Old 09-13-2007, 10:39 AM   #19276
slammin's Avatar
Trader Rating: 88 (100%+)
Send a message via Yahoo to slammin
Originally Posted by Slidewayz View Post
We can only use the bonded rotor in our 13.5 for our club racing. I use the 102T 64p spur on our short technical track. It runs your pinions to the higher 40 tooth side of things (~ 42mm rollout max available with a 51 tooth pinion) , so I would recommend using a 90 or so 64p tooth spur if your track is longer and calls for more rollout, or if you want greater gear selection.
Novak says run a 4:0 with the sinter rotor in 13.5.I am using a 52 pinion with the 102 spur on short technical with know problems. I be racing on a big track this weekend so I goning to go up to a 54 or 55 pinion with should be close to 4:0.
RC Addicts AR
Agama A8t
Agama A215e
Agama A215
Agama A215T
slammin is offline   Reply With Quote
Old 09-13-2007, 05:29 PM   #19277
TryHard's Avatar
Ok, if your running an MSX (35t/16t pulleys = 2.188 i.r.) your looking at a 55 or 56t pinion for 4 FDR (55 = 4.057, 56 = 3.984)
If your running an MRE or MSXX (or 36t drive pulleys, so i.r. of 2.25), you'll need a 57 or 58 pinion (57 = 4.026, 58 = 3.957)
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 09-16-2007, 04:03 AM   #19278
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
hey guys,
at the moment im running a GTB/13.5 in my msx. Im using a front one way and a center one way. Soon im going to be running mod with a 4.5. Should i keep the one way in, or use a spool/diff. (i will be running on asphalt)
Cheers
Castle Hill Raceway
surrealmaterial is offline   Reply With Quote
Old 09-16-2007, 04:43 AM   #19279
stokka's Avatar
Originally Posted by surrealmaterial View Post
hey guys,
Cheers
It all depends on the track you are racing on, long curves make it more efficient with one-way. Short sharp turns may make it more efficient with a spool. But all this also depends on your driving style. The only way to find out is to try both
~rune
stokka is offline   Reply With Quote
Old 09-16-2007, 04:48 AM   #19280
ok, thanks....does anyone have the part numbers for a spool and a direct center shaft
cheers
Castle Hill Raceway
Old 09-16-2007, 09:22 AM   #19281
stokka's Avatar
cheers
Actually it's easier if you look in the online manuals at the Tamiya site.
http://www.tamiya.com/english/rc/manuals.htm
The manual for mre is the one containing a spool and the direct center shaft unit.
~rune
Old 09-19-2007, 12:11 AM   #19282
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
guys, what would you reccomend the number of teeth for a pinion of a 415 MSX if i have a 102T spur gear and will be using a 4.5 LRP BL motor, thanks
buboy28 is offline   Reply With Quote
Old 09-19-2007, 01:07 AM   #19283
maxepower's Avatar
Exclamation Gearing for brushless?
The pinion you need for around 9.7 FDR is 23 tooth pinion. Not sure what LRP recommends to start with but I believe that's where my son was running his LRP BL at our local track!
maxepower is offline   Reply With Quote
Old 09-19-2007, 03:23 AM   #19284
buboy28's Avatar
ok, thanks will do that also
Old 09-19-2007, 08:22 AM   #19285
afr0sch's Avatar
Trader Rating: 95 (100%+)
Send a message via MSN to afr0sch
Default Nice MSX up for SALE!
Here is a link to my MSX on the sale thread.
Thanks for looking.
http://www.rctech.net/forum/showthread.php?t=182144
Teaser pic -
afr0sch is offline   Reply With Quote
Old 09-19-2007, 08:25 AM   #19286
afr0sch's Avatar
cheers
I've got a complete MSX center shaft config with the alloy direct drive pulley and spur gear holder I will sell. Also includes the layshaft stopper. Send me a PM if interested. I can send a pic if needed.
Old 09-21-2007, 04:04 AM   #19287
rampal's Avatar
Send a message via MSN to rampal
Is tamiyausa.com out of order??
Iīm trying to get info on the #4004046 lower deck, would like to know if it is for the new MSXX MR or is the one that is used on the stick pack conversion....
cheers,
al
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 09-21-2007, 10:07 AM   #19288
AWK
AWK's Avatar
Where did you get the 4004046 part number from? I have not seen that part number before.
AWK is offline   Reply With Quote
Old 09-21-2007, 11:01 AM   #19289
rampal's Avatar
it just happens that I have the part right in front of me...
I ordered an msx mre lower deck and get this one.... cannot complain at all as it has the 5 cell cutoffs and evo5 bumper.... but also other holes so I was curious....
cheers,
al
Old 09-21-2007, 10:35 PM   #19290
chicmagnet's Avatar
found the answer!
STRAIGHT LTD.
chicmagnet is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
