Tamiya TRF415
The original 415 is much stiffer than the latest model so much better for carpet racing. Still very competitive.
Yep, and I have one of those babies. I'm willing to sell it too, PM me if interested !
Originally Posted by John Doucakis
My blog has just been updated with pics from the LRP TCM.
Here are photos of Marc's and Hupo's cars.
http://jdracing.blogs.se/
marc prob running brushed as checkpoint doesnt make brushless......
TRYHARD: what size shim are you running under your mre steering? and where exactly do these shims go? thanks!
Why are a lot of people using the old steering on a new 415 car? people use the 415msx mre but with the old steering, why is that?
Arjen
Arjen
I think some people find it easier to drive. Personally i like the new steering system. It feels more responsive.
Charles
Charles
Arjen
Arjen
Arjen
Arjen
R/C Tech Elite Member
I've just updated my MSX to MRE spec (Lower deck, Pulleys, Air Duct etc) but am keeping the old steering just as I tried a mates MSXX with the new steering and it was way too sensitive for me, when you have 42mm turnbuckles to the hubs and a short one to the servo, yes it's far more reactive, but sometimes a little too much so! It's all personal choice, and it's not too much a task to change over later on!
Originally Posted by nikkiesteban
what brand is that battery matched by checkpoint?
Upper Link Position
Q1. Anyone can explain the meaning of the three holes location on the upper front / rear bulkheads ? Does it matter ?
Q2. Shorter vs Longer Upper Link ? Suggestion for asphalt ( Low to medium grip ) but technical track ?
They affect your roll centre, stick to what the manual says for now, you can always adjust it later
Elvo's setup guide explains it well from a technical perspective - http://users.pandora.be/elvo/
Essentially it is the instantaneous point in space around which the car is rotating when it rolls into a corner. And the posistion of this relative to CG is important.
A raised roll centre - acheived with a more angled/shorter camber link or by raising the inner suspension mounts - decreases cornering grip on that axle but also makes the car more responsive.
Lowering the roll centre (longer/less angled link, lower suspension blocks) does the opposite.
Extremely angled camber links also generate more dynamic camber change which is a whole different kettle of fish.
Generally, to generate more grip run a low roll centre. So for low grip asphalt a lower roll centre is usually better.
