...
MSX F = 0.41mm, R = -3.08mm, Difference = 3.49mm
MSX MRE F= 0.70mm, R = -4.47mm, Difference = 5.17mm
MSXX F = 0.41mm, R = -5.44mm, Difference = 5.85mm
Something I should add... the ball studs used in all calculations are the hexheaded type, so are 1mm shorter. If your using standard studs/nuts, add 1mm to the value of the shims you put in. I'll update my previous post this evening with a sheet having that note on it.
Regards
Ed
Old 11-13-2007, 12:28 PM   #19420
RC MARKET's Avatar
use MRE
Old 11-13-2007, 12:53 PM   #19421
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Switching from the MSX center pulley to the MRE dropped 7 grams from the chassis.. I just had to drill out a bit of the bearing holder material so the bearing sat further inside.. found a 5/16" bit just fit that hole, and used a drill press to slowly and lightly take a bit out each time.. It just needs to sit in an extra millimetre, really.. I figured this was cheaper than getting the aluminum holder, AND the curved top plate that has to go on top of it.
I love the 18T/36T Widepitch setup.. sure you need Cyclone and T1 belts, but just the extra freedom of the drivetrain is great.. I was running 19T rubber with a Checkpoint, and some were surprised at the belt tension I ran.. incredibly loose, but no slippage.. very nice! I think I'd have to run a bit tighter for Foam..
I had to run diffs at the moment. I have to look into the MRE front oneway for my MSX that fits 36T pulleys for rubber, keep my diff for foams..
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 11-13-2007, 05:38 PM   #19422
snopro31's Avatar
Trader Rating: 36 (100%+)
I have a few questions and may have been answered here but i dont have time to check here everyday and i miss alot sorry.
1, with 18tooth centre and 36tooth wide pitch pully what is the internal ratio?
2, what belt is needed front and rear for this change alone?
3, with an 18tooth center and 37tooth wide pitch pully what is the internal ratio?
4, what belt front and rear is needed for the 18,37 combo?
has anyone tried this on foam tire carpet and did you see any actualy improvement ?
other then yea the car in theory should be looser do to less belt wrap. it should make it looser but did it actually make a gain you could feel or notice in your times. ?
has anyone tried to put the 4mm msx chassin on the mre car? is there a way to make the steering fit or did you just put the old steering on and how did it work?
Sorry for all the questions just want to catch up i will be able to read here every day for the next little while
snopro31 is offline   Reply With Quote
Old 11-13-2007, 07:30 PM   #19423
Jam-ehz's Avatar
1. It's exactly 2.0:1
2. HB Cyclone Front belt, XRay T1 Rear Belt
3. 2.055:1
4. Likely the same as above, but some report that it's too tight..
Unfortunately it was the first time I ran the MSX on carpet with rubber, but for me the times were phenomenally greater than what I've ever done on the TA05.. then again, 2 different chassis, different weights, but I knew that it was allowing the motor to run at full speed without hinderance. I'm sure foam would work just the same, but perhaps a bit tighter belts.. but still not as tight as you would with a 16T center..
I believe the MRE car's new steering also changed the upper deck's hole positioning.. you'll likely need to get an MSX top and bottom chassis with the standard steering rack.
Old 11-13-2007, 09:52 PM   #19424
echo's Avatar
Thanks Tryhard, so i still can use my original bearing holder (black plastic)?
Old 11-13-2007, 10:53 PM   #19425
Hey guys,
I need to get a MRE/MSXX aluminium upper brace (TA-3454404), so if anyone has one lying around or knows were i can get one let me know please.
Cheers
Castle Hill Raceway
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
