Old 05-09-2007, 08:54 PM   #18271
Leester's Avatar
Trader Rating: 21 (96%+)
Hello Folks.
I would like to know what the difference is between the 415MSXX and the original 415MSX. Like chasiss, suspension, bulkhead's etc. Cause i'm thinking of buying the 415MSXX
-Lee
Leester is offline   Reply With Quote
Old 05-09-2007, 09:01 PM   #18272
Originally Posted by Leester
Hello Folks.
-Lee
This question has been asked many times
TRF415MSXX has 2.0mm lower deck, compared to 2.5mm of MSX. MSXX has a newly shaped upper deck, new belts, wide pitch pulleys, air duct, new bumper. Everything else is pretty much the same.
trf_racer is offline   Reply With Quote
Old 05-09-2007, 09:39 PM   #18273
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
And last but not least:
The newer style steering.
tamiyarcracer is offline   Reply With Quote
Old 05-09-2007, 09:51 PM   #18274
nexxus's Avatar
Trader Rating: 302 (100%+)
Different Centre Pully and Pully cover, also uses the nex Hex head ball connectors not the older style that used a 5.5mm nut wrench to tighten.
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 05-09-2007, 09:58 PM   #18275
Kenneth Tan's Avatar
416?
http://www.rczone.net/modules.php?na...rticle&sid=813
Kenneth Tan is offline   Reply With Quote
Old 05-09-2007, 11:16 PM   #18276
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Kenneth Tan
we have to wait until the Shizuoka hobby show. they always unveil a lot of stuff at that show!
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 05-10-2007, 04:09 AM   #18277
TryHard's Avatar
My bet... wait for the Reedy Race, seem to have been a favourite event to debut a new car there (415, MSX, and MRE all were first run there).
| THard.co.uk | Xray | MuchMore |
Old 05-10-2007, 04:14 AM   #18278
TryHard's Avatar
Originally Posted by veecee
Nice one Ed. So did you run the front end narrower in that case or did you shim it back out? And I'm guessing you used 42mm drive shafts? Dropped a one-way back into my MRE converted MSX. See how it goes tomorrow night...
Nope, everything standard MRE in that respect. 0.5mm shims on the axles, and 46mm driveshafts.
Had no issues at all.. but then again, I didn't check :P Also used an original 415 centre oneway setup, don't have the parts from the MSXX yet.
HiH
Ed
Old 05-10-2007, 04:29 AM   #18279
nexxus's Avatar
I ran an MSXX spec One Way on the weekend (well MSXX shaft and standard holders, TA05 one way pulley) all went well, not shimmed right though, didn't have enough shimmy thingys!
Old 05-10-2007, 07:12 AM   #18280
veecee's Avatar
Trader Rating: 34 (100%+)
HiH
Ed
I might have to give that a try then. Going back to a front one-way made a world of difference the other night... The car turned in well and and the short arms maintained the line through the rest of the turn. I added some anti-squat at the rear (0.5mm shim under the front block in the rear enf) and this gave me even more steering. Much more like it!
SMOKEM --- XPRESS --- MONTECH --- SRT
veecee is offline   Reply With Quote
Old 05-10-2007, 08:43 AM   #18281
Old 05-10-2007, 09:40 AM   #18282
Hebiki's Avatar
there goes TRF_Racer posting his secret ninja pictures again.
tryhard... you seem to be the most experienced with the 415 here.... have you experimented with adding a shim to the front blocks? (either the front rear, or the front front).
curious to see what effects it had in your set up.
Hebiki Design Works
Old 05-10-2007, 03:07 PM   #18283
TryHard's Avatar
Shim under the front = Kick-up + increased castor.
I did some measuring, and to get as near as dammit 1 increase in castor, you need 0.8mm of shims under the block. Increasing the kick up helps the car deal with bumps, and gives a bit more mid-corner speed, but takes away some intial
Shim under the rear = Anti-dive + reduced castor
Helps to transfer weight to the front of the car. Also the reduced castor helps increase initial turn-in, at the expense of a little mid corner.
I found anti dive good on a track which had quite a few tight hairpins, as it helped get the nose tucked in quickly. Also useful when running a spool, helps counteract the lose of initial steering inherent when running one.
TBH though, I haven't played with this option much since getting the MRE... although I might start to try some kick-up, been looking for a little more mid-corner recently.
HiH
Ed
Old 05-10-2007, 04:00 PM   #18284
secretsg's Avatar
Has anyone got a pic of the MSXX stick pack lower deck? #49426. I want to see if it will allow me to use lipo packs on the mre without grinding the aluminum.
secretsg is offline   Reply With Quote
Old 05-10-2007, 04:02 PM   #18285
Hebiki's Avatar
I found anti dive good on a track which had quite a few tight hairpins, as it helped get the nose tucked in quickly. Also useful when running a spool, helps increase counteract the lose of initial steering inherent when running one.
HiH
Ed
thanks ed... ive havent had a chance to play around with it TBH. but i will on saturday. my car is pretty stuck for initial steering, but i dont want to sacrifice rear traction.
worse comes to worse.. ill just JAM on the brakes if i need to dive into a corner.
ill try those things this weekend tho and let you know what i find.
Hebiki Design Works
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
