Old 03-01-2007, 05:08 AM   #17746
peejay's Avatar
Originally Posted by Stein Tumert
You find them all here http://www.tamiyashop.ch/index.php?c...=3&cPath=10_12
Good prices too!
But they don't/won't deliver to UK addresses (in checkout you cannot get beyond the first step with a UK address), and so far they have not responded to my query about this.
peejay is offline   Reply With Quote
Old 03-01-2007, 06:40 AM   #17747
LBSR415's Avatar
Originally Posted by tbeardmore
I need your help guy's. I've been running a 415 MSX MRE now for about 3 months now. I've been running on Carpet w/ Rubber tires and a front Spool.
It seems like I just can't get the diff. right and I'm frustrated with it.
It seems to be wearing out the thrust bearing abnormally fast. I try not to over tighten it, but it always feels like it's too loose and makes a sound like it's slipping. Could it be the belt slipping? (SCREEEEECH)
I've rebuilt the diff using ceramic balls, resurfaced the diff rings, replaced the screw and the the lock nut. I've tried lock tight.... but I keep having the same problem.
Any tips of input on how to fix the problem I having would really be appreciated.
THANKS!
check the manual for the diff build,,there is a shim that goes between the diff bearings,,make sure it is there
Team OHP
Razor Graphix
East Coast R/C
Pantheon Motorsports
These fish,,,are frozen.
LBSR415 is offline   Reply With Quote
Old 03-01-2007, 11:47 AM   #17748
tbeardmore's Avatar
Originally Posted by sim600
What kind of grease did you put in the thrust bearings? I think they need to be pretty thick. I use Tamiya Anti-Wear grease in mine. Not sure about others.
That's what I use.
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 03-01-2007, 11:47 AM   #17749
tbeardmore's Avatar
Yup! It's in there....
Old 03-01-2007, 12:37 PM   #17750
Charles Godwin's Avatar
I'd try replacing the little nut in the diff half. That might have worn out. What diff grease do you use?
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 03-01-2007, 01:07 PM   #17751
THANKS!
Get new diff rings. Clean everything with motor spray. And give it to someone who knows how to build a diff properly. And watch how he does it. But, it sounds like the same problem I use to have, which was putting to much grease on the diff balls. And the sound your talking about, have someone check to see if your belts are to loose.
Juan Aveytia is offline   Reply With Quote
Old 03-01-2007, 02:52 PM   #17752
RC MARKET's Avatar
Originally Posted by SpeedDesignz
The MRE comes with titanium screw where as the MSXX does not. You can also use the 4mm chassis with the MRE or MSXX you just need to modifiy it a bit to accept the different steering rack. I've been using it on mine since new. I only run it on Carpet W/foams. The MSXX does use the Evo front.
Yes !
So MRE ver. car kit is cheaper,
& you can option Air Duct for cool down motor .2/3 arrive
RC MARKET is offline   Reply With Quote
Old 03-01-2007, 07:56 PM   #17753
Trader Rating: 23 (100%+)
THANKS!
The sound you are hearing is the diff slipping. Try to tighten the rear diff 1/8 of a turn and see if slippage is reduced.
I had the same issue and rather than going to thicker diff grease or finding some other means to reducing diffing, simply tightening the diff helped.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 03-01-2007, 09:40 PM   #17754
maxepower's Avatar
Talking "DIFF OUT DUDE"
THANKS!
I just wanted to add a little more to whats been said about Tamiya diffs.
When they are built correctly they are as smooth as butta!, but if not re-built correctly they can be a real pain in the "AZZZZZZZ"!
Not only check the locknut but also the plastic piece that holds the locknut. Look very closely at them,some of them crack and get deformed from over tightening. I do a little mod to protect this piece. I put a washer between the plastic piece that holds the nut and the spring. This protect the plastic piece from getting deformed from the spring which can cut into the plastic or worse. I believe it also puts even pressure on the nut and screw.
I also use anti wear grease and replace the thrust bearing when you change the plates and balls. Hope I could be of some help!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 03-02-2007, 01:20 AM   #17755
Hey there
I had a feeling at my MRE:s original Tamiya servo saver is little flexible, so i decided to change it. I bought Kimbrough servo saver 25 spline drive # 114 because i use Futaba s9550 and i think it`s better to use saver anyway.
I`m not visit track yet, but is that ok, or what saver you use with that servo?
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini M03 - Tamiya 415MSX MRE - Tamiya 416 WE
Cruisaaja is offline   Reply With Quote
Old 03-02-2007, 03:12 AM   #17756
Burlap's Avatar
Send a message via MSN to Burlap
Originally Posted by Cruisaaja
Hey there
Tamiya servo savers are well known for going sloppy very quickly. For all their expertise, why they have not come up with a better arrangement is beyond me.
I use the small Kimbrough servo saver that is specifically made for Futaba servos. Works beautifully.
Burlap is offline   Reply With Quote
Old 03-02-2007, 03:55 AM   #17757
Yeah. I found that link as well... and there is that #114 saver.
http://www.kimbrough-products.com/servosvr.htm
Old 03-02-2007, 04:26 AM   #17758
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Hey there
i'm also using that for my MRE
buboy28 is offline   Reply With Quote
Old 03-02-2007, 08:22 AM   #17759
Tsquare's Avatar
THANKS!
I had a problem with the Tamiya diff, it kept coming lose. The problem I was having is the locknut would spin inside the plastic locknut holder as I tightened the diff screw. I race at Tamiya's track in orange county, Fred Medel of Tamiya gave me a fix two years ago and I have never had a problem since:
Place a drop of CA glue in the placstic piece that holds the diff locknut, it will keep the nut from spinning as you get to the desired diff tightness, it also helps keep the plastic nut holder from cracking.
Good luck, I hope this helps.
Tsquare is offline   Reply With Quote
Old 03-02-2007, 09:20 AM   #17760
Rogier's Avatar
FINALLY!! The airduct for the MSX MR (or MSXX) is for sale!! It's now available for $12,00 at RcModel in Hong Kong. Too bad they don't show the actual stock...
My RCTech trader feedback: http://www.rctech.net/forum/trader-feedback/146331-rogiers-feedback-thread.html
Rogier is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
