Old 05-10-2007, 05:43 PM   #18286
TryHard's Avatar
Originally Posted by Hebiki
thanks ed... ive havent had a chance to play around with it TBH. but i will on saturday. my car is pretty stuck for initial steering, but i dont want to sacrifice rear traction.
worse comes to worse.. ill just JAM on the brakes if i need to dive into a corner.
ill try those things this weekend tho and let you know what i find.
You could also play with the shims behind the steering ball joints... more shims should equal more steering.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 05-10-2007, 05:58 PM   #18287
Hebiki's Avatar
Trader Rating: 26 (100%+)
HiH
Ed
did that last weekend! i settled on front holes on the knuckles and having 1mm behind the ball studs instead of the stock "silver" spacer.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 05-10-2007, 06:31 PM   #18288
chris_morrison_'s Avatar
Originally Posted by secretsg
Has anyone got a pic of the MSXX stick pack lower deck? #49426. I want to see if it will allow me to use lipo packs on the mre without grinding the aluminum.
If you use the chassis and bulk head from the stick pack conversion you do not have to grind any material away.
one local racer has done that conversion for lipo.
chris_morrison_ is offline   Reply With Quote
Old 05-10-2007, 07:03 PM   #18289
Burlap's Avatar
Send a message via MSN to Burlap
Shim under the front = Kick-up + increased castor.
I did some measuring, and to get as near as dammit 1 increase in castor, you need 0.8mm of shims under the block. Increasing the kick up helps the car deal with bumps, and gives a bit more mid-corner speed, but takes away some intial
Shim under the rear = Anti-dive + reduced castor
Helps to transfer weight to the front of the car. Also the reduced castor helps increase initial turn-in, at the expense of a little mid corner.
I found anti dive good on a track which had quite a few tight hairpins, as it helped get the nose tucked in quickly. Also useful when running a spool, helps increase counteract the lose of initial steering inherent when running one.
TBH though, I haven't played with this option much since getting the MRE... although I might start to try some kick-up, been looking for a little more mid-corner recently.
HiH
Ed
Thanks for those tips, I can never get anyone at the track to clearly say what the changes to the angle of the toe blocks do.
Burlap is offline   Reply With Quote
Old 05-11-2007, 10:25 AM   #18290
rctouringracer's Avatar
Send a message via Yahoo to rctouringracer
Could you'll give me some suggestions on start up gear ratios for my new bl set-up? I have a MSX with the 36tooth wide pitch pulleys installed. I'm installing a Novak 13.5 with the Novak GTB. I am running on an asphalt track with about 100ft of straight-away.
Thanks in advance...
Burned up
JoeRacer Graphix
Wanna Bee Racing
rctouringracer is offline   Reply With Quote
Old 05-11-2007, 11:06 AM   #18291
Hebiki's Avatar
ive heard "rumors" of people gearing the 13.5 around an FDR of 5.0
with a 102 spur on the MRE/MSX you would need a 45/46T pinion
102/45 x 2.25 internal = 5.1 FDR.
a friend of mine ran his at 4.8 on a similar sized parking lot track.
Hebiki Design Works
Old 05-11-2007, 11:12 AM   #18292
Thanks!
Burned up
JoeRacer Graphix
Wanna Bee Racing
Old 05-11-2007, 11:24 AM   #18293
Chris no rumors it's a fact we have had them down to 4.8 on some of our layouts at SIR
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 05-11-2007, 11:25 AM   #18294
Hebiki's Avatar
well there it is! i always leave myself with an out dont want to get blamed.
4.8 FDR it is.
Hebiki Design Works
Old 05-11-2007, 11:40 AM   #18295
hierog's Avatar
I second that! I'm running 4.79 at Speedworld - 98 spur, 46 pinion!
hierog is offline   Reply With Quote
Old 05-11-2007, 01:37 PM   #18296
Toughbeard's Avatar
I thought the MRE was 2.187 internal
What was your tire diameter 62? 63? is that for 13.5BL?
Last weekend I raced at the track using a 10x2 against the 3.5 and 5.5 bL systems. I was running 76Sx26P and 62.5mm tires (6.39 FDR using 2.187 internal) the motor needed cutting after each race but managed to finish 2nd over all on triple Amain.
Serdar Aytemiz
Racing since the 20th century
Toughbeard is offline   Reply With Quote
Old 05-11-2007, 01:43 PM   #18297
TRF415 Chassis with TA05 16T center pulley and TA05 36T Diff pulley gives you 2.25.
trf_racer is offline   Reply With Quote
Old 05-11-2007, 02:23 PM   #18298
Toughbeard's Avatar
Well the MRE has the 35Diff 16Pulley
do you change the diff pulley because the 36 is stronger? or just to change the internal...
Serdar Aytemiz
Old 05-11-2007, 02:27 PM   #18299
Stein Tumert's Avatar
The MSX is 2.187
The MRE is 2.25
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 05-11-2007, 02:32 PM   #18300
Toughbeard's Avatar
So that means I calculated wrong but doesnt matter in the end all was calculated wrong and the out come was right Did that make anysense to you
ok back to my original question
you guys use 4.7 - 5 FDR for 13.5BL using (assuming here) 62 - 63 mil tires?
Serdar Aytemiz
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
