Old 04-14-2007, 11:09 PM   #18091
Burlap's Avatar
Send a message via MSN to Burlap
Originally Posted by quantum
is there a general rule of thumb on when to use the shorter evo5 arms?
i know lots of ppl use them on the msx when running foam carpet, but is it advantageous to use with rubber asphalt or rubber carpet in 19T?
what exactly does the shorter arm do?
I race on asphalt mainly, and found the car less twitchy on the short arms compared to the long arms.
Also the short arms are far more stronger than the long arms, and don't snap as easily. For example I have been running the same short arms as what I originally reassembled the car with, and been racing the past two months. No broken arms at all. Same period I would've been through at least 3 long arms.
Burlap is offline   Reply With Quote
Old 04-15-2007, 02:40 AM   #18092
TryHard's Avatar
really? I have to admit I've only used the short arms indoors, and am still yet to break one... but over the coarse of last season (running only the long arms), I think I broke only 1 arm, and that hit also bent the rear axle and hub...
ahh well
| THard.co.uk | Xray | MuchMore |
Old 04-15-2007, 03:24 AM   #18093
Eirik's Avatar
I always use the short arms as they made my car more precise, gave more corner speed, more steering and faster laptimes!
The car was soo much better with them, so I never went back to the std. arms.
Eirik is offline   Reply With Quote
Old 04-15-2007, 04:07 AM   #18094
Szimon's Avatar
Default new 415?
My local official tamiya distributor told me about new "tamiya 415" which should be showed in Shizuoka? Did anyone hear about it?
Szimon is offline   Reply With Quote
Old 04-15-2007, 04:14 AM   #18095
Szimon's Avatar
I have to agree with you but I used longer arms only two time after "short arms time" started :-)
I was on very bumby track with long curves, the car was very unstable with short arms unlike long arms.
Old 04-15-2007, 04:40 AM   #18096
Burlap's Avatar
Originally Posted by TryHard
really? I have to admit I've only used the short arms indoors, and am still yet to break one... but over the coarse of last season doing the nationals, I think I broke only 1 and that hit also bent the rear axle and hub...
ahh well
I think you misread what I typed, I haven't broken a short arm at all so far
Old 04-15-2007, 05:52 AM   #18097
TryHard's Avatar
Ahh... my fault, I was talking about the long arms... I only broke one all last year.
Old 04-15-2007, 06:11 AM   #18098
nexxus's Avatar
Trader Rating: 302 (100%+)
I started off with a set up Tryhard suggested for me for Carpet (see a few pages back) and I gave it a go on Asphalt, by just changing to a front one way and a couple of shock position changes, and it's got to be by far the best it's handled, Short arms make the car so much more precise, I may have to dump all my spare long arms on Fleabay!
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 04-15-2007, 07:50 AM   #18099
xtrememadness's Avatar
Send a message via AIM to xtrememadness
when using the short arms are you shortening the wheel base also or are you using longer blocks and keeping the same wheelbase as with the longer arms? i run the b and a blocks up front and the d and xb blocks in the rear with the long arms so what blocks should i run with the short arms? thanx
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 04-15-2007, 07:55 AM   #18100
Short arms will not affect wheelbase, but it will decrease the track width. Yes, people use longer suspension mount to compensate for the narrower width.
trf_racer is offline   Reply With Quote
Old 04-15-2007, 12:38 PM   #18101
rctouringracer's Avatar
Send a message via Yahoo to rctouringracer
Is it necessary to switch to 42mm axles if you switch from the standard lwt arms to the short lwt arms?
Burned up
JoeRacer Graphix
Wanna Bee Racing
rctouringracer is offline   Reply With Quote
Old 04-15-2007, 01:00 PM   #18102
sohlman's Avatar
Trader Rating: 89 (100%+)
No. I'm using the 46mm ones and they are fine with the diff, one-way and spool.
Steve Sohl
sohlman is offline   Reply With Quote
Old 04-15-2007, 01:09 PM   #18103
RC MARKET's Avatar
Yes use 46mm is ok or Square !
short arm only short 1mm
RC MARKET is offline   Reply With Quote
Old 04-15-2007, 07:53 PM   #18104
Burlap's Avatar
Look back at the past couple of pages, and you will see your answer in regards to what toe blocks you need to run
Old 04-16-2007, 02:51 AM   #18105
TRF415boy's Avatar
Hi guys,
First meeting outdoors of the season, I made a few changes to my setup from last year and it seemed to have worked quite well.
I ran this setup with a 12T in and in 5-cell 3.5T b/L (using a XA block at the back to get 3deg toe in) and I equalled my track record on 6-cell mod on that track.
Then on sunday used it to take 3rd qualifying spot at TORC in 19T, bearing in mind I didn't have much HP compared to the 2 front runners.
It's basically a MSXX setup, with adequate springs and the short LW suspension, and the rear RC blocks raised 1mm to try and get a more even wear on the front and rear tyres, and get a few more good runs out of new tyres.
Worked well as I did my best run in qual 3, on 3rd run tyres and at the hottest part of the day. No drop off in the two finals either using the same tyres.
TRF415boy is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
