Old 06-10-2007, 09:06 AM   #18616
Goingfast's Avatar
Trader Rating: 29 (100%+)
Originally Posted by RC MARKET View Post
You need change lower & upper deck & steering parts !
Do you have the list of parts number ? Thanks
Goingfast is offline   Reply With Quote
Old 06-10-2007, 01:40 PM   #18617
RC MARKET's Avatar
sorry we only have MSXX
RC MARKET is offline   Reply With Quote
Old 06-10-2007, 01:48 PM   #18618
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
here is the supplement for the MRE manual
http://www.tamiya.com/japan/rc/rcman...4trf415msx.pdf
here is the MSXX manual
http://www.tamiya.com/japan/rc/rcmanual/trf415msxx.pdf
you can find all the part #'s there
MSXX has a thinner lower deck and a flexible upper deck also has the air duct
MRE has the thicker lower deck, and a stiffer upper deck
Both have the same steering.
tamiyarcracer is offline   Reply With Quote
Old 06-10-2007, 03:13 PM   #18619
TryHard's Avatar
Originally Posted by TryHard View Post
I can see on the pics with the steering, few quick Q's... is that simply the bell cranks flipped, with the brace mounted underneath? or is it fully raised up a few mm... it does look like they are mounted higher on the posts though, so I'm guessing second option. how much is it raise by?
You can just see the milling on the motor mount in one of the pics too. How much did the guys take off?? 1-1.5mm?
Cheers
Ed
Originally Posted by sohlman View Post
Hey Ed,
Yes, the bellcranks/posts were just flipped and raised enough that Marc ran his transponder on the lower deck, right side, and the bellcrank would swing over it. Not sure exactly how much though.
And the bulkhead was milled about 1mm.
Been looking at the steering again.
Just tried flipping the bell cranks over, and running them higher, as per the pics of Marc's and Mazeumi's cars. Assuming they aren't using new steering posts... the steeringball joints end up in the same place, 10.4mm above the chassis plate. And guess what, same height with the standard MRE setup
I'm guessing then that the steering setup run at the reedy is too help out on belt clearance as well... and PT.
regards
Ed
| THard.co.uk | Xray | MuchMore |
Old 06-12-2007, 09:58 AM   #18620
sohlman's Avatar
Trader Rating: 89 (100%+)
regards
Ed
Hey Ed, did you run it yet?
Steve Sohl
sohlman is offline   Reply With Quote
Old 06-12-2007, 11:39 AM   #18621
rtypec's Avatar
Stephen, nice Daijiro avatar
rtypec is offline   Reply With Quote
Old 06-12-2007, 12:22 PM   #18622
sohlman's Avatar
Thanks Rod and good catch. Check out the driver on my 1/8th onroad body...more Daijiro. And my motorcycle helmet. He was too young to die...RIP.
Steve Sohl
Old 06-12-2007, 01:17 PM   #18623
rtypec's Avatar
Agreed...I believe David Jun also has the same helmet that you have. How's that saying go? Great minds...are in the gutter?
Well as for me....
Old 06-12-2007, 04:07 PM   #18624
TryHard's Avatar
No not yet, was just mucking about with my car last night, fitting a few treats to it, and thought I'd see how that steering setup works. All you really need is some cut steering collars from an Evo5 to make it work (to stop the bell cranks riding up the posts).
Not racing at all at the moment, last time I ran was over a month ago, and won't be racing again till mid july. Taking the time to give my car a bit of a re-fresh (new drivtrain components etc), and testing out little bits like the steering.... that is when I'm not in the gym or out sailing. Got a Worlds I'm training for you see... (it's me in the red top)
Regards
Ed
Old 06-13-2007, 02:16 PM   #18625
razzor's Avatar
I have a 415MS and have damaged lower chassis.Id like to know if the MSX or MRE chassis would fit.
Seems our local agent cant get spares for the MS.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-13-2007, 03:06 PM   #18626
RC MARKET's Avatar
41?
Old 06-13-2007, 03:11 PM   #18627
SpeedTech's Avatar
I don't think the MRE would fit because the steering system is different on the MRE...I'm not sure about the MSX. I'm sure some of the other guys on here are more knowledgeable than I am, but definitely a no on the MRE.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 06-13-2007, 03:13 PM   #18628
SpeedTech's Avatar
Regards
Ed
WOW
Good luck Ed!
Steve Wang
Old 06-13-2007, 03:19 PM   #18629
TRF415boy's Avatar
MRE chassis will fit and be the same thickness, the msxx chassis will also fit but is 2mm thick only so it will have more flex, which you may or may not want depending on the surface and tyres you race on.
TRF415boy is offline   Reply With Quote
Old 06-13-2007, 03:23 PM   #18630
TRF415boy's Avatar
Steve Wang
That's what's good with tamiya 415 series, the new chassis still have the holes for the old steering and posts etc... So you can use the new chassis plates on the standard 415 or the MS/MSX.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
