Old 07-25-2007, 09:55 AM   #18916
1shnot's Avatar
could someone tell me part# for mre bulkhead upper brace (heatsink)? and best place to get it?
1shnot is offline   Reply With Quote
Old 07-25-2007, 04:57 PM   #18917
rctouringracer's Avatar
Send a message via Yahoo to rctouringracer
The part number is 3454404 and I got mine from Tamiya parts.
rctouringracer is offline   Reply With Quote
Old 07-25-2007, 05:30 PM   #18918
Burlap's Avatar
Send a message via MSN to Burlap
Are you talking about the aluminum piece that goes over the centre shaft? The MRE version?
Burlap is offline   Reply With Quote
Old 07-25-2007, 06:59 PM   #18919
Vicko's Avatar
Trader Rating: 14 (100%+)
so about what weight shock oil are most using outdoors
on and long, big smooth, high traction track in the us?
Vicko is offline   Reply With Quote
Old 07-26-2007, 02:59 AM   #18920
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
what is the part number of the MSXX stick pack type chassisthanks
buboy28 is offline   Reply With Quote
Old 07-26-2007, 10:58 AM   #18921
JayL's Avatar
Just go with the Cory Lewis setup from tamiyausa.com...
500wt F&R
JayL is offline   Reply With Quote
Old 07-26-2007, 11:06 AM   #18922
Toughbeard's Avatar
Originally Posted by miccal View Post
I recently replaced the C-hubs on my trf, which I initially purchased second-hand and hence already put together. Since then, I have had trouble with the BB2 screws that go in the bottom of the C-hubs as circled in the picture below, which keep falling out. Is there a trick to getting these screws to stay in place?
I have the square aluminium knuckles and had the same problem. the only cure is loctide. but make sure you dont put too much or you will risk gluing the whole assemble to gether. use tamiya thread lock as it is tacky to start with you will instantly know if you got it in the wrong place.
But dont take it for granted and check to see if it is secure before your races.
Toughbeard is offline   Reply With Quote
Old 07-26-2007, 11:14 AM   #18923
Toughbeard's Avatar
Originally Posted by Tral View Post
Hello
Can you give me some advice how to setup my MRE for European Championships in Montbrison?
Will Mazda6 Protoform be good?
One way or spool?
What oil and pistons?
Thank you in advance and see you in Montbrison.
I dont know the track but I won my last race with Rhinehard 2006 setup for eds web site. I just didnt use the toe block spacerson the buttom and the wheel spacers.
40 wt 2 hole yellow springs all around. urethane bussing on the front shocks none on rear. yellow sway bars . it was dialed in rocket.
track was wide smooth with medium grip at around 25 degreesC with medium to high winds...
for a tight track I will use a oneway setup. make sure car is not tweaked.
Old 07-26-2007, 12:19 PM   #18924
RC MARKET's Avatar
ASSO 40W
RC MARKET is offline   Reply With Quote
Old 07-26-2007, 04:12 PM   #18925
Vicko's Avatar
500wt F&R
is that 50wt in the usa shock oil? like losi or assc
Old 07-26-2007, 04:48 PM   #18926
JayL's Avatar
no, it is 500wt... the rest of the world has to be different , , so they measure shock oil different as well.. the tamiya oil comes in these weights, which the team uses.....
Old 07-26-2007, 07:01 PM   #18927
Vicko's Avatar
well what dose 500w tamiya convert to the oil that everyone else use?
Old 07-27-2007, 12:52 AM   #18928
peejay's Avatar
A good guess would be 50
peejay is offline   Reply With Quote
Old 07-27-2007, 09:47 AM   #18929
Hebiki's Avatar
Trader Rating: 26 (100%+)
the good thing about Tamiya oils is that they're colored. so if you forget what oil you were running with the other brands, your stuck rebuilding your shocks. with Tamiya, just reference the color to the appropriate weight.
yellow - 400wt is "supposed" to be equivalent to 40wt oil. etc.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-27-2007, 10:44 AM   #18930
JayL's Avatar
they are not a direct conversion 400 isn't = to 40
there is a chart somewhere, maybe tryhard's site
Why do you want to run 40wt's? you have alot of them?
I would reccomend going with the 100's weights as then you can use and/or start from the team setups...
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
