Old 09-07-2007, 12:01 PM   #19261
miccal's Avatar
Trader Rating: 23 (100%+)
Originally Posted by miccal View Post
You won't have to on the rear. If you have a front one-way, then expect some limit on camber angle with the 46mm shafts. The 42mm shafts are too short with the kit toe blocks, so either get wider ones and use the 46mm shafts, or get shorter ones and use the 42mm shafts.
Originally Posted by Cruisaaja View Post
I solve that different way. If you have problem with 42mm shafts are too short, you can use # 53704 lw one-way joints, because they are longer than regular ones. I use them and no problem at all.
I had not realized that the lightweight cups were longer, thanks for that.
I got the lightweight cups and can now use the 42mm swing shafts with the short arms with no problems- thanks Cruisaaja for the tip.
miccal is offline   Reply With Quote
Old 09-07-2007, 02:02 PM   #19262
RC MARKET's Avatar
TRF415 Blue Alum. Ball Diff.
RC MARKET is offline   Reply With Quote
Old 09-07-2007, 03:16 PM   #19263
kewdawg's Avatar
This appears to be for the rear diff. Is there a front diff coming out, also?
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 09-07-2007, 06:20 PM   #19264
RC MARKET's Avatar
not have release
Old 09-08-2007, 01:01 AM   #19265
miccal. You are welcome
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini M03 - Tamiya 415MSX MRE - Tamiya 416 WE
Cruisaaja is offline   Reply With Quote
Old 09-08-2007, 01:02 AM   #19266
As i remember wright JAAD racing does that.
Old 09-08-2007, 01:49 PM   #19267
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
Hey Quinn, Hope this helps: http://www.precisionrc.com/nv/car/pr...oduct_id=52991
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 09-09-2007, 10:58 PM   #19268
kewdawg's Avatar
Cool. Thanks, guys!
Quinn Moon
Old 09-10-2007, 09:38 AM   #19269
ooliganRC's Avatar
Send a message via MSN to ooliganRC
its probably mentioned before, but what are the main differences between msx and mre...
ooliganRC is offline   Reply With Quote
Old 09-10-2007, 05:28 PM   #19270
Can you get Titanium Ball head? I just never seen them for Tamiya 415.
Clangeddin is offline   Reply With Quote
Old 09-11-2007, 12:27 AM   #19271
ooliganRC's Avatar
check out www.titaniumracing.com some nice bits for 415
damn i should be on commission
Old 09-11-2007, 01:10 AM   #19272
maxepower's Avatar
Default MRE and the MSX=Same but different!
The main differences is the re-designed steering linkage, the centerpulley, spool and belts!
maxepower is offline   Reply With Quote
Old 09-12-2007, 12:18 PM   #19273
Ted B.'s Avatar
Send a message via Yahoo to Ted B.
I guess my local track is going to be running all rubber tires on the carpet this winter which I have never done. Does anyone know of a good setup for the MSXX?
Ted B.
[email protected]
Ted B. is offline   Reply With Quote
Old 09-13-2007, 12:55 AM   #19274
Slidewayz's Avatar
Originally Posted by andyuk99 View Post
Anybody running 13.5T brushless, if so what sort of size spur gear are you using ?
thanks
We can only use the bonded rotor in our 13.5 for our club racing. I use the 102T 64p spur on our short technical track. It runs your pinions to the higher 40 tooth side of things (~ 42mm rollout max available with a 51 tooth pinion) , so I would recommend using a 90 or so 64p tooth spur if your track is longer and calls for more rollout, or if you want greater gear selection.
Tamiya TRF-415 MSX/X (540/GTX), Team Magic E4 (17.5/GTBss), Tamiya TA-04 TRF (3.5/GTB)
Tamiya M03 SWB (3000kV Brushless), JR-Z1 Spektrum & KO Servos. www.lcrccc.com
Slidewayz is offline   Reply With Quote
Old 09-13-2007, 01:14 AM   #19275
TryHard's Avatar
Ted B.
[email protected]
http://www.thard.co.uk/setups/CarpetWars07Rd6.jpg
Try that one. If your lower grip carpet, try using 0.5 or 0mm underneath the suspension blocks. Bear in mind thats for 27t too.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
