Old 08-20-2007, 12:40 AM   #19141
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
Originally Posted by Tek Nickal View Post
Then your IDR is 2.1875. To get close to 10, 88/20x2.1875 = 9.625. And 88/19x2.1875 = 10.132, which is closer to 10. Although 87/19 gets you closest with 10.01.
thanks mate
Castle Hill Raceway
surrealmaterial is offline   Reply With Quote
Old 08-20-2007, 12:48 AM   #19142
quick question, does the Futaba S9550 servo fit in the MSX without any mods?
Castle Hill Raceway
Old 08-20-2007, 01:32 AM   #19143
PizzaDude's Avatar
quick answer: yep it does
PizzaDude is offline   Reply With Quote
Old 08-20-2007, 01:54 AM   #19144
miccal's Avatar
Trader Rating: 23 (100%+)
Originally Posted by buboy28 View Post
miccal, that 415MS stick pack convertion you have what's the part number 49378 and aside from the MS and MSXX any other stick pack convertion chassis for the 415 whew!!! this is getting confusing
There are a total of three stick pack conversion kits:
49341: TRF415 Lower Deck for Stick Type Battery
49385: TRF415MSX Lower Deck for Stick Type Battery
49436: TRF415MSXX Lower Deck Set for Stick Type Battery
The one I have is the first one, since I have a TRF415MS. It is significantly cheaper if you can find it since it only contains the lower deck, battery holders, battery post and battery plate i.e. there are NO bulkheads. This cost me about US$75 from WalaWala Shop (www.valavala.com/) a few months ago.
Note that this one has a 3mm lower deck, since it is in fact for the original TRF415. There was no dedicated stick pack kit for the TRF415MS, which comes with a 2.5mm lower deck. Actually, there wasn't one for the MSX MRE either.
The only problem with the original conversion kit is that the suspension mounts are slightly further apart on the original TRF415 deck, since that chassis did not used the reversible suspension set. The TRF415MS, MSX, MSX MRE and MSXX all use a 3mm by 46mm shaft for the suspension arms, while the original TRF415 used 3mm by 48.5mm shafts for the suspension arms. The part number for these shafts are 9805681 and cost US$5 from RCMushroom (http://rc-mushroom.com/product_info....ducts_id=10327). I had to get these and use extra spacers on the suspension arms, but it wasn't a problem.
The part 49378 is the conversion kit to turn a TRF415MS into a TRF415MSX, and doesn't contain a lower deck.
miccal is offline   Reply With Quote
Old 08-20-2007, 02:30 AM   #19145
miccal's Avatar
Originally Posted by miccal View Post
If I get the short suspension arms (53928) will I need to replace my 46mm swing shafts with 42mm ones? I am running 1A-1B suspension mounts on the front and 1XB-1D suspension mounts on the rear.
To answer my own question, I run a front one-way and had to change the front swing shafts from 46mm to 42 mm when I changed to the short suspension arms. Otherwise the swing shaft pushed too hard into the front one-way cup and the front wheels weren't as free as they should have been. I didn't have to change the rear swing shafts, though.
Old 08-20-2007, 02:36 AM   #19146
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
ok thanks for that clarification very helpful but one last question if i have a 415MSX MRE and i would like to convert it to a stick pack chassis would the MSXX lower deck stick pack chassis (49436) fit as Rnold was asking or should i go with the MSX lower deck stick pack chassis (49385) sorry for a lot of questions just got to be sure before i order thanks
buboy28 is offline   Reply With Quote
Old 08-20-2007, 02:43 AM   #19147
thanks
Castle Hill Raceway
Old 08-20-2007, 04:13 AM   #19148
PizzaDude's Avatar
Originally Posted by surrealmaterial View Post
thanks
Don't know why it shouldn't.....
Old 08-20-2007, 04:37 AM   #19149
miccal's Avatar
If you have an MSX MRE that means you have the new steering system which is different from the standard MSX, correct? If so, then the MSX stick pack conversion won't work because it will only have the holes for the old steering system. Therefore, you would have to get the MSXX stick pack conversion. Keep in mind though that the MSXX has a differently shaped front bumper support (angled instead of straight), so you would have to get the MSXX front bumper The part number is 51253.
Old 08-20-2007, 04:45 AM   #19150
miccal's Avatar
To illustrate, below are the MSX and MSXX stick pack conversions. The yellow box indicates where the steering system is mounted. Note the differently shaped front ends.
Old 08-20-2007, 05:57 AM   #19151
Hey all
I`m back and work again.
I drove 15 times during the last weekend race and i have to say at that 16 ball diff feels like new.
Iīm sure that 18t pulley made drivetrain much sensitive and it felt different vs original.
I drove at Novak ss5800 brushless and SMC IB4200wc cells with 7.5 gear reduction and feel was at my car flies
Kentech use that same diff/pulley combo in his Tamiya, but he drove modified...
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini M03 - Tamiya 415MSX MRE - Tamiya 416 WE
Cruisaaja is offline   Reply With Quote
Old 08-20-2007, 07:09 AM   #19152
buboy28's Avatar
hey miccal, thank you very much it was a lot of help already ordered the MSXX stick pack convertion chassis and the front bumper again thanks
Old 08-20-2007, 07:13 AM   #19153
Xanavi_R34's Avatar
hey sir, where are you ordering from???
TAMIYA TRF416
[Tamiya] [Hot Bodies]
[Futaba] [SpeedPassion] [LRP] [YeahRacing] [3Racing] [Imax]
Xanavi_R34 is offline   Reply With Quote
Old 08-20-2007, 05:36 PM   #19154
Burlap's Avatar
Send a message via MSN to Burlap
You just need to run wider front toe blocks to use the 46mm shafts. I can't remember the combo as such, as the car is at home and I am at work.
Burlap is offline   Reply With Quote
Old 08-20-2007, 05:43 PM   #19155
miccal's Avatar
True, but I don't want to. I run 1B/1A at the front, and I don't want to go any wider. Otherwise, what was the point of the shorter front arms? I think this is a problem only for the front one-way, if you were running a diff or spool then it wouldn't be a problem.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
