Old 02-09-2007, 09:56 PM   #17476
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by RocketRacer
thanks bro!!
NP
Glad to help
tamiyarcracer is offline   Reply With Quote
Old 02-09-2007, 10:08 PM   #17477
RocketRacer's Avatar
ok, i am going thu the manual, but am not too sure of some of the parts i require.
will a TA05 fron direct coupling work in the 415msxx??
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 02-09-2007, 10:21 PM   #17478
No TA05 is not a 415
on the top 4 pages of the manual it shows assembly instructions for the different cars that make the MRE different from the MSX
Let me find it all for you.
Old 02-09-2007, 10:42 PM   #17479
Here are parts needed to put the MRE drive train in a TRF415
TRF415 MRE Spool:
3454401 Direct holder x 1
9804268 Direct cup x 1
9804267 Direct coupling x 1
53936 Alternated one way pulley x 1
9805776 2 x 9.8 shaft x 1 pkg
53583 3 x 6mm round head screw x 1 pkg
TRF415MSX MRE locked center shaft:
3454395 Direct center shaft x 1
3455643 spur gear stopper x 1
53534 3 x 8mm countersunk screw x 1 pkg
51213 16T pulley x 1 pkg
50589 5mm e clip x 1
Full conversion needs these parts as well
53935 Alternated diff pulley x 1
6245013 Drive belt (long) x 1
6245014 Drive belt (short) x 1
Optional parts
if you want the upper heatsink (TRF415MSX kits only) this is it, and you need the following:
3454404 Aluminum upper brace (heatsink style) x 1
9804263 Aluminum Bearing holder x 1 pkg
Old 02-10-2007, 12:23 AM   #17480
Trader Rating: 24 (96%+)
Default blocks
Does anybody know or have a chart of the msx suspension blocks.Bought a car with a lot of suspension blocks for fine tuneing.But do not know what all the letters mean.My last car just said what degree they were ,these have a lot of diffrent letters do not know what they mean,thanks.
saleen95 is offline   Reply With Quote
Old 02-10-2007, 12:25 AM   #17481
Default blocks
Does anybody know or have a chart of the msx suspension blocks.Bought a car with a lot of suspension blocks for fine tuneing.But do not know what all the letters mean.My last car just said what degree they were ,these have a lot of diffrent letters do not know what they mean,thanks.Oh almost forgot if anybody has one can you email me chart thanks
Old 02-10-2007, 12:26 AM   #17482
http://www.thard.co.uk/excel.html
Old 02-10-2007, 12:27 AM   #17483
Not if you don't leave an email address.
Old 02-10-2007, 06:01 AM   #17484
Can anyone tell me about that new MSXX? Is it made for carpet or asphal racing...??
Just curious
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini M03 - Tamiya 415MSX MRE - Tamiya 416 WE
Cruisaaja is offline   Reply With Quote
Old 02-10-2007, 06:13 AM   #17485
Charles Godwin's Avatar
Tarmac racing because i think it has a thinner chassis
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 02-10-2007, 06:19 AM   #17486
Thanks. When i bought my MRE last autumn it was clear at that car was made for asphalt, but i was`t sure about that new MSXX... that double one-way make me thing that purpose
Old 02-10-2007, 10:16 PM   #17487
I ran the car at the track today, everything was fine. When I was on my last battery pack of the day, the car started to push crazy after 2 minutes of running. I took the car off the track, and I found out the rear diff got so tight by itself. Before that battery pack, the diff was very smooth and free. I got home, took the diff apart, inspected all the parts, it looked okay. I washed everything and put the diff back together. I tighten it until the point the diff does not slip. However, it does not rotate as free as before. What's wrong?
trf_racer is offline   Reply With Quote
Old 02-10-2007, 10:43 PM   #17488
Thrust bearing, or the 2 bearings in the center of the diff.
Old 02-10-2007, 10:48 PM   #17489
There could be a high-spot on the diff rings, you could sand them with 600grit on a flat surface. Bearings in side the diff or the thrust bearing has gone like tamiyaracer said.
Charles
Old 02-11-2007, 02:33 AM   #17490
Burlap's Avatar
Send a message via MSN to Burlap
I have looked back the past 10 pages and found nothing, who has been using Evo V arms on their MSX?
I am looking at getting the arms and 42mm uni shafts, but anyone else tried the different toe blocks method? Part numbers if possible please.
Burlap is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
