Old 06-20-2007, 06:19 PM   #18676
Tek Nickal's Avatar
I wonder how he got steering with that car, the roll centers are super low, the front shock is placed in hole 1, and there's a very thick sway bar in the front. Do you have his setup sheet?
Tek Nickal is offline   Reply With Quote
Old 06-20-2007, 10:22 PM   #18677
Trader Rating: 62 (100%+)
Anyone know who makes that servo horn?
patrick is offline   Reply With Quote
Old 06-21-2007, 12:17 AM   #18678
Eirik's Avatar
The roll centers are standard setting actually and the swaybar is the one that comes with the MRE, 1.4mm
Eirik is offline   Reply With Quote
Old 06-21-2007, 12:21 AM   #18679
Eirik's Avatar
Hybrid makes the blue alu piece, the rest is Tamiya Servo Saver parts.
Old 06-21-2007, 03:23 AM   #18680
TryHard's Avatar
hmm... thoose are new rear hubs on satoshi's & Kiyo's car. There's no third setting (outer) setting hole..
| THard.co.uk | Xray | MuchMore |
Old 06-21-2007, 03:26 AM   #18681
Eirik's Avatar
Hard to tell what else is different, but I hope they have 10x5 bearings inn there
Old 06-21-2007, 05:40 AM   #18682
ttso's Avatar
It looks like outbound toe-in is bigger than 1', hopefully it's 1.5 or 2' outbound toe-in on upright.
ttso is offline   Reply With Quote
Old 06-21-2007, 07:02 AM   #18683
TryHard's Avatar
doubt it... XB/D is 3 toe in anyway... why you'd want to run more i don't know.
I'm pretty sure all the cars since the MS come with 0 rear hubs anyway...
I tried running toe-in rear hubs a while ago, have to say I prefered how the car felt using the 0 hubs instead.
Old 06-21-2007, 07:45 AM   #18684
Eirik's Avatar
Running 2 innboard + 1 outboard toe inn (3 total) will have more sidebite and less forward traction than 3 innboard toe inn.
Normally, the car will feel more responsive with innboard toe inn.
Outboard toe inn will make the car very easy to drive (mild steering) works good when a one-way is used
Old 06-21-2007, 08:18 AM   #18685
jordan.norwood@ is offline   Reply With Quote
Old 06-21-2007, 09:27 AM   #18686
ttso's Avatar
I checked my 0' alum upright. It seems the prototype's 2 ballhead holds are in middle of 3 holds on 0' alum upright. Maybe it's something just relocate the hole?
As for outbound toe-in, I always run 1' outbound toe-in as I found it loose rear onpower quite well, compared with 0' outbound toe-in. I acturally wanna get Square's 1.5' outbound toe-in upright to see if I can get rear rotate more.
Old 06-21-2007, 11:12 AM   #18687
JayL's Avatar
speed racing also makes the blue alum servo horn part, precisionrc has it.
They probably got steering on they car by using brakes heavy.....I always have steeering in mod due to brakes throwing weight forward
JayL is offline   Reply With Quote
Old 06-21-2007, 12:53 PM   #18688
RC MARKET's Avatar
http://rcmarket.com.hk/index.php?cPa...tutj16441k24f0
RC MARKET is offline   Reply With Quote
Old 06-21-2007, 01:02 PM   #18689
Eirik's Avatar
I think I just found out the difference....
The holes are in the same place, But the distance between the bearings are greater.... this will for sure put less stress on the bearings
You are right about the outboard toe, it will give more on power steering and less off power steering/initial steering.
Old 06-21-2007, 03:42 PM   #18690
Tek Nickal's Avatar
Then I guess they're coming out with new rear axles too. So many new parts yet to be released.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
