Old 03-03-2007, 05:10 PM   #17776
TryHard's Avatar
Originally Posted by veecee
Sounds good Ed. I'm going to play around with droop a bit more on the MSX/RE. If that doesn't cure my lack-of-steering woes, then I'll go to 1mm spacer. If not, then I'm going to short arms. A few people have found these to work well on the MSX/RE
What droop are you running?
For carpet, I run 6 F and 4 R (measured off a gauge). I currently have the Short arms on the car too, seem to work well, although I haven't done a back to back with the long ones, so can't really comment.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 03-03-2007, 05:55 PM   #17777
veecee's Avatar
Trader Rating: 34 (100%+)
I'm running 5F and 4R on a gauge. I'll have a chance to do some back-to-back testing with the ackerman and short arms on Tue night. Should be interesting.
SMOKEM --- XPRESS --- MONTECH --- SRT
veecee is offline   Reply With Quote
Old 03-03-2007, 11:52 PM   #17778
Tek Nickal's Avatar
Whats the part number for the new spool that comes on the MRE? I'm using the 36t pulleys on my MSX. And will it fit?
Tek Nickal is offline   Reply With Quote
Old 03-04-2007, 04:12 AM   #17779
veecee's Avatar
Had some spare time earlier today and decided to put the short arms in and rebuild the CVDs. I'm very keen to try this setup in a couple of days time. With D-D blocks at the front, X-E blocks at the rear and std hexes with 1mm shims, the car comes to 187mm.
Old 03-04-2007, 09:05 AM   #17780
Vicko's Avatar
Trader Rating: 14 (100%+)
hey just wanted to know if anyone use the stock MR chassie for carpet at all
or dose eveyone use the 4mm one and make the mods to fit the streeing
Vicko is offline   Reply With Quote
Old 03-04-2007, 10:43 AM   #17781
TryHard's Avatar
with rubbers or foam?
Personally, the 2.5mm chassis is a little flexible for rubber carpet work, but not enough to worry too much about. For foams, the 4mm chassis is probably best.
HiH
Ed
Old 03-04-2007, 11:03 AM   #17782
Vicko's Avatar
foams that all I race but I love this car, but the new blue cyclone seems to be fasters (BMI chassie for cyclone)
Old 03-04-2007, 12:35 PM   #17783
TryHard's Avatar
4mm then... or try and convince BMI to make one for the 415
Relating to my earlier post, some pics to explain it better.
First two, shows the screws on both cars that I measured the distance between (rear two, steering posts, front two, suspension block).
Second two, show the ackerman spacers (red arrow), and wheelbase spacers (yellow arrow).
What I've done is assume all other measurements are equal, so effectively by adding thoose three variables together, I can figure out exactly the difference in ackerman between the two. A large total number means that the longitudinal difference between inner and outer l joint is larger... effectively putting the steering link at a greater angle.
Because the spacings are different on the two cars, the ackerman setting is different, which affects the way the car turns. I'm trying to get my MRE to handle as well as the evo on the rug, so hence why I've added spacers.
HiH
Ed
Tamiya TRF415-dscf0011.jpg   Tamiya TRF415-dscf0012.jpg   Tamiya TRF415-dscf0016.jpg   Tamiya TRF415-dscf0017.jpg
Old 03-04-2007, 04:24 PM   #17784
hi all iam running a msx and want to replace the chassis,will the mre chassis fit and still be able to keep the old type steering or will i have to change the steering aswell
thanks
skiv is offline   Reply With Quote
Old 03-04-2007, 06:26 PM   #17785
Vicko's Avatar
if u goin to run the mr chassie u may want to use the mr streeing it and mr top plate
Old 03-04-2007, 09:02 PM   #17786
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
Is there a Tamiya Diff for the 415 and if so what is the p/n. Or am I stuck just using a spool for TCS racing. Also what is the part number for the locked center pulley?
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|CRC WC-Xti|TT02|TA05|TL01|
f1larry is offline   Reply With Quote
Old 03-04-2007, 09:48 PM   #17787
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
there is a diff.
http://www.tamiyausa.com/product/ite...oduct-id=53921
http://www.tamiyausa.com/product/ite...oduct-id=53708
tamiyarcracer is offline   Reply With Quote
Old 03-04-2007, 10:08 PM   #17788
f1larry's Avatar
Thanks, Wish I would have had that for this weekend, better late than never
Old 03-05-2007, 02:48 AM   #17789
veecee's Avatar
thanks
Yes there are holes for the MSX steering so you can run it with the MSX top deck if you want.
Old 03-05-2007, 03:32 AM   #17790
Ed. I notice at you use those cone washers your top deck. Did you feel at tweak broblem is gone after that modification?
I made order M3 countersink washers and i`ll try those also with my MRE.
http://www.rctech.net/forum/attachme...hmentid=209731
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini M03 - Tamiya 415MSX MRE - Tamiya 416 WE
Cruisaaja is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
