Tamiya TRF415
That gearing should work fine. If the track is real tight, you could drop a tooth but you'll lose a little of the top end depending on the size of the straight. The novak 5.5 is worth checking out also. That motor is real smooth.
Originally Posted by J Stark
Frost: For the 4.5, try 102 x 25. That should get you real close.
I will start with 22 pinion it gave you FDR 10.13 and latter on you can increse the pinion
I think you missed my point. Just making a joke
Originally Posted by Tek Nickal
No kidding, there is an ultra hard spring.
Originally Posted by Toughbeard
looks like coming fresh out of the pimp my ride show...
For the TA05MS, I hope this wont be the 416 setup... I think the center motor mount pushes the batteries outside plus you have to route your receiver wires around the motor which is always a pain.
For the 416 All I want to see is stuff added to the Avid. Form fit chassis so stuff wont move around, large axle bearings (Ill live with the old 5x11s), some sorf of boot over the cvds and for god sake toe blocks with degrees on them not the alphabet...
Wouldn't mind bigger bearings (10x5's seem pretty standard on a lot of other cars).
But the toe blocks, I certainly prefer the current system and for a good reason. Because you can adjust both the front and rear block, how can you say that one block gives x-amount toe-in. If your running a narrower front block, and then change to another rear block, you just going to get confused by numbers... and which one do you call as 0°? Currently you just need to remember the order they go (E, D, C, B, A, X, XA, XB, XC, XD wide - narrow) and that theres 0.5deg between each block. Quite simple in my book really.
Regards
Ed
that gearing should work just fine i guess if your a really smooth driver because i have never seen jstark thermal once
Hi,
I have 415MRE. Want to know what is the part number for the rear ball pulley WP? And what is the part number for non WP?
Originally Posted by ioxqq
Hi,
http://rcmarket.com.hk/product_info....roducts_id=475
Anyone know if this will fit the MSX? http://cgi.ebay.com/TOBEE-20700-Reve...QQcmdZViewItem
I get confused with what fits from the TA05 parts.
Thanks!
Thanks!
Thanks!
Thanks!
IC. Thanks Bro!
Originally Posted by TryHard
Agreed on the 416 vs 05MS.... my opinion is that a) the motor is too far forward, b) with it so far forward it pushes the batteries off centre.
Regards
Ed
Regards
Ed
on a second note I probably wouldnt said that if I had the blocks I have now all arrived yesterday. I am confused, yes, but I ll Live....
one question though. I have checked your web site and you have the blocks listed. you have the widths of the blocks do you have the total width of the car with certain blocks... (For ex. say if you put 1D on the back you are at 189mm and so on... etc..)
By the way any news on the 416 yet...
back to the 415 topic, anyone with a gtb that would like to post a picture of its installation on the mre or msxx? what to do with the lousy cap? every installation I think ends up with the cap flying around... anyone with a 'clean' one?
moreover, any hint for a start point on the gear ratio for a 3.5R 5 cell?
thanks!
cheers,
al
thanks!
cheers,
al
thanks!
cheers,
al
thanks!
cheers,
al
Internal ratio on MSX: 2.187, 102-spur/21-pinion*(2.187-internal ratio)=10.62 FDR, this FDR ration i think is not a good starting point, you might risking thermal shoutdown.
The solution is to change larger spur gear--i change mine to 48pitch using 79 spur gear and 15 pinion, this is also the smalest pinion i can go, below 15 pinion wont touch the spur either..............
With 79 spur gear, the spur sit just right............i think 80T spur gear will also fit but risking the spur damage easily, because it sit really on the bottom of the chasis.........
here are a couple of pics of my mre:
vic
vic
thanks!
cheers,
al
thanks!
cheers,
al
