Old 05-30-2007, 04:14 PM   #18541
Toughbeard's Avatar
Originally Posted by bilmec
carking, thanks for the pics.
reversible suspension set includes 5x9x4 bearings. But all online shops sell 5x9x3 bearings.
can i use this bearings?
you can get those bearings fron Altuntaş in Karaköy. I have about 12 left in my box as they keep blowing up. I gave a set to Deyvi in Ankara race. mind though they are alittle expensive here as they are off size bearings.
order them from one of the online shops and in the mean time I can replace the ones you have broken. You can replace mine when you receive yours...
Serdar Aytemiz
Racing since the 20th century
Toughbeard is offline   Reply With Quote
Old 05-30-2007, 05:38 PM   #18542
nexxus's Avatar
Trader Rating: 302 (100%+)
Use the bearing spacers that Tamiya has out for the wheel hubs, they help a lot. My bearings are around a yr old, and still fine, just upgrading the wheel bearings to Ceramics and be interested to see how they go.
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 05-30-2007, 06:04 PM   #18543
rtypec's Avatar
Hi All...For those of you who are interested in the setup I ran at the Reedy Race, please have a look at the attached setup sheet. Keep in mind there are small notes on the sheet regarding which ball nuts were used. This setup feels very good but can get a little loose if over-driven . I've also attached a picture of the car for reference.
Here is video shot by Mr.McGoo (thanks man!) that shows it in action.
Reedy Race Modified A-Main 1
Let us know if you have any questions.
Enjoy!
rtypec is offline   Reply With Quote
Old 05-30-2007, 06:32 PM   #18544
Tsquare's Avatar
Enjoy!
Rod - Thanks for posting your setup, your car looked good at the Reedy.
Tsquare is offline   Reply With Quote
Old 05-30-2007, 07:41 PM   #18545
Island Losi's Avatar
any shims used under the front upper camber link on the caster block?
Island Losi is offline   Reply With Quote
Old 05-30-2007, 07:45 PM   #18546
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
I don't know of anyone that uses a spacer there. seeing as that ball mount is the king pin.
tamiyarcracer is offline   Reply With Quote
Old 05-30-2007, 08:07 PM   #18547
thanks
Old 05-31-2007, 01:07 AM   #18548
DRAG_ON's Avatar
anyone can please help-- i'm planing using MRE wide pitch pulley (white) -- for front spool and rear diff. Do i need to change the belt? currently i'm using MSX belt........
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
Old 05-31-2007, 01:12 AM   #18549
Enjoy!
Rod
You didn`t make the same things to your car like Marc did. Any way, you did well
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini M03 - Tamiya 415MSX MRE - Tamiya 416 WE
Cruisaaja is offline   Reply With Quote
Old 05-31-2007, 01:31 AM   #18550
rampal's Avatar
Send a message via MSN to rampal
Enjoy!
excellent!! Rod, quick request, can you please post a picture of your car from the "other" side?? It seems you're not using the air scoop and where the hell did you put the GTB condenser?? It looks indeed a very clean setup!!
Another question, if you don't mind.... how much weight your car end up with? I've noticed you have some lead around... did the Reedy have any weight limitation (more than 1350g) or that was just for balancing the car?? and you're using hotbodies sway bar holders, right??
thanks a lot,
al
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 05-31-2007, 02:02 AM   #18551
TryHard's Avatar
Enjoy!
Cheers Rod,
One question, how was your steering setup? spacers behind ball joint, type of ball joint used etc
Cheers
Ed
| THard.co.uk | Xray | MuchMore |
Old 05-31-2007, 05:37 AM   #18552
U guys mentioned that u are useing 3racing pulleys?Do any of u know where i can find some and what all do I need to do the conversion?I have an 415 msxx.Thanx
TOP Racer is offline   Reply With Quote
Old 05-31-2007, 06:36 AM   #18553
Originally Posted by stuey
you can get the 3 racing pullys and use cyclone belts
Newbie question. Tell me how you can use cyclone belts with that 3-racing 18t pulley, because cyclone`s own centerpully is 16t?
Or is it diffpulleys different?
Old 05-31-2007, 06:40 AM   #18554
Eirik's Avatar
Cyclone's diff pulleys are 39t, so that's why they are slightly longer
Eirik is offline   Reply With Quote
Old 05-31-2007, 06:48 AM   #18555
RC MARKET's Avatar
if use 17 or 18T need change other belts !
RC MARKET is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
