Old 10-12-2007, 09:04 AM   #19336
Originally Posted by surrealmaterial View Post
thanks, but if i choose the 18t pulleys would i be able to run my original belts? (also running 36t white pulleys)
Nope, you need a xray rear belt and a HB front belt. Also, in order to fit the mre layshaft in a msx, you need to either to file the layshaft to fit the msx bearing holders or fit mre ones with mre upperbrace.
Mr_Orange is offline   Reply With Quote
Old 10-12-2007, 04:54 PM   #19337
TryHard's Avatar
I'm pretty sure the MRE bearing holders are not required, as the spacing on the holders is the same, from memory. I may be wrong though...
Regards
Ed
| THard.co.uk | Xray | MuchMore |
Old 10-12-2007, 06:00 PM   #19338
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Regards
Ed
So.. just to clarify.. to put a MRE spur setup in an MSX, you would need...
3454395 - Direct Center Shaft
51213 - TA05 16T Pulley
..would the 9804263 - 840 Aluminum Bearing Holder fit, or just stick with the old plastic ones?
Is it possible to put the MSXX spur setup into an MSX with these?...
3454477 - Center Shaft
3454478 - Spur Gear Holder
3454479 - Pulley Holder
..or 18T pulleys from the 501X?
Anything else? Just making sure I can use the parts that I'd be buying...
Why would two cars pretty close together use different spur parts? Is one set lighter than the other?
Jam-ehz is offline   Reply With Quote
Old 10-12-2007, 11:11 PM   #19339
maxepower's Avatar
Talking Conversion 101!
3454401 - Direct Holder
The plastic bearing holders need to be reversed but a very tight fit so you can file them down to fit nice. I guess the MRE is lighter being the spur gear holder is a one piece made out of aluminum where as the MSX is aluminum with a steel shaft going through the center. Plus the MRE uses plastic gears vs. the aluminum that the MSX uses.So I guess it would be much lighter!
maxepower is offline   Reply With Quote
Old 10-13-2007, 03:18 AM   #19340
Centerfire's Avatar
Trader Rating: 6 (88%+)
Hi Guys, i tried using the 36T and 18T converted Pulleys and Belts, but im having a problem in Front Belt Tension because it seems that the front adjustment notch is almost second to the last slot but the tension of my front belt is still not that normal tight. its a little bit loose! what will i do? Thanks!
Centerfire is offline   Reply With Quote
Old 10-13-2007, 09:19 AM   #19341
Jam-ehz's Avatar
I wonder why all of a sudden they went from the MRE's 1-piece spur/pulley mount to the MSXX's 2-piece...
Old 10-13-2007, 10:39 AM   #19342
infokiz's Avatar
Because the MSXX comes with the center oneway
infokiz is offline   Reply With Quote
Old 10-13-2007, 11:50 AM   #19343
habis's Avatar
i wonder aswell. cause the 1-piece really works well....ally my tamiya 415s are mounted with 1-piece center shaft
habis is offline   Reply With Quote
Old 10-13-2007, 11:51 AM   #19344
habis's Avatar
Old 10-13-2007, 01:21 PM   #19345
Jam-ehz's Avatar
Ah.. so if you want to use the MSXX with a solid center, you'd have to go get the MRE's, and vice-versa?
Old 10-14-2007, 02:19 AM   #19346
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
ok, can i use the original belts if i use the 16t centre pulleys with the 36t white pulleys?
Castle Hill Raceway
surrealmaterial is offline   Reply With Quote
Old 10-14-2007, 04:57 AM   #19347
rampal's Avatar
Send a message via MSN to rampal
by original belts you mean the white ones?? You can use the MSXX ones, I think the white ones are a tight fit.
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 10-14-2007, 05:03 AM   #19348
mac853's Avatar
As you loose the belts with bearing holder it's acceptable at least on Stock race.
mac853 is offline   Reply With Quote
Old 10-14-2007, 12:34 PM   #19349
SpeedTech's Avatar
Hi Guys,
Just want to post a quick note we got more Tamiya spare and hop-up parts for TRF415 back in stock
Also check out our new retail location
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 10-14-2007, 03:33 PM   #19350
RC MARKET's Avatar
Tamiya
TRF415 Series parts discount now !
http://rcmarket.com.hk/index.php?cPath=51_98_120_134
RC MARKET is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
