Old 09-22-2007, 01:32 AM   #19291
PutAwayWet's Avatar
Originally Posted by Ted B. View Post
I guess my local track is going to be running all rubber tires on the carpet this winter which I have never done. Does anyone know of a good setup for the MSXX?
Ted B.
[email protected]
I run an MSXX with a 13.5 at our local track (Seattle Indoor Raceway--'07 Paved Nats), and we laid down carpet this past month.
I'm running direct drive and a front diff, blue springs in back, white in front, medium front swaybar, no rear, Sorex 28's, and I have to say my car is hooking up really well. Oh, and a Mazda 6 body. I started with a Mohawk but didn't like it. The MSXX doesn't have much of a reputation as a carpet car, but at least with rubber tires, it slices as well as anything else down there. And we've got it all, TC5's, 007's, Mi3's, yadda yadda.
PutAwayWet is offline   Reply With Quote
Old 09-22-2007, 10:39 AM   #19292
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Is there a front diff for the MSXX? I'm having a hard time finding information on it.
Racing4Evo is offline   Reply With Quote
Old 09-22-2007, 10:55 AM   #19293
stokka's Avatar
www.precisionrc.com is stocking the front diff.
Actually this link below will take you to it:
http://www.precisionrc.com/nv/car/pr...300&cat_id=969
stokka is offline   Reply With Quote
Old 09-23-2007, 10:35 AM   #19294
chicmagnet's Avatar
Originally Posted by Mr_Orange View Post
You will need:
Center:
TA-3454395 Tamiya TRF415 Direct Center Shaft
TA-50589 Tamiya All Car 5mm E-clip
Spool:
Tamiya delrin:
TA-3454401 Tamiya TRF415 Direct Holder
TA-9804268 Tamiya TRF415 Direct Cups
TA-9804267 Tamiya TRF415 Direct Coupling
TA-53500 Cross joints for universals, just need the pins if you dont have any spare ones
JAAD steel:
JDR41502 JAAD Racing TRF415 Alum. Front Spool with Hard Coated Anti Rust Steel Joint Cups (Requires Ball Diff Pulley)
TA-53935 Ball diff pulley
18T Conversion:
TA-53989 Tamiya TRF501X Center Pulley (18T)
HBS-70738 Hot Bodies Cyclone/CS Front Belt 169T
XR-305442 Xray rear belt
sir, aside from xray rear belt, what other brand can i use??
STRAIGHT LTD.
chicmagnet is offline   Reply With Quote
Old 09-28-2007, 09:29 AM   #19295
Ted B.'s Avatar
Send a message via Yahoo to Ted B.
Thanks for the reply. What didn't you like about the Mohawk? I had the car out for a few runs yesterday and it's different than foams (obviously) but I am quite happy with the feel. Do you ever run two different compound rubber tires for the front and back? i.e. something harder in the front. What's your FDR with the 13.5 and why a front diff?
Ted B. is offline   Reply With Quote
Old 09-28-2007, 09:59 AM   #19296
TryHard's Avatar
Hi,
If your running rubbers on carpet, and unless it's really tight, try a front one-way in the car.... works very well in for stock racing (it's what I always run). For mod, try a spool. Also Vtec 27's are very good on the rug.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 09-29-2007, 01:26 PM   #19297
Send a message via MSN to mark34 Send a message via Yahoo to mark34
Hi
I am tring to find a Uk stockist other than Demon or Brock that definatly has the 16 t TA05 plastic pulley (51213). Any one know of a stockist
TIA
Mark
mark34 is offline   Reply With Quote
Old 09-30-2007, 02:17 AM   #19298
peejay's Avatar
Originally Posted by mark34 View Post
Hi
TIA
Mark
This any good?
http://www.tamiyaparts.co.uk/tamiyap...-1201-1400.htm
HTH
peejay is offline   Reply With Quote
Old 09-30-2007, 04:09 AM   #19299
Ta very much
Mark
Old 10-01-2007, 10:12 AM   #19300
TA05ers's Avatar
Did Marc Rheinard take the Modified Rubber Sedan crown at the recently concluded IIC?
Can anyone confirm it?
If yes, Marc is really on fire! Won the Reedy and now IIC?!?
-TA05MS-TA05R-TT01R-Futaba 3PK-KO Servo-Novak GTB-Nosram-LRP Velociti-Yokomo MSR-
TA05ers is offline   Reply With Quote
Old 10-01-2007, 10:13 AM   #19301
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
Marc did win Mod Rubber at the IIC
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|CRC WC-Xti|TT02|TA05|TL01|
f1larry is offline   Reply With Quote
Old 10-05-2007, 03:11 AM   #19302
TryHard's Avatar
whats this doing all the way down on the 3rd page.... not much going on at the moment then.
Got the carpet season starting big style next weekend, with the first round of Carpet Wars over here in the UK. Final chance to practise this weekend, and got hold of some new parts to try and make the MRE even quicker on the rug (not that it's slow at the moment!).
Found some one-way outdrives made by atomic, that lock them together, creating a locked oneway, a la Xray's multi diff.
I usually always use a one-way, but have recently been having issues with too much steering at the local club, so thinking this might help out a little, without having to change from my base setup too much.
Hoping for a good result, managed to make the A final in stock at the last round of the wars last year.... setup hasn't changed at all from that since, so I know it'll be fast
Old 10-05-2007, 03:19 AM   #19303
DRAG_ON's Avatar
good luck Ed and dont forget to share how you create locked oneway a la xray multi diff
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
Old 10-05-2007, 05:50 AM   #19304
TryHard's Avatar
very easy really....
Atomic Solid one-way joints
Got mine through RC Mart when browsing their site... worth a try I thought
Old 10-05-2007, 06:00 AM   #19305
rampal's Avatar
Send a message via MSN to rampal
please let us know how they perform... although I'm running mod, it would be interesting to know... are these too heavy?
thanks!
al
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
