Old 02-23-2007, 07:05 AM   #17686
chris_morrison_'s Avatar
The only way to run the team orion 3200 lipo in the msx with out filing those beautiful bulk heads is.....................
To use the standard msx steering rack and the bulkheads and top deck from This
chris_morrison_ is offline   Reply With Quote
Old 02-23-2007, 07:52 AM   #17687
TryHard's Avatar
Originally Posted by lucandowen
Hello fellow TRF'ers
Does anyone (UK pref) have a front one-way for sale or that I could borrow for Carpetwars (Ed/Fab?? ) this weekend????
As I am unable to make my throttle stick go backwards I thought I would give one a tray!!!
Hi Lucas,
I have an original style one mounted on a TA05 pulley you can use if you want... the MRE one I might need.
Come find me in the pits on sunday morning.... look for the shell in the pic <----
Hih
Ed
| THard.co.uk | Xray | MuchMore |
Old 02-23-2007, 08:20 AM   #17688
pug 205 gti's Avatar
ive just took the hammer to it lol
pug 205 gti is offline   Reply With Quote
Old 02-23-2007, 08:54 AM   #17689
I am running the Orion 3200 lipos in my 415 MRE. I found that by taking a dremel tool and removing a slight bit of material from the rear bulkhead (where the contours are to fit a 6 cell pack), the battery will fit. I removed about 1 mm (or less) of aluminum which allows the battery to slide in easily. This modification does not look unsightly and in no way effects the structural integrity of the car.
Hopefully a future release of the 415 will be 100% lipo friendly to include lateral weight balancing.
Hope this helps, Pete
Pete Thomas is offline   Reply With Quote
Old 02-23-2007, 09:55 AM   #17690
ive done pretty much the same it now fits and looks great too.
Old 02-23-2007, 12:28 PM   #17691
Hello everyone,
It's been a long time since I've used rollout charts. Could someone explain how it works and how to use it.
Cheerz
Obsidian is offline   Reply With Quote
Old 02-23-2007, 01:02 PM   #17692
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by Racing4Evo
Thank you for the quick reply Chris!
Now, where can I get these in the US by internet preferably?
tamiya USA is out of the e clip so good luck there.
the others you can get direct from them if you need to.
tamiyarcracer is offline   Reply With Quote
Old 02-23-2007, 01:10 PM   #17693
Kevin CBR's Avatar
orion carbon lipo 3200 has just arrived and it doesnt fit in the msx mre damn!!
Mine worked fine. You just have to tilt the battery from the side to slide it under the rear bulkhead. I have also filed the battery holes on the lower chassis for regular sub c's to fit better so maybe it needs that little extra for the lipo pack to fit. Oh yeah, mine is an MRE also.
Panda Performance / Nemo Racing top secret R&D lab hidden in a lush bamboo forest....
Scorpion Power Systems
Kevin CBR is offline   Reply With Quote
Old 02-23-2007, 02:13 PM   #17694
racer43's Avatar
Default COOLING FAN
i purchase a 3racing fan for my trf and i like to know where do you plug this thing.its strait to the the battery or to the receiver?
racer43 is offline   Reply With Quote
Old 02-23-2007, 02:38 PM   #17695
Wing Chun's Avatar
Hi there
Solder straight to the positive/negative Battery leads on the speed controller. That way you can turn the car off and go and marshall and the motor fan will stay on while the car is turned off.
Here are a couple of pics of mine.
Hope this help's
Take care
Addam
Tamiya TRF415-addams-fan-setup-001-small-.jpg   Tamiya TRF415-addams-fan-setup-002-small-.jpg   Tamiya TRF415-addams-fan-setup-003-small-.jpg
Wing Chun is offline   Reply With Quote
Old 02-23-2007, 02:46 PM   #17696
Wing Chun's Avatar
Hi guy's
What do you guy's think about my shells that TomB did for me here in Oz, I wanted a couple of Rheinard's colour's.
Addam
Tamiya TRF415-addams-2-new-shells-032-small-.jpg   Tamiya TRF415-addams-2-new-shells-038-small-.jpg   Tamiya TRF415-addams-2-new-shells-039-small-.jpg
Old 02-23-2007, 04:45 PM   #17697
couple of pics of the car
Tamiya TRF415-image017.jpg   Tamiya TRF415-image060.jpg   Tamiya TRF415-image011.jpg
Old 02-24-2007, 03:15 PM   #17698
So your MRE, has the air scoop ?
Andyg01 is offline   Reply With Quote
Old 02-25-2007, 01:41 AM   #17699
Burlap's Avatar
Send a message via MSN to Burlap
Originally Posted by Burlap
I might try out the C-A setup this weekend and report its results on Monday. The front one way doesn't bind with that toe block setup, so might be another option for people wanting to run the one way on their 415 without having to change the outdrives.
Ok, not Monday, but still Sunday here.
Gave the car a run today at the races with the short arms.
Car has tons more grip than with the longer arms. Also not as twitchy under power (although only running Stock, so YMMV). That much grip it pretty well cooked my tyres in not too hot conditions.
Car seemed a lot smoother with the suspension change. Sure there might be a placebo effect, but even co drivers noticed the changes with my car. And the short arms are a hell of a lot more stronger than the long ones. I got punted into a corner with a wood barrier, and the car bounced off, no broken front arm.
I highly recommend the short arm setup. Here are the toeblocks I used
Front: 1B-1A (the bridge 1A block, which came on the original 415)
Rear: 1XA-1D (2.5 deg Toe in)
Running 42mm outdrives on the front with the one way, as the 46mm bind up.
Burlap is offline   Reply With Quote
Old 02-25-2007, 02:49 AM   #17700
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
what do you think will be the effect of this modification.?. i flipped the steering into much lower position.. see pics for comparison.. look closey into the steering arm and compare.
1st pic is the original setting
2nd pic is the flipped steering done by me.
post your opinion. im just experimenting.
nikkiesteban is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
