Old 02-20-2007, 03:42 PM   #17641
Burlap's Avatar
Send a message via MSN to Burlap
Originally Posted by TRF415boy
same here with the 46mm dogbones and B/A the driveshafts pins used to be right at the end of the one way outdrive and bind, especially when the suspension is compressed. This doesn't happen with the new MRE one way I may add. Switching to the 42mm outdrives is ok but would be better using the original 415 one way outdrives which are a bit offset.
I might try out the C-A setup this weekend and report its results on Monday. The front one way doesn't bind with that toe block setup, so might be another option for people wanting to run the one way on their 415 without having to change the outdrives.
Burlap is offline   Reply With Quote
Old 02-20-2007, 05:33 PM   #17642
racer43's Avatar
Default white/yellow and white/blue springs
i got the mre edition and i want to know the order of the shock springs.is yellow front or rear.
racer43 is offline   Reply With Quote
Old 02-20-2007, 05:38 PM   #17643
drew85's Avatar
stock is blue in the front yellow in the rear. blue is one step firmer then yellow.
drew85 is offline   Reply With Quote
Old 02-20-2007, 05:40 PM   #17644
TryHard's Avatar
Tamiya springs go;
Red - Soft (~11.8lb)
Yellow - Medium (~13.3lb)
Blue - Hard (~14.1lb)
White - Extra Hard (~15.3lb)
Grey - Super Hard (~20.9lb)
Purple - Ultra Hard (~22.7lb)
The yellows go on the rear on the MRE, so harder front than rear.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 02-20-2007, 06:04 PM   #17645
pug 205 gti's Avatar
im confused i only got white springs with my mre ?? oops ive just checked the springs and i got lucky the yellow ones are on the rear and the blues up front.how lucky lol
pug 205 gti is offline   Reply With Quote
Old 02-20-2007, 06:09 PM   #17646
You should see a dot of blue or yellow paint on the bottom of the spring.
DOTMAN is offline   Reply With Quote
Old 02-20-2007, 06:10 PM   #17647
if you don't see any paint, then they are actually white springs. Someone had the brilliant idea to do this to try and hide their setup from people
Old 02-20-2007, 06:42 PM   #17648
rchoudini's Avatar
Doh
rchoudini is offline   Reply With Quote
Old 02-20-2007, 06:49 PM   #17649
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by GuyIsDamGood
Hey Tamiyarcracer; the Tower Hobbies site is known for putting-up wrong info. I`ll contact Tamiya and find out what`s up with that Turnbuckle Wrench.
-53602 - Tamiya Turnbuckle Wrench is the Silver Aluminum Wrench.....?
-49197 - Tamiya Turnbuckle Wrench is the Blue Aluminum Wrench.
They could be both 4mm Wrenches; but in different colors.
I`ll get back with direct info on it.
Take Care
I just measured the 53602 and it is 4.10mm It is blue.
The 49197 is blue also, it is now discontinued. It was also 4mm. I believe what the difference is, is that the 49197 was a limited production run. then the decided to add it to the Hop up parts line
http://www.tamiyausa.com/product/ite...oduct-id=53602
http://www.tamiyausa.com/product/ite...oduct-id=49197
tamiyarcracer is offline   Reply With Quote
Old 02-20-2007, 09:51 PM   #17650
quantum's Avatar
is there somewhere i can find a list of the parts required to convert the msx to the MRE drivetrain?
ta05 center pulleys, new front oneway and drive cups, wide pitch pulleys... what about the layshaft? anything else? the belts?
thnx
quantum is offline   Reply With Quote
Old 02-20-2007, 09:57 PM   #17651
thnx
go back about a page 5 or 6 I listed it about a week ago
Post 17586 has a link to the manual
Post 17479 has the parts listed
Old 02-21-2007, 03:59 AM   #17652
the blue tamiya turnbuckle wrench 53602 had arrived and it works just fine
Old 02-21-2007, 07:30 AM   #17653
now what droop front and rear should i start out with on the mre.i run rubber tyres and a front diff... please only the peaple with experience thanks
Old 02-21-2007, 08:37 AM   #17654
Charles Godwin's Avatar
With my Associated gauge i generally run 2 on the rear and 3 on the front. I think a lot of people run less droop than me so maybe try 3 rear and 4 front for starting out (droop screws tightened down more).
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 02-21-2007, 08:50 AM   #17655
thanks charles im using 3 racing ones and at the present time i have front and rear at 4 mm
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
