Old 02-12-2007, 02:13 PM   #17506
Trader Rating: 70 (100%+)
[QUOTE=Rogier]OMG... is it that hard to look back one page in this thread??
[url]http://www.tamiya.com/japan/rc/rcmanual/49394trf415msx.pdf[/ur
Sorry dude 1st time on this thread
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 02-12-2007, 02:27 PM   #17507
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
wow... maybe you could read what he actually asked for, instead of slamming him for not reading the 4000 pages in this thread first.....
www.tamiya.com/english/rc/rcmanual/trf415.pdf
try that one..
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 02-12-2007, 04:12 PM   #17508
racer43's Avatar
Default 2.187 formula
if i change the stock spur gear on my trf415 msx mre(102t .4 module) to 64 pitch,the 2.187 number that the manual gives to multiply by change to a different one?
racer43 is offline   Reply With Quote
Old 02-12-2007, 04:17 PM   #17509
pug 205 gti's Avatar
i dont get what your saying?
pug 205 gti is offline   Reply With Quote
Old 02-12-2007, 04:37 PM   #17510
racer43's Avatar
in the instruction manual,page 20,it tells you the gear ratios according to the differents pinion geras. the formula is:
spur gear teeth divided by pinion gear teeth x 2.187
now the stock spur is 102t so its 102t/xxt x 2.187
the pitch on that tamiya spur gears are.04 module pitch which is not quiet 64 pitch.
if I change for a 102t 64 pitch is that 2.187 change?
Old 02-12-2007, 05:07 PM   #17511
Superkarter's Avatar
2.187 is the internal ratio that ratio is calculated by dividing the no. of teeth on the centre pulley and the diff pulley.
but i thought the ratio on the mre was 2.25
So changing the spur gear won't affect the 2.187 number
Hope this helps
Superkarter is offline   Reply With Quote
Old 02-12-2007, 05:07 PM   #17512
No, it stays the same.
Juan Aveytia is offline   Reply With Quote
Old 02-12-2007, 06:33 PM   #17513
the MSX is 2.187. The MRE uses slightly larger pulleys so the internal on it IS 2.25
DOTMAN is offline   Reply With Quote
Old 02-12-2007, 06:42 PM   #17514
Tek Nickal's Avatar
Changing the spur gear on your car won't affect the car's internal drive ratio, it will change your overall gear ratio.
To get the internal ratio, divide the larger pulley by the smaller one, 36/16 = 2.25
So if you have an MRE: spur/pinion x 2.25 = FDR
Tek Nickal is offline   Reply With Quote
Old 02-13-2007, 04:35 PM   #17515
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default motors 19T
GETTING READY for TCs what r u guy's gering the checkpoint money 19t and the new trinity 19t based on the MS not mre
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 02-13-2007, 04:55 PM   #17516
im running a 110 spur 64dp on my msx mre with a checkpoint 19t i was hoping some of you guys could help me with the gearing i havent got the grasp of all this rollout stuff yet.so as it stands what pinions should i be using
indoor carpet racing
if someone has the patience to help me understand the gearing it would be of a great help
i would of thought you want your car toping out just at the top of the longest straight?
but this still leaves me with what size pinions to buy?
thanks in advance
Old 02-13-2007, 05:21 PM   #17517
thanks in advance
What i heard for my stallion a good final drive is 6 to 6.20 so for you U need to find that ..for the stock 415ms that would be 102/36 if u look in your book in the back it tells u how to do it...
Old 02-13-2007, 05:46 PM   #17518
J Stark's Avatar
It's tough to say what grearing you should run with out knowing the size of the track. For a Checkpoint or Komodo, I agree with the post above: Start out at 102/36. That should be real close. If the straight is smaller than 100 feet, go down a tooth. I run on a track that's similar to the size of the Tamiya track and 102/37 is PERFECT gearing for me.
J Stark is offline   Reply With Quote
Old 02-13-2007, 09:02 PM   #17519
Post heat
@ 6 to 6.20 what motor temp will i see ?
Old 02-13-2007, 09:34 PM   #17520
maxepower's Avatar
My motor temp is around 140 degrees. Running 6.2 FDR. If I go to 6.0, the motor temp is around 160 degrees. I like to keep it geared for the infield so I run usually between 6.2- 6.3, I give up a little top end on the straight but I'm very quick in the infield and my rutime is around 8 min. before the battery dumps.
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
