Old 05-14-2007, 09:09 AM   #18346
TryHard's Avatar
Have to mention, I've had a quick look at the TA05 ones... pretty good, might have to get a set and chop off the middle section
| THard.co.uk | Xray | MuchMore |
Old 05-14-2007, 10:52 AM   #18347
JayL's Avatar
I cut a chunk or really dense foam and put it over the sway inside the mount, similar to the way a real car has sway bar bushings. this allows the mount to rotate but still not have play
JayL is offline   Reply With Quote
Old 05-14-2007, 02:48 PM   #18348
rampal's Avatar
Send a message via MSN to rampal
Originally Posted by TryHard
yeah, you actually did it... so Ed, did you notice any difference? If not, I will try that foam trick... the thing is how on earth tamiya haven't think on that??
cheers,
al
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 05-14-2007, 02:58 PM   #18349
Tek Nickal's Avatar
I use Yokomo sway bar mounts on my car. Fits exactly the same way, and it has a setscrew. The only thing is that it doesn't fit the hardest sway bar.
Tek Nickal is offline   Reply With Quote
Old 05-14-2007, 03:01 PM   #18350
rampal's Avatar
can you please give me the part number?? need to check them... anyway, don't think I will ever use the thicker one, as I'm running asphalt... thanks!
al
Old 05-14-2007, 03:39 PM   #18351
TryHard's Avatar
cheers,
al
It does help... they have had set screw mounts on both the evo4 and 5, I guess it's just one thing that the 415 is missing...
Regards
Ed
Old 05-14-2007, 08:07 PM   #18352
gijoe64's Avatar
Trader Rating: 30 (100%+)
My MSXX Ready for the REEDY RACE!!!!!!!!!!
Tamiya TRF415-000_0263.jpg   Tamiya TRF415-000_0262.jpg   Tamiya TRF415-000_0261.jpg   Tamiya TRF415-000_0260.jpg   Tamiya TRF415-000_0259.jpg
gijoe64 is offline   Reply With Quote
Old 05-14-2007, 08:11 PM   #18353
gijoe64's Avatar
Hey guys I will be using MR setup at the Reedy but in 19T were should I gear my car at with the stock spur. Thanks!!
Old 05-14-2007, 09:48 PM   #18354
drew85's Avatar
5.8 for reedy motor
drew85 is offline   Reply With Quote
Old 05-14-2007, 11:12 PM   #18355
maxepower's Avatar
Exclamation pinion size?
Use a 40 or 41 pinion. I'm assuming the spur is a 102 tooth. Right?
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 05-14-2007, 11:35 PM   #18356
nexxus's Avatar
Trader Rating: 302 (100%+)
40 or 41? Damn, I can't gear a Sports Tuned over a 38 without it dying after one race!
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 05-14-2007, 11:50 PM   #18357
Hebiki's Avatar
Trader Rating: 26 (100%+)
102/41 is only 5.59FDR on the tamiya track
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 05-15-2007, 12:31 AM   #18358
Eirik's Avatar
cheers,
al
Having your swaybars mounted correctly is important!
It's very easy to upset the balance and handling of the car when it's not 100%
Jet Racing makes some of the finest swaybar mounts, you can get them here: RC Models
Eirik is offline   Reply With Quote
Old 05-15-2007, 05:14 AM   #18359
gijoe64's Avatar
Yes my spur is 102. thanks
Old 05-15-2007, 11:42 AM   #18360
Ted B.'s Avatar
Send a message via Yahoo to Ted B.
Does anyone know where to get a stiffer front sway bar for the 415MSXX?
Ted B. is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
