Old 10-05-2007, 02:01 PM   #19306
MelvinLee's Avatar
Default TRF 415 for sale.
If you are looking for that good carpet car, I have the 415 with all part, and 4mm lower deck for sale. $150 Take a look over in rc sale.
CTX D2, CELL MASTER, AND MUCH MUCH MORE.
MelvinLee is offline   Reply With Quote
Old 10-05-2007, 03:34 PM   #19307
AWK
AWK's Avatar
Has anyone run a TA05MS and 415 back to back? I am probably going to pick up a TRF415MSXX MRE (yeah its a mouth full) but I already have a TA05MS. I am very curious to see the handling differences.
AWK is offline   Reply With Quote
Old 10-05-2007, 03:37 PM   #19308
RC MARKET's Avatar
Originally Posted by f1larry View Post
Marc did win Mod Rubber at the IIC
Good !
RC MARKET is offline   Reply With Quote
Old 10-06-2007, 05:30 PM   #19309
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
you should wait for the 416
Castle Hill Raceway
surrealmaterial is offline   Reply With Quote
Old 10-08-2007, 01:29 AM   #19310
are the white low friction belts stronger than the black ones?
Castle Hill Raceway
Old 10-08-2007, 02:14 AM   #19311
also if i buy these:
http://www.rcmart.com/catalog/produc...ducts_id=23030
http://www.rcmart.com/catalog/produc...ducts_id=20782
would i be able to make a spool for my MSX? I have a one way in it now.....can i still use that pulley?
Cheers
Castle Hill Raceway
Old 10-08-2007, 02:46 AM   #19312
TryHard's Avatar
well, had a reasonably good days racing yesterday. Car was fast, and had a really good balance.
Settled on a few choices for next weekend, and made a few tweaks to the setup to get the car working better on the Vtec27's (loosening up the rear mainly).
Didn't manage to try the locked one-way joints, I'll have to try them some other time. Given how well the car was going with the standard dual one-ways (lots of entry steering, but nice and stable), I didn't want to change loads before next weekend.
Still runing a setup very close to the one from last year's carpet wars, except for some slight changes to the shocks (still not settled on which combo to go for.. heavier or lighter oil), steering spacer, rear camber links, and rear toe blocks.
Now just need to get some new cells (4 packs of EP's are on their way..) and I'm all set!
Here's hoping for a good one for the coming weekend.
Regards
Ed
| THard.co.uk | Xray | MuchMore |
Old 10-08-2007, 02:49 AM   #19313
rampal's Avatar
Send a message via MSN to rampal
Cheers
you need:
Tamiya 9804267 TRF415MSX MRE Direct Coupling
Tamiya 9804268 TRF415MSX MRE Direct Cup
Tamiya 9805776 2x9.8mm Shaft
Tamiya 3454401 TRF415MSX MRE Direct Holder
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 10-08-2007, 03:39 AM   #19314
whats the coupling for?
Castle Hill Raceway
Old 10-08-2007, 03:45 AM   #19315
rampal's Avatar
to avoid the delrin outdrives coming wide open....
Old 10-08-2007, 03:46 AM   #19316
can i use my original oneway pulley with the spool?
cheers
Castle Hill Raceway
Old 10-08-2007, 01:20 PM   #19317
hi guys
anyone useing the orion 4800 lipo in a msxx.it looks like you have to cut the lump in the rear metal part where the battery shape is.do you have to file or cut the cross piece aswell.
any pics would be great
skiv is offline   Reply With Quote
Old 10-08-2007, 01:28 PM   #19318
linger's Avatar
Originally Posted by skiv View Post
hi guys
skiv,
you can't run the orion 4800 in the MSXX. There is a screwhole going through that part of the aluminum bulkhead that you should not grind off.
The only way to get it to fit is to buy the MSXX stick pack chassis conversion.
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 10-08-2007, 01:33 PM   #19319
ok thanks for the advice ill have a look at the convertion before i go out and buy lipos.
Old 10-08-2007, 02:10 PM   #19320
rampal's Avatar
cheers
yes.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
