Old 03-20-2007, 05:08 PM   #17911
Burlap's Avatar
Send a message via MSN to Burlap
Originally Posted by RocketRacer
TryHard, do you have a possible base setup for my situation. Mod, foams, outdoor,asphalt. i am running a 3.5 Brushless motor in my MSXX. any help would be much appreciated.
When I ran foams on my 415 outdoors, I found the white springs were firm enough to get grip. 50-60wt oil. YMMV with the faster motor however.
Burlap is offline   Reply With Quote
Old 03-20-2007, 05:18 PM   #17912
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
Originally Posted by Charles Godwin
MSX is a very capable car it can work on any surface, i think Hupo still runs his instead of the MRE. MSX has LW suspension so it can change direction quicker and is usually the standard for outdoor racing. The MSX has also other little things such as blue shocks, gold Ti shock and suspension shafts and aluminion rear hubs.
Charles
i see.. going to MRE is a bit pricey for me.. About the drive train how free is the drive train of the msx?
nikkiesteban is offline   Reply With Quote
Old 03-20-2007, 08:37 PM   #17913
veecee's Avatar
Trader Rating: 34 (100%+)
Originally Posted by nexxus
Also. can I run the MRE lower deck (to make use of the air vents for the motor) or does it need some mods? Have heard some stories of changing steering positions, want to keep with the MSX set up, so the option is an MRE/MSXX lower deck, or a 4mm MSX lower deck.
As I've mentioned before (though a few pages ago now), MRE lower deck has holes for both MSX and MRE steering setups. So you can run either steering setup. However the upper decks are specific.
SMOKEM --- XPRESS --- MONTECH --- SRT
veecee is offline   Reply With Quote
Old 03-21-2007, 05:36 PM   #17914
[QUOTE=TryHard]Blue247carz; Which car are you running? MRE or MSX?
I did the national at Southend last year with my MSX... and for the life of me can't find the setup I used (or any of the other national ones...), still a good starting point would be...
Drive; Spool + Locked centre
Shocks; HPI Blue or Tam Yellow Springs all round 30-35wt oil, 3 hole pistons, Front hole 2 in tower, 3 in arm, rear 4 tower, 3 arm.
Roll bars; Yellow all round
Suspension block; B/XB front, XC/B rear, no shims (although you could also try the now favoured B/A, and XA/D combination)
Camber links; Front 2mm, Hole 3, rear bulkhead 1mm hole 2, rear hub position B, 1mm.
Rideheight, 5.5mm Front, 6mm Rear
Droop; 5 Front, 3 rear (the rear setting is an important one, as otherwise the car will ride the droop screw round the sweeper, then snap out before the chicane at the end of the straight)
If you don't want to run roll bars, try HPI silver or Tam blue springs instead.
Cheers for the reply, I am currently running the MRE with the short reversable arms and the mounts B/A front & XB/D rear = 2.5mm
I will be running 19t KD Demon not Mod.
I have tried the softer yellow and blue springs but they seem to give slower times around the local outdoor Bedworth track than the combination I currently run which is White front 40wt & Yellow rear 35wt with the red foam spacers in the top of shock and 3 holes. I have seen people run without the spacer but do not know what this does?
I have also found that the blue thick roll bar all round gives the car more grip than the original black ones.
But as you are saying the top boys do run yellow springs all round and soft roll bars. Is this just a modified thing or will it work for a slower 19t speed?
I can send my current setup for you to have a gander if you like, see if you can see any probs.
I do tend to find the car has nice turn in but washes a bit on mid corner, also can be difficult to drive on the limit. Springs may be the prob but just always found whites quicker especially for 27t class.
Cheers Paul Pinkney
blue247carz is offline   Reply With Quote
Old 03-21-2007, 09:06 PM   #17915
Trader Rating: 112 (100%+)
Default New 415 Owner
Hello,
I bought a 415(1st version).
What is the internal gear ratio?
Also what parts can I use to make a ball diff for the front?
I have a oneway in now.
Thank you for the help
Dave
Sponsors: YuK-Foo Tire Prep
dragracer72nova is offline   Reply With Quote
Old 03-21-2007, 09:10 PM   #17916
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
Yokomo parts were used to make the first diffs. I believe Tamiya sells one now however. If your running indoor Carpet w\ rubber Tires I would stick w\ the one-way.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 03-21-2007, 10:25 PM   #17917
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
53921 aluminum diff for the 415
51055 35 tooth diff gear
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|CRC Xti Altered Ego|Associated B5M|TT02|TA05|TL01RA|TL01|
f1larry is online now   Reply With Quote
Old 03-21-2007, 11:28 PM   #17918
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
MSX drivetrain are nice no need to worry plus it is using the white low friction belts so its a very free drivetrain
buboy28 is offline   Reply With Quote
Old 03-22-2007, 12:34 AM   #17919
nexxus's Avatar
Trader Rating: 302 (100%+)
Originally Posted by TryHard
Attached is a base setup to try, it's a combination of the maritime one, with updates that I know work from my recent setups for the MRE.
With regard to the bottom plates, yes you can use the one from the MRE or MSXX, as they both still have the holes drilled for the old steering system, so just a case of bolting it on.
HiH
Ed
Panoramic view of track if anyone is interested and/or has suggestions.
http://www.rcracephotos.com/special/eponroad.html
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 03-22-2007, 03:33 AM   #17920
TryHard's Avatar
Cheers Paul Pinkney
Hi Paul,
I'll admit I haven't run my MRE outside for a whie now, so am a little out of touch on the setup for it. However, if I remember, Bedworth is smoooth, something southend certainly isn't. I'm pretty sure southend is tighter and more technical too.
Sounds like your setup is not far off the kit setup for the MRE. The MRE does seem to prefer a stiffer front spring (due too the steering setup), I guess thats why it's standard setup of Blue front, yellow rear springs. Also, the std black roll bars are medium front, soft rear.
I would think of going softer for southend, mainly due too the bumps.
Have you tried blue on the front? The white could be part of the reason for washing out mid corner... although I do have another theory for that.
Where abouts are you running you steering links? front hole in hub, with 0.5mm behind? If so, I found that really tricky to drive, so I moved the steering arms back in the hub, which helped, and then recently (albeit on carpet, when I was experiencing a vacuum of mid-corner speed ) I added shims behind the ackerman ballstuds, and this settled the car down more.
Shocks don't sound far off... maybe 35/30 for southend.
The foam bushing has the effect of increasing the pack of the shock, as it stops the rubber diaphragm from collapsing under pressure. This makes the shock initially more resistant to motion, until the oil flows through the piston holes. Removing it allows the diaphragm to collapse a little under load, which softens the initial resistance of the shock, and smooths out the action. It makes the shock feel about 10wt lower in oil. (ie a 60wt/no foam feels similar to a 50wt/foam)
HiH
Ed
| THard.co.uk | Xray | MuchMore |
TryHard is online now   Reply With Quote
Old 03-22-2007, 04:36 AM   #17921
Which is better in MSX the stock pulley pitch or the ta05 pulley pitch?
marklitero is offline   Reply With Quote
Old 03-22-2007, 05:46 AM   #17922
buboy28's Avatar
Originally Posted by marklitero
oh good. thanks sir buboy28. Which is better in MSX the stock pulley pitch or the ta05 pulley pitch?
do not know if the pulley from the TA-05 will fit the MSX but if its the MRE the TA-05 pulley will fit. stock pulley of the MSX is good enough but if the TA-05 pulley will fit better get those wide pitch pulley
Old 03-22-2007, 07:30 AM   #17923
Hi Paul,
HiH
Ed
Take a look at my current setup if you will,
Front:
1B/1A bridge both spaced 1mm underneath both
Short reversable suspension with HPI hubs and Tamiya 4deg C hubs
Standard Tamiya 5mm blue hexes
Steering link rear hole which is just a tad further forward than Tam rear hole
3mm spacers to adjust acherman angle back on steering block
2mm spacers under inside front camber link
Camber link in 3rd hole
3mm top deck Fibrelyte
Tam Spool
Blue roll bar
TIR CVD's
.5deg neg camber
40wt oil white springs 3 hole
outer hole at bottom and 2nd hole down at top
6mm ride height 6mm droop
Rear:
1D/1XA with 1mm spaced underneath both
Short Reversable arms standard 0deg hubs and hexes with 1mm spacers
2mm spacers under inner camber link at inner hole
3mm spacer under outer camber link in middle hole B
6mm ride height 4mm droop
blue rool bar
35wt oil yellow springs outer hole on bottom 2nd hole down top
1 deg neg camber 2.5deg toe
standard chassis
ceramic diff balls
Car runs 186mm front & rear track
Cheers Paul
Old 03-22-2007, 07:54 AM   #17924
TryHard's Avatar
Hi Paul,
That all sounds pretty good. Does seem that your running a lot of spacers behind the ackerman ball-stud, any reason for this? The rule of thumb goes, more spacers = more steering, I'm just wondering if the ammount of spacers is compormising other areas of the setup (ie, if you having to take away inital steering by running a stiffer spring, you could be compromising your mid-corner and exit traction).
Then again, if your happy with the setup, run it like that, most of the changes you'll probably make would be quick and easy (spring/roll bar etc). I've nearly always found that if having to change your base setup loads to run someones track specific setup it's never that good an idea, simply as you won't be used to how it works.
HiH
Ed
Old 03-22-2007, 08:49 AM   #17925
[QUOTE=TryHard]Hi Paul,
Hi Ed
Sorry the spacer is 2mm not 3mm, that would be alot.
The reason for running the larger spacer behind the steering arms is to bring the acherman angle back to the original angle when I was running the Tamiya Hubs on the outer hole. If I reduce this spacer the angle becomes greater and the steering more aggressive.
I may be dialing out the initial turn in with the use of the harder springs and just as you say once the car has rolled the spring is too hard and scrubs slightly, but I do find that the softer spring does make the car lose some corner speed as there is more roll, weight transfur and grip.
I suppose you can throttle more to compensate with 19t against 27t as long as the spool doesn't make the car understeer.
I will try the different springs if I get a chance before quali and will adjust the droop to 5 and 3 as you said for the sweeper.
Cheers for all your help, hope I don't embaress myself to much :0(
Paul
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
