Old 08-15-2007, 01:06 AM   #19066
Originally Posted by maxepower View Post
Tungsten Carbide is a harder material than the standard diff balls.
Ceramic is suppose to be stonger and more heat resistant than carbide!
Theoretically speaking of coarse!
That`s wright. I use ceramic balls now a days and they are great for competition.
If diff feel gritty, add some crease time after time and turn diff plates and here we go again
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini M03 - Tamiya 415MSX MRE - Tamiya 416 WE
Cruisaaja is offline   Reply With Quote
Old 08-15-2007, 01:09 AM   #19067
Xanavi_R34's Avatar
what is this ceramic balls??? is this the one that comes with the kits???
TAMIYA TRF416
[Tamiya] [Hot Bodies]
[Futaba] [SpeedPassion] [LRP] [YeahRacing] [3Racing] [Imax]
Xanavi_R34 is offline   Reply With Quote
Old 08-15-2007, 01:30 AM   #19068
Toughbeard's Avatar
For those who want to test massive IR, try to find someone with a kawada around you. I used to own one and I am kicking myself in the head now for selling it. yeeees the support is low and I hear now that Champ has quit working with them (which makes getting parts hard)
but with 1.75 IR that car just flies. I used to run 23T in mod class with it. massive 24 center pulley
I may end up building a 20T center pulley for kicks and try it out... but mostly I would want it for stock racing.
but I have to admit that the car handles and drives so well at the moment that I dont feel like changing and major components. I had major problems with motors and electronic last weekend. I had a novak 4.5 literally blow up. Then I blow up a 10T and finally the ESC cut off for good. and I basically gave up and packed my stuff
one of the problems I have with this car is the 9x5 bearings. they just can not support the axles which wobble around like crazy. I have gone through probably about 10 sets already.
the other is the shock plastics, which have massive play in them. I ended up exchanging the sway bar ball ends with the shock ball ends to remove the bottom play but the top still has it. to solve the prblem I will get my self a set of new TM shocks.
well I am going back to dismantling my car...
Toughbeard is offline   Reply With Quote
Old 08-15-2007, 01:33 AM   #19069
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Ceremic ball is lighter, last longer than Tungsten Carbide ball.
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 08-15-2007, 01:36 AM   #19070
rampal's Avatar
Send a message via MSN to rampal
steel came with the kit.... ceramic is optional.
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 08-15-2007, 01:42 AM   #19071
rampal
Did you already made that new diff?
Old 08-15-2007, 02:04 AM   #19072
where do you guys get the cermaic balls?
chumanji is offline   Reply With Quote
Old 08-15-2007, 02:11 AM   #19073
PizzaDude's Avatar
Dude,
If you'ld use the 18t center pulley and a TA-04 diff pulley
you'ld get 32/18=1.77 int ratio!
PizzaDude is offline   Reply With Quote
Old 08-15-2007, 02:17 AM   #19074
TryHard's Avatar
And after workday i`ll make that new 18 ball diff
Well, I've got the parts on order to do this now too.
And also the 501x 18t centre pulleys... I'll try this all out at the forthcoming KO GP over here in the UK, be intrigued to see if I can notice a difference.
BTW, I'll have an updated version of the gear chart on my site soon, will have charts for the many different pulley combinations (35/16, 36/16, 35/18, 36/18 etc)
Ed
| THard.co.uk | Xray | MuchMore |
Old 08-15-2007, 02:52 AM   #19075
Ed
Tryhard
Long time to see you
I have everything already, but no time to do it. Maybe tonight...
We have race weekend, so i`ll try that 18t center pulley fixing and new 16 ball diff if weather allows it
Old 08-15-2007, 05:15 AM   #19076
C van der Hagen's Avatar
Default diff
It's 16 balls, not 18!
And you can made it with just xtra balls and the TRF501X diff plates. Use a regular TA05 pulley (not the wide pitch). No modification is needed!
Just put in every hole a diff ball (16x) and use the large diff plates. The diff will be smoother and last longer!
C van der Hagen is offline   Reply With Quote
Old 08-15-2007, 05:23 AM   #19077
Default diff
Old 08-15-2007, 05:29 AM   #19078
Oops, sorry my bad. I ment 16
Old 08-15-2007, 07:18 AM   #19079
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Originally Posted by Rnold View Post
guys, would the trf415 msxx lower deck set for stick type battery in the attached picture fit the mre? will this chassis be able to accept side-by-side packs, stick type battery, lipo 3200's and lipo 4800's?
i do hope that it fits for i also have the MRE and i've already ordered the MSXX stick type chassis for my MRE
buboy28 is offline   Reply With Quote
Old 08-15-2007, 09:07 AM   #19080
peejay's Avatar
I assume that you are suggesting that there should be 2 rings of 8 balls, rather than drilling 8 extra holes in the outer ring? Have you done this?
If the holes in the inner ring are the correct size it seems to me a better bet than trying to accurately drill more holes in the outer ring. If I tried that I might have to corner the market on TA05 pulleys
peejay is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
