Old 02-27-2007, 02:48 PM   #17731
Wing Chun's Avatar
Originally Posted by J Stark
TRFMAD: If you're going to try a 10x2 your gearing should be around 102/30 or 31. Just a basic rule of thumb, is that you go up a tooth for each turn. If you don't like the strength of a 7 or 8 turn, you should try a 9 turn also to get that smoother feel you are looking for. If the track you are racing on is on the small side, you can get away with motoring down. You'll notice that a 10 turn lacks top end and punch in all phases, but will be very comfortable to drive.
Thank's Mate
The track I am racing is small this weekend and has a main staight of 35 metres. I ran a 8x1 last weekend and tried to go smooth but kept running out of straight.Do you think that a 10 would be better.
So what is the difference between a double wind and a single wind and so a 7 has much more top end and a 10 has more punch is this right. It's just that I have always run a 7 or 8.
Addam
Wing Chun is offline   Reply With Quote
Old 02-27-2007, 06:26 PM   #17732
J Stark's Avatar
Well, a 10 turn is going to be better if you have a good set-up, drive smart and don't make any mistakes for 5 minutes. On a smaller track, I think it's better to drive a 9 turn hard then to hold back and conserve a 7 turn. Check your lap times with a 7 turn and then put in a 9 or 10 turn and see the results.
The difference between a single and a double is more driver preference. A single has more burst on the low end and a double has a bit more smoother feeling as it goes through the power band. A double is more for free flowing tracks. When I check some of the pro's set-up sheets, it seems like a lot of them prefer a single, so I don't know.
Sounds like you got some motor testing to do lol.....
J Stark is offline   Reply With Quote
Old 02-27-2007, 09:08 PM   #17733
Wing Chun's Avatar
Originally Posted by RC MARKET
MSXX Air duct good or bad , can cool down motor ?
So will you have them for sale soon?
Addam
Old 02-28-2007, 06:57 AM   #17734
Default Battery Strap Kit
Originally Posted by racer43
does anybody knows if somebody is making some kind of battery strap for the trf415mre/ tape them down is a pain.
Hi, have a look at this one, I had for sale on ebay.co.uk.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...L:EOISUA:UK:11
Item no 170083710219
Tweaky is offline   Reply With Quote
Old 02-28-2007, 04:23 PM   #17735
gijoe64's Avatar
Trader Rating: 30 (100%+)
I would like to know which 415 I should buy.
415MSX Refine2
or
415MSXX
What is the better value?
What are the Differences?
I know they are both good cars, should I buy the new version?
Thank you
gijoe64 is offline   Reply With Quote
Old 02-28-2007, 04:53 PM   #17736
SpeedDesignz's Avatar
Send a message via AIM to SpeedDesignz
The MSXx would be the way to go. It's always good to have the up to date technology. The MSXX will have a smother drivetrain. Better steering rack. ect....
NYC Hobbies / Eurotek motorsports / SpeedDesignz / BackBreaker Racing !!
SpeedDesignz is offline   Reply With Quote
Old 02-28-2007, 07:02 PM   #17737
hyena boy's Avatar
where can i get the part numbers for the pivot blocks for the suspension arms?
i am trying to use marks set up from iic carpet foam mod, but i do not have all of the blocks.
hyena boy is offline   Reply With Quote
Old 02-28-2007, 07:12 PM   #17738
maxepower's Avatar
MSX vx.MSXX?
415MSX Refine2
or
415MSXX
Thank you
Isn't the 415msxx only a 2mm lower deck? If your running carpet with foam tires I would think that the MSX is better because it's 2.5mm thick? I'm not completely sure and if it really matters or not?
Just my 2$
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 02-28-2007, 07:51 PM   #17739
Tek Nickal's Avatar
It really depends what your running, some find that the steering rack on the MSX is better suited for foam on carpet than the newer one on the MRE and MSXX. Also the 4mm lower chassis is available for the MSX.
But for asphalt the definite answer would be the MSXX.
Tek Nickal is offline   Reply With Quote
Old 02-28-2007, 08:07 PM   #17740
secretsg's Avatar
Still a little lost on the differences between MRE and MSXX. From what I've gathered the diff setups are different and MRE has more hop up parts included. MSXX also has a EVO 5 front? I'm also not sure if MSXX will fit a 6 cell pack.
If the MSXX has the same build quality, has 6 cell compatibility and I can get all the hop ups then I would just wait for the summer to get it. If MRE has better carbon/materials etc I would have to try and find one now. I will be running asphalt with rubbers and using Orion 3200 LiPO pack (with some filing I gather.)
Please advise. Thanks!
secretsg is offline   Reply With Quote
Old 02-28-2007, 08:24 PM   #17741
The MRE comes with titanium screw where as the MSXX does not. You can also use the 4mm chassis with the MRE or MSXX you just need to modifiy it a bit to accept the different steering rack. I've been using it on mine since new. I only run it on Carpet W/foams. The MSXX does use the Evo front.
Old 02-28-2007, 08:54 PM   #17742
tbeardmore's Avatar
I need your help guy's. I've been running a 415 MSX MRE now for about 3 months now. I've been running on Carpet w/ Rubber tires and a front Spool.
It seems like I just can't get the diff. right and I'm frustrated with it.
It seems to be wearing out the thrust bearing abnormally fast. I try not to over tighten it, but it always feels like it's too loose and makes a sound like it's slipping. Could it be the belt slipping? (SCREEEEECH)
I've rebuilt the diff using ceramic balls, resurfaced the diff rings, replaced the screw and the the lock nut. I've tried lock tight.... but I keep having the same problem.
Any tips of input on how to fix the problem I having would really be appreciated.
THANKS!
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 03-01-2007, 12:59 AM   #17743
sim600's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to sim600
What kind of grease did you put in the thrust bearings? I think they need to be pretty thick. I use Tamiya Anti-Wear grease in mine. Not sure about others.
ModRC.com
sim600 is offline   Reply With Quote
Old 03-01-2007, 01:35 AM   #17744
Burlap's Avatar
Send a message via MSN to Burlap
http://www.tamiya.com/english/rc/manuals.htm
You can download with the TRF415 or TRF415MS manuals, they had all the toe/pivot blocks supplied with them, unlike the MSX.
Burlap is offline   Reply With Quote
Old 03-01-2007, 02:08 AM   #17745
Stein Tumert's Avatar
You find them all here http://www.tamiyashop.ch/index.php?c...=3&cPath=10_12
Good prices too!
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
